I want to make sure i ordered the proper part for my 2013 buick lacrosse. i need the passenger side rear tail light assembly. i think i only ordered the bulb that goes into the complete assembly .
I am trying to replace aleft rear turn signal bulb on a 2005 lacrosse. I removed two wing nuts but cannot remove assmbly. Is there another wing nut holding it in. I cannot find it?
3 wing nuts. here is the info needed.
gmlogoflat.gif Service Information
bhome.gifbpublication.gifbnumsrchbutton.gifbnews.gifymkbutton.giffeedback.gifbhelp.gif
2005 Buick LaCrosse ' Allure, LaCrosse VIN W Service Manual ' Body ' Lighting Systems ' Repair Instructions ' Document ID: 1537542 Tail Lamp, Turn Signal Lamp, High Mount Stop Lamp, License Lamp, Backup Lamp Replacement - Rear
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Turn Signal/Stop Lamp Assembly Replacement - Rear 1
Nut, Turn Signal/Tail Lamp (Qty: 3)
Tip
Pull back rear compartment carpet to gain access to lamp.
Tighten
2 N·m (18 lb in)
Lamp, Turn Signal/Tail Lamp
Tip
Twist the bulb socket and pull inward to replace the bulb.
License Lamp Replacement 3
Screws, License Lamp (Qty: 2)
Tighten
2 N·m (18 lb in)
Lamp, License Lamp
Tip
Jul 29, 2011 | Buick LaCrosse Cars & Trucks
HOW DO I CHANGE THE REAR BULB ON A 2006 BUICK LACROSSE
Asuming you mean taillight/turnsignal, and not highmounted brake light:
1.open the trunk
2.Remove 4 wingnuts on trunk trim (there are two on each side)
You can do it by only removing 2 on one side, but it makes a nicer job,
3.Pull back the trunk "trim" the carpeted cardboard
4.Remove 2 wingnuts which hold the taillight assembly in place
Pull out the taillight assembly; you might want to remove (i.e. unattach or unplug) the wiring harness
5.Turn the particular bulb's socket (there's 5 back there: 2 tail, 1 back up, 1 side marker, 1 brake/turn) counterclockwise, and it removes from the assembly, holding the bulb.
6. Pull out bulb and replace.
6. Reverse steps to reassemble.
Dec 30, 2010 | 2006 Buick LaCrosse
Replace headight assembly on 2005 buick lacrosse
The procedure to replace head light assembly on buick lacrosse is as follows:--- 1)To remove and replace the headlight assembly you will need to remove 1 retaining bolt on the top of the headlamp assembly and 2 sliding retainers at the rear. 2) The carefully Pull up the retainers and that will release the headlight assembly and allow you to pull it out the front. 3) When installing the new headlight assembly make sure you have it lined up correctly before trying to install the retainers, don't force them it may get cracked . 4) Both the cover and the bulb are removed by a standard twist to the counterclockwise and replaced by a twist to the clockwise. 5) Now to the dim light. You have to release the entire light assembly before you can remove the screw-on cover to reach the light. 6) On the rear edge of the light unit closest to the engine is a white locking tab. Pull that tab up just to the point where it releases…pull too far and it locks again. 7) Next, locate the other locking bracket which is a metal bracket in the center-rear of the light assembly. This bracket is held down by a screw. 8) Remove the screw with a 10mm wrench. Lift the bracket just like you did the white bracket. You should now be able to pull (or pry) the entire light unit forward a little. Depending on the size of your hands this might be enough. Note:-- The turn signal is part of the headlight assembly on your 2005 Buick LaCross. 9) To replace the headlight bulb you need to remove the front bumper cover. 10)To release the plastic bumper assembly to give you a little more space. This is done by removing two expansion locking pins, one that holds the little plastic strip down between the bright and dim lights and one that is located inside a rubber bumper on the engine side of the light unit. 11)To remove these locking pins, pull or pry up the little tab in the center of the pin. Thanks.
May 23, 2010 | 2005 Buick LaCrosse
How do you change a tail light in 2005 Buick
I have a 2002 lesabre and suspect it is the same. The light assemblies are bolted to the car from the inside of the trunk. Mine has three sections. Left side of trunk, across the back of the trunk and right side of the trunk. Open the trunk and look thru the small holes in the back for nuts that hold on the sections. They may require a deep socket to reach. Also not all the nuts need to be loosened. Trial and error. Once the nuts are removed the light assemble is freed from the car. Don't let it fall and scratch the car. The wires will help hold it in place. The light holders usually turn/twist and pull out. A little bit of a pain, but not too difficult. Again the deep sockets are probably required.
Apr 25, 2010 | 2005 Buick LaCrosse
Can't get to passenger side head light to change it
Directly behind the head lamp assembly there are 2 tabs.These hold the head lamp assembly in place in back.Pull up on both of these and the complete assembly should pull out.Then remove the covers and replace the bulb that needs replacing.Check and make sure it works before you put it back together.Good luck.
Nov 19, 2009 | 2006 Buick LaCrosse
How to replace a 2003 Buick Century rear tail light assembly?
open the trunk and unscrew the plastic nuts on the back side of the light assy and replace
Oct 26, 2009 | 2003 Buick Century
How do i change the low-beam bulb on my 2005 buick lacrosse cxl on the passengers side? the assembly wont pop out far enough to unscrew the cap on the housing
there should be 2 brackets at the rear of bulb housing, 1 may have a small bolt.....lift these up and the headlamp housing should come out. you will see how it works when you get it apart.
Oct 09, 2009 | 2005 Buick LaCrosse
No brake lights
Could be your turn signal switch!
The brake lights in this run through the turn signal switches!
Apr 18, 2009 | 1991 Chevrolet C1500
Replacing rear turn signal bulb in 2003 Mustang
remove the trim panel at the very rear of trunk, remove it and place it out of the way, remove tail light Assembly retaining nuts top and bottom, I think there are 6 per side, pull the tail light assembly straight back to access the bulbs for replacement.
Dec 04, 2008 | 2003 Ford Mustang
Computers & Internet Logo
David Payne
David Payne
