Question about Exercise & Fitness
How do you recalibrate a bowflex treadclimber 10
rockfixya
  • 679 Answers
SOURCE: Bowflex Treadclimber tc 1000 turns off
Problem could be low colant, water pump, fan not kicking on (bad sen or bad fan motor) radiator dirty,
so the Treadclimber not working properly.
I hope this helps u
Thanks for using FixYa.
Posted on Jan 30, 2009
SOURCE: We just purchased a Bowflex Treadclimber 1000.
putting the drive sensor wire back in the correct place workedgetattachment.aspx&hm__qs=file%3d3d2f2ee0-2668-46ea-b32c-db049d56cb37.jpg%26ct%3daw1hz2uvanblzw_3d_3d%26name%3daw1hz2uwmdiuanbn%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253aimage002.jpg%254001c99c08.13bd6320&oneredir=1&ip=10.12.128.8&d=d6608&mf=0&a=01_0b590aaade5e800af268d347750ab151eca93264be20cd9ce2166e583b18cfe9
Posted on Mar 03, 2009
SOURCE: bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Posted on Jan 12, 2010
  • 3 Answers
SOURCE: my bowflex treadclimber tc500 is
where are you located
Posted on Nov 21, 2010
  • 679 Answers
SOURCE: my bowflex treadclimber starts for abut 3sec then
The machine needs to be re-calibrated if its an L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
Posted on Jan 22, 2011
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
I get a reading "Err 1" and it will not run at all.
Try recalibrating your machine. Use the owners manual for the steps. This might work. I had an L5 error and it wouldn't run either. Recalibrating fixed the problem.
Jul 09, 2009 | Bowflex Treadclimber
I have a bowflex tredclimer tc1000 won't turn on.
I have a TC3000 and when it wouldn't turn on I recalibrated it using the directions from the owners manual. It's now working. Give it a try.
Jul 08, 2009 | Bowflex Treadclimber
Bowflex tc 1000 treadclimber
Jun 28, 2009 | Bowflex TC1000 Treadclimber
Calibration fail message on bowflex treadclimber.....help
Unplug your machine, restart it and try to calibrate it one more time. I had to do this with mine and it did take more than one try to get it to recalibrate again.
Jun 03, 2009 | Bowflex Treadclimber
Bowflex Treadclimber rubs against housing.
Adjustment is needed. Remove rear covers and using a 9/16 wrench lossen the four bolts that secure treadle assembly to base. Place a 3/4 inch piece of plywood or a 3/8 inch socket extension in between the treadles in the front area. with that in place center them about an 1/8 in closer to the right upright as when you tighten the four bolt up the drive belt will place additional pressure and they should center perfect. tighten bolts...tight. remove wedge from between treadles and recalibrate unit. replace covers and enjoy. Use turtle wax on area rubbed to prevent rust.
Mar 05, 2009 | Bowflex Treadclimber TC5300
My bowflex tc5000 will not calibrate
Check the speed sensor and make sure it is no farther than a credit card away from the drive pully. Unplug unit Located...remove left and right rear covers and back cover. 3 screws in each and 4 screws in back. Follow 2 black wires up to drive belt pulley under back of left treadle. slide sensor in with cc between it and the pully. Recalibrate
Dec 07, 2008 | Bowflex Treadclimber TC5300
Bowflex treadclimber 5000
Hi ddmyatt.. They sell what is call dry lube at sports store's. for spraying under the tread's and on the wheels that the tread run's on.. Lift the tread and spray as far under it as you can on both side's. She'll be lot's quieter then before and lots easier on the motor too..
Nov 03, 2008 | Bowflex Treadclimber TC5300
Exercise & Fitness Logo
16 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
