I need to verify that i ordered buick lacrosse rear tail light assembly right side
  • 4 Answers
That is not what I paid for nor did I order it
Posted on Feb 19, 2014
I am trying to replace aleft rear turn signal bulb on a 2005 lacrosse. I removed two wing nuts but cannot remove assmbly. Is there another wing nut holding it in. I cannot find it?
3 wing nuts. here is the info needed.
gmlogoflat.gif Service Information
bhome.gifbpublication.gifbnumsrchbutton.gifbnews.gifymkbutton.giffeedback.gifbhelp.gif
2005 Buick LaCrosse ' Allure, LaCrosse VIN W Service Manual ' Body ' Lighting Systems ' Repair Instructions ' Document ID: 1537542 Tail Lamp, Turn Signal Lamp, High Mount Stop Lamp, License Lamp, Backup Lamp Replacement - Rear
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Turn Signal/Stop Lamp Assembly Replacement - Rear 1
Nut, Turn Signal/Tail Lamp (Qty: 3)
Tip
Pull back rear compartment carpet to gain access to lamp.
Tighten
2 N·m (18 lb in)
Lamp, Turn Signal/Tail Lamp
Tip
Twist the bulb socket and pull inward to replace the bulb.
License Lamp Replacement 3
Screws, License Lamp (Qty: 2)
Tighten
2 N·m (18 lb in)
Lamp, License Lamp
Tip
Jul 29, 2011 | Buick LaCrosse Cars & Trucks
HOW DO I CHANGE THE REAR BULB ON A 2006 BUICK LACROSSE
Asuming you mean taillight/turnsignal, and not highmounted brake light:
1.open the trunk
2.Remove 4 wingnuts on trunk trim (there are two on each side)
You can do it by only removing 2 on one side, but it makes a nicer job,
3.Pull back the trunk "trim" the carpeted cardboard
4.Remove 2 wingnuts which hold the taillight assembly in place
Pull out the taillight assembly; you might want to remove (i.e. unattach or unplug) the wiring harness
5.Turn the particular bulb's socket (there's 5 back there: 2 tail, 1 back up, 1 side marker, 1 brake/turn) counterclockwise, and it removes from the assembly, holding the bulb.
6. Pull out bulb and replace.
6. Reverse steps to reassemble.
Dec 30, 2010 | 2006 Buick LaCrosse
Replace headight assembly on 2005 buick lacrosse
The procedure to replace head light assembly on buick lacrosse is as follows:--- 1)To remove and replace the headlight assembly you will need to remove 1 retaining bolt on the top of the headlamp assembly and 2 sliding retainers at the rear. 2) The carefully Pull up the retainers and that will release the headlight assembly and allow you to pull it out the front. 3) When installing the new headlight assembly make sure you have it lined up correctly before trying to install the retainers, don't force them it may get cracked . 4) Both the cover and the bulb are removed by a standard twist to the counterclockwise and replaced by a twist to the clockwise. 5) Now to the dim light. You have to release the entire light assembly before you can remove the screw-on cover to reach the light. 6) On the rear edge of the light unit closest to the engine is a white locking tab. Pull that tab up just to the point where it releases…pull too far and it locks again. 7) Next, locate the other locking bracket which is a metal bracket in the center-rear of the light assembly. This bracket is held down by a screw. 8) Remove the screw with a 10mm wrench. Lift the bracket just like you did the white bracket. You should now be able to pull (or pry) the entire light unit forward a little. Depending on the size of your hands this might be enough. Note:-- The turn signal is part of the headlight assembly on your 2005 Buick LaCross. 9) To replace the headlight bulb you need to remove the front bumper cover. 10)To release the plastic bumper assembly to give you a little more space. This is done by removing two expansion locking pins, one that holds the little plastic strip down between the bright and dim lights and one that is located inside a rubber bumper on the engine side of the light unit. 11)To remove these locking pins, pull or pry up the little tab in the center of the pin. Thanks.
May 23, 2010 | 2005 Buick LaCrosse
How do you change a tail light in 2005 Buick
I have a 2002 lesabre and suspect it is the same. The light assemblies are bolted to the car from the inside of the trunk. Mine has three sections. Left side of trunk, across the back of the trunk and right side of the trunk. Open the trunk and look thru the small holes in the back for nuts that hold on the sections. They may require a deep socket to reach. Also not all the nuts need to be loosened. Trial and error. Once the nuts are removed the light assemble is freed from the car. Don't let it fall and scratch the car. The wires will help hold it in place. The light holders usually turn/twist and pull out. A little bit of a pain, but not too difficult. Again the deep sockets are probably required.
Apr 25, 2010 | 2005 Buick LaCrosse
How to replace left rear tail light?
I did the same thing on my 2005 Lacrosse. The owners manual shows you how to do this. You have to remove the entire assembly, unbolting it from inside the trunk and then pulling it out from outside the vehicle, standing by the back bumper. It's not like the "old days" when you just reached behind the assembly in the trunck and uncscrewed and replaced the bulb. Then you follw the same steps in reverse, obviously, to reassemble the unit.
The same applies for the front headlamps. I had to replace one and it is a bit trickier than the rear because of gently pulling away part of the front trim. I found the reassembly more difficult than the diasassembly.
Jan 04, 2010 | 2005 Buick LaCrosse
How to replace a 2003 Buick Century rear tail light assembly?
open the trunk and unscrew the plastic nuts on the back side of the light assy and replace
Oct 26, 2009 | 2003 Buick Century
How do I change the right brake light/stoplight?
In order to replace the light bulbs you will have to remove the entire rear light housing unit. In order to do this you must do the following:
  1. Pop the trunk.
  2. Loosen the trunk lining in order to reach the 4 nuts that are located on the right or left side and hold the light housing in place.
  3. You loosen the trunk lining fabric by removing two small, black plastic fasteners that anchor the trunk lining fabric. These either screw loose or you will need to pop off using a blunt- nosed pliers ( a flat head screwdriver works in a pinch) by first pulling the square bit out (towards the direction of the back seat,) followed by the circular components.
  4. Pull the fabric loose on either the left or right side to expose the 4 nuts holding the light assembly in place.
  5. Now, look for the four gold colored washer and nut assemblies surrounding the tail-light assembly. Find yourself a 7/16 socket and remove those bad boys. The tail-light itself should be able to pop- out, otherwise you've missed a washer- nut.
  6. Ease the tail- light assembly off of it's perch on the car and hold it red- side down. This will expose the wiring and "turn- locks" for the blinker and tail- light.
  7. Remove the bulbs from the assembly by turning the turn- locks in the direction (counter- clockwise) indicated by the plastic molding, and pulling upwards, off of the tail- light assembly.
  8. Pull the bulb from the turn- lock with a moderate tug of the hand.
Aug 04, 2009 | 1997 Mercury Sable
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
