Question about Miele T9822 Front Load Gas Dryer
Not heating Motor is working, dryer drum is turning, but no heat.
3 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Posted on Oct 14, 2007
heatman101
  • 43501 Answers
SOURCE: Brand new Miele T9000 Electric dryer. Dryer heats
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 23, 2010
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Dryer heats, but drum will not rotate.
try looking for a thermo fuse or check vent on roof ??
May 02, 2010 | Kenmore Elite HE4 Electric Dryer
CTD00 drum does not turn,heating OK,belt OK,motor OK
you have a bad motor,most likely.
Mar 03, 2010 | Dryers
Kenmore electric dryer 8662100 drum turns, no heat
you have probably lost one leg of your power supply feed 120volts+120volts=240volts,your motor will operate on 120volts, but the element won't,also if you have 240volts the neutral wire to the element can burn off w/heat and age
Aug 18, 2009 | Kenmore 84152 Electric Dryer
Dryer power problems
Yes, all dryers have a belt that turns the drum. Chances are the belt and heat problems are 2 separate issues.. The belt turns the drum from a motor mounted inside the unit, your electric dryer has a heater element/coils that heats the drum your clothes are in. The belt could be bad and heat element also but both at exactly the same time is rare. Try unplugging the unit for about 5minutes and see if it resets. My washer does that sometimes and I have to unplug
Aug 07, 2009 | Whirlpool WED6400S Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
Miele T9822 Front Load Gas Dryer Logo
41 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
