Question about Kensington 39336 KeyFolio Bluetooth Keyboard Case for iPad/iPad 2
Kensington keyfolio 39336 troubleshooting
My device doesnt seem to be charging - i also need a user guide
I have a samsung tablet and my kensington keyfolio pro 2 wirelee bluetooth keyboard... it connects to the tablet, is it supposed to?
Hi Lynnette,
Your Samsung Tablet will be on the same Router as the Kensington Keyfolio pro 2 wireless Bluetooth keyboard and would therefore expect it to connect to your Tablet.
Regards
Eric
Jan 07, 2017 | Samsung Computers & Internet
Numbers one two and three won't work on my Kensington keyfolio key pad
Kensington KeyFolio Pro 2 Removable Keyboard Case and Stand For iPad 4...
Can you uninstall it and reinstall it? Or install it for another tablet?
If you get same result and it's new, on warranty,Claim warranty If past warranty, ask how much should cost to repair it
Yo can get it in Amazon for 35 USD
Jun 07, 2015 | Kensington Computers & Internet
How do I connect my Kensington folio via Bluetooth to my iPad 2?
I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the 4th and 3rd Generation iPad's and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
May 05, 2014 | Kensington Folio Case Stand for iPad,...
Kensington KeyFolio 39336
It needs a battery change if it is flashing red.
Feb 16, 2014 | Kensington Computers & Internet
I lost the passkey to my Kensington Keyfolio Pro 2 Universal Bluetooth Keyboard. Is there still a way for me to connect?
Enter 5 digits on the laptop or tablet and press enter, then quickly enter the same on the KeyFolioTM Pro 2 Universal and press enter. Will sync up fine.
Aug 26, 2012 | Kensington KeyFolio Pro 2 Universal...
Keyboard is not working
if its a wireless mouse and keyboard make sure the batteries are securely seated and fully charged the battery panel should be on the underside of your mouse keyboard as would be the on off switch
click start control panel keyboard hardware make sure the right type of keyboard is selected
click start control panel keyboard hardware troubleshoot or click start control panel administration tools computer management device manager scroll to keyboard you could see a yellow question/exclamation mark ? ! or red X a new driver will need to be installed
right click to install drivers
http://download.cnet.com/bluetooth-driver-ver-5/3000-2110_4-149801.html
hope this help
Jun 03, 2012 | Kensington KeyFolio Bluetooth Keyboard and...
Kensington 39336 KeyFolio Bluetooth Keyboard Case for iPad/iPad 2 Logo
29 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
rey francis basa
rey francis basa
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
