Question about Kensington Computers & Internet
Kensington KeyFolio 39336
I got this second hand and the red charge light flashes but is it charging or does it need battery change?
    Problem Solver:
  • 19 Answers
It needs a battery change if it is flashing red.
Posted on Feb 17, 2014
SOURCE: dinovo edge keyboard
try flicking the orange power switch on the side of the keyboard while the keyboard is sitting on the charger
Posted on Sep 07, 2008
SOURCE: Not charging
Try to turn on the Keyboard.
There's a switch in the right side of the Keyboard.
For more information download the User Manual at Logitech Site
Posted on Nov 06, 2008
  • 6 Answers
SOURCE: Battery problem,...
I had this problem with mine so lets start by saying there are solutions!!
Solution 1:
Logitech state the battery cannot be replaced. It CAN. You can purchase the exact battery from ebay. Its a simple case of taking the orange backing off, removing all the screws (not forgetting the one hidden under the bluetooth address sticker) and popping the keyboard apart. From there, flip out the battery, pop in the new one, put it all back togeather and voila.
Solution 2:
Now if you dont care about your warrenty or it has none (as does mine) there are two contacts on the back of the keyboard which connect to the charger stand. Having took the keyboard apart, solder a wire onto each contact and then solder onto the battery connection contacts taking care to match red to red and black to black. Every time the keyboard is docked it will charge until you remove it. One other thing to note is that the low battery will keep flashing at you now and again (according to logitech you have about 10 mins use left until battery gives up) I have been using it for over 5 hours like this and its still going strong.
Enjoy.
Posted on Nov 06, 2009
  • 39 Answers
SOURCE: MX Laser Cordless mouse will not charge
yes you will find the baterys need changing (for rechargeble one's). the front of the mouce pops up when u flick the switch underneeth
Posted on Dec 01, 2009
  • 12 Answers
SOURCE: flashing red light on the Kensington wireless mouse base
My adapter says 5.6V DC 600mA tip is positive
Posted on Jan 26, 2010
Can you change batteries on a Logitech solar kb folio?
You won't be replacing batteries on Logitech's newest iPad keyboard case. As its name implies, the Solar Keyboard Folio uses light to maintain its battery life, which is two years on a complete charge, claims Logitech. Two small solar panels integrated into the Folio use either indoor or outdoor light to keep the Bluetooth keyboard juiced up.
Nov 18, 2014 | Tablets & eReaders
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
I bought a second battery (standby as I am going to Africa) for my Inspiron, charged it for about 10 hours until it indicated it is full. However, the power light has been flashing red since. Even when I...
Flashing red indicates that the battery is non-functioning (at the end of its ability to hold a charge), although as it is a new battery, this would seem a bit odd.
Did you buy the battery new or 2nd hand, was it a genuine Dell battery? My suspicions are that if this is an aftermarket battery and one which was not compatible with the dell, then there might have been some damage done to the laptop, causing the old battery not to charge. I'm assuming you are using a genuine Dell charger
Jun 21, 2012 | Dell Inspiron N5030 Notebook PC
Keyboard is not working
if its a wireless mouse and keyboard make sure the batteries are securely seated and fully charged the battery panel should be on the underside of your mouse keyboard as would be the on off switch
click start control panel keyboard hardware make sure the right type of keyboard is selected
click start control panel keyboard hardware troubleshoot or click start control panel administration tools computer management device manager scroll to keyboard you could see a yellow question/exclamation mark ? ! or red X a new driver will need to be installed
right click to install drivers
http://download.cnet.com/bluetooth-driver-ver-5/3000-2110_4-149801.html
hope this help
Jun 03, 2012 | Kensington KeyFolio Bluetooth Keyboard and...
Flashing red light on the Kensington wireless mouse base
I still have the manual for my mouse.  Model number 64321.
When this mouse was manufactured it used NiCad batteries which developed a memory much more than the newer batteries.  The older NiCad batteries needed to be conditioned occasionally so Kensington provided a way to do that with the charging base.
The red light is for indicating discharge status of NiCad batteries.
The red light will flash quickly when you press the battery discharge button on the bottom of the base.  This indicates that you now have 5 seconds to place the mouse in the charging base for battery discharge.
The red light will flash flash more slowly when the battery is being discharged.
After the battery is fully discharged, the base will then charge the batteries.
It should be noted that very few manufacturers of products that utilized NiCad batteries provided a "battery conditioning" feature.  Kensington was unique in this regard.  Battery conditioning allowed NiCad batteries to have a longer useful life.
Now maybe you can help me....  I lost my power supply that plugs into the USB connector.  If you have yours, can you tell me what the output voltage is and what the polarity is of the inner pin.  This will be marked right on the power supply base.
I plan to just get a generic power supply from Radio Shack, but I need the voltage value and polarity.  Until then, I can still use the mouse, but it won't charge.  FOr now, I'm just using standard AAA batteries.
Thanks.
bartman9@earthlink.net
Mar 17, 2009 | Kensington StudioMouse Wireless
Computers & Internet Logo
Top Kensington Computers & Internet Experts
Alun Cox
Pierre Legault
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
