Question about Stiebel Eltron DHC-E 10
Unit cuts off after 3 mins of heating water
Unit stops working after 3 minutes. trip switch trips. what are the possible factors causing this problem? all what are some of the solutions?
    Master:
  • 340 Answers
Sounds like the heating element in the unit is shorting out. If you are handy you may be able to replace the part but I would recommend having someone look at it who is familiar with this unit.
Posted on Feb 16, 2014
4 Suggested Answers
  • 409 Answers
SOURCE: water heater not working after turning up heat
Did you turn the breaker completely off, then back on? When a breaker trips it is in a middle position, and nust be turned off to reset it, then it can be turned back on.
Posted on Mar 17, 2010
rockitman187
  • 2559 Answers
SOURCE: no hot water. we noted the reset button is
The thermostat that you are resetting needs to be replaced.
Posted on Oct 02, 2010
blackmar
  • 235 Answers
SOURCE: The unit is no longer heating the water. The red
This will be a thermostat or element problem. The red light tells us that you have power to the unit. If you are handy you can test the thermostat and the element with a continuity tester. A voltmeter may also be used. This will tell you where the fault lies.
Posted on Mar 06, 2011
I have a power star ae115 electric tankless water heater. It has performed flawlessly for approximately 5 years. A couple weeks ago it stopped producing HOT water but is still heating to Luke warm. The "...
5 years is about the lifespan for tankless.
You might have shorted element. That would explain cooler water and tripping reset.
Test element: power is off, disconnect wires from element; ohms = voltage squared divided by watt rating of element
http://waterheatertimer.org/How-to-test-water-heater-element.html
Call service technician./ Call Bosch
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 14, 2014 | Water Heaters
How to take off the thermal couple off a ge sg40t12txk
1) Copy following links:
http://waterheatertimer.org/How-to-replace-thermocouple.html
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
2) GE is made by Rheem, so air intake screen is located below the combustion burner, as is the TRD (thermal reset device).
3) Modern gas water heaters, the FVIR, or FV system will trip when air intake gets clogged with dust.
This will slow venting of hot combustion gasses, except burner is still burning same amount of fuel. Overheating occurs, and that trips FV system.
Other brands require cleaning air intake screen and possible replacement of gas control valve, or FV sensor, etc. Each model is different.
Rheem_GE overheating will trip TRD, and glass vial breaks, causing air intake to close. Glass vial must be replaced, and possibly the gas control valve replaced.
Dec 18, 2012 | Rheem 36" Water Heater Thermocouple Kit
Bosch AE-9.5 keeps tripping the reset
All resets and breakers trip with high heat.
Do you mean the tankless unit is tripping the 40 amp circuit breaker?
Or the thermal cut-out, located on unit, is tripping?
Is this a new installation?
Or was the tankless working before and stop working?
Copy following link to check wiring.
AE 9.5 requires 40 amp breaker and 6 gauge wire.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
If the unit is tripping the thermal cut, -out, then product manual says to call Bosch or service technician.
Call Bosch 866-330-2729
http://waterheatertimer.org/pdf/Bosch-Powerstar-AE3.4-7.2-9.5.pdf
Thermal cut-out can trip if water flow is too low.
Try changing power selector screw from Hi to Lo so only 1 element is ON. See diagram page 6 of manual.
Adjust the 'outlet service valve:' The manual recommends that a ball valve be installed between hot outlet and faucet. Adjust the valve so more water flows to faucet.
Remove aerator, clean aerator, don't use low flow restrictions or low flow shower heads, replace leaky faucet cartridge on single-handle faucet.
Aug 29, 2012 | Bosch AE-9.5 PowerStar 1.5 GPM...
I have a powerstar ae115 water heater that is 3 years old. The thermal cutout onthe left side keeps tripping. after shutting off the shower the temp on the top of the unit is reaching 185*f. I have...
You've done the required first-step troubleshooting and maintenance.
If thermal cutout keeps tripping, and unit is actually reaching 185, then something is wrong with wiring, temperature sensor, gas valve, or PC board. Or combination of factors.
Call service technician, and open following link for some Bosch tankless resources including Bosch contact information:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Jun 26, 2011 | Bosch PowerStar AE115 Tankless Water...
Hi, is not working, the machin is turn on but we don't have hot water
Possible causes and solutions:
  1. Safety Thermal Cut-Out Tripped, Reset.
  2. Not enough flow rate to activate unit, clean filter screen at unit, clean aerator at faucet.
I hope this has helped. Please rate the answer as to it's helpfulness. Good Luck and have a great weekend. Jeff
Apr 04, 2010 | RTO American Heat Tankless Electric Water...
What is service code 1 for a grohe wireless shower
I had the same Service Code 01. The solution is simple. Switch off the power for the shower for a minute or so usually located outside of the bathroom. Switch it back on and you should hear the unit (if it's close by) resetting itself. Switch on the shower and it will tell you to wait, then with a bit of luck it should wizz into action.
Jan 04, 2010 | Grohe Grohtherm Thermostatic Rough-In...
(electric 240v 50 gal.,3 yr old)breaker on unit(not elec service panel) trips every afternoon-not apparantly under load
there may be a short in the heating element causing it to trip, or the breaker itself need to be replaced.
Dec 03, 2009 | Reliance Water Heaters
Water heater trip circuit breaker
I would say you have a bad element in the bottom.If the water is cold and heat until the top thermostat reach it tempture,then switch the bottom element and then the breaker trip.So replace the bottom element.
Mar 09, 2009 | Rheem 81VP6S/430126 Water Heater
Over riding switch
You could have a defective thermostat causing the limit control to trip off. Here is the manual!
http://www.insinkerator.com/pdf/POU_ICU.pdf
Copy and paste to your address bar.
Jan 20, 2009 | Emerson InSinkErator W-152 Electric...
Stiebel Eltron DHC-E 10 Logo
232 people viewed this question
Top Stiebel Eltron Water Heaters Experts
chargerhp
chargerhp
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
