Question about Fagor Dishwashers
Overheating water overheating
Overheating 97 Lincon Town car
Connie, Were the radiator,water pump and thermostat replaced to try and fix the over heat issue or as maintenance. Engine overheating can be caused by a lot of things, Leak in cooling system, air in system, bad rad. cap, slipping belt, faulty thermostat or installed upside down, faulty water pump, plugged radiator (inside/outside), collapsing rad hose, faulty cooling fan, leaking head gasket, sludge plugging engine water passages, poorly tuned engine, etc..
Take into a good shop for diagnoses and estimate for repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Troubleshoot an Overheating Engine
Steve Litt Overheating Guide
Diagnose Engine Overheating Auto Repair Help
How to Troubleshoot an Overheating Engine DoItYourself com
Jul 21, 2016 | Cars & Trucks
Overheating engine
how is the oil level of the engine ?
Also could be a faulty thermostat in the cooling system .
May 20, 2015 | 2004 Kia Rio
How to replace head gaskets
What engine? Has thermostat been changed? You say it has not overheated since, but water not circulating. If water/coolant wasn't circulating, it would be overheating. Please explain a little more or confirm why you think that.
Feb 25, 2014 | 1998 Dodge Ram 1500 4WD
Water overheating by water bottle
most likely a cracked head.
Feb 15, 2012 | Cars & Trucks
I am getting an engine system failure light coming out on my 2005 ford focus. The first day I checked oil and water. The oil was slightly low and I topped up. The water appeared to be overheating and I...
Sounds to me like you are having a cooling system problem, if water is boiling in the tank or radiator then the engine is overheating. If you have not flushed the cooling system, it would be a good idea to do so. Also you need to test the cooling system at idle and see if the engine will maintain normal temperature, without overheating. Overheating can be caused by plugged or restricted radiator, hoses, or the thermostat, also check the operation of the electric cooling fan. Once you solve the overheating you light should stay off. If you do not solve the overheating soon, the engine will suffer major damage, so check it out very soon. Hope this helps, let me know.
Aug 04, 2010 | 2000 Ford Focus
I got a new water pump and my car is overheating
You need to read this article. It seems like there could be a blown head gasket on your BMW.
Anyways.. > how to diagnose an overheating engine.
Apr 17, 2010 | 1999 BMW 323 Series
Overheating and water in the exaust
sounds like head gaskets or a cracked head check oil for water
Jan 03, 2010 | 1993 Chevrolet S-10 Blazer
Changed thermostate still overheating
what about the water pump? is the water circulating
is the electric fan working? check all these things outlook in the radiator see if the water is circulating feel the top hose is it cold or hot when the engine is runing
Jan 01, 2009 | 2002 Pontiac Grand Prix
Overheating and now engine 'clicking noises.
possible causes of overheating are, dirty cooling system, clogged radiator, bad thermostat. Use only distilled water with a good quality coolant.
still overheating? have your top head checked - warped head, valves, valve seats, etc. You might need to have your engine's compression checked if it is still within specs.
Sep 24, 2008 | 1995 Jeep Cherokee
Dishwashers Logo
21 people viewed this question
Top Fagor Dishwashers Experts
dannydoesita
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
