Question about Kalorik Sunny Morning Lime Stick Mixer-MS18676L
Washing Lower Portion Allowed?
Can't find the manual. Wife brought it to me nearly frozen, was able to loosen it up by pouring small portion of canola oil down the shaft. I suspect from the construction that this removable part is supposed to be able to go in the dishwasher or water in the sink to prevent this problem in the future. Does anyone have the manual so they can tell me for sure? Thanks.
    New Friend:
    Problem Solver:
  • 7 Answers
I have a stick blender... not the same make, but I put the removable stem in the dishwasher without consequence.
Posted on Feb 16, 2014
How do you eject the beaters on a hand mixer
Very Carefully! Generally, depending on the make and model there are two small ejection buttons near the beaters portion. Press HARD to make the inside locks disengage the beaters and they will fall out.
Feb 07, 2018 | Food Mixers
Kitchenaid stand mixer motor head fell off
You didn't say which model KitchenAid mixer you have. Assuming that it is a tilt-head, and that the metal portion of the motor housing joining it to the base did not break, the Service Manual can be had at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Apr 16, 2017 | KitchenAid Food Mixers
How do I kill white fly and Aphid on my Fuschia
Ingredients:
  • 1/2 cup vegetable oil
  • 1/2 tbsp liquid dish washing soap
Directions:
  1. Mix ingredients well in a lidded glass jar.
  2. Add 1 1/2 teaspoons of the solution per each cup of water in the spray bottle and store remaining solution in the jar in the refrigerator.
  3. Soak spray the infested plants and surrounding soil.
  4. Repeat the rinsing and spraying for two more days and then use the solution thereafter once a week.
  5. Do not spray when direct sun is on the plants because the combination of the sun rays and solution will burn the leaves.
Jan 13, 2015 | Food Mixers
Dough hook stuck immediately after use
I just got my dough hook unstuck! The problem was the bolt at the top of the dough hook. This bolt is used to adjust the height of the dough hook. This bolt came loose while mixing and went up towards the mixer. The force of the spinning actually tightened this bolt against the mixer so when I tried to release the dough hook by lifting and turning, it wouldn't lift. The bolt was in the way! The solution is to loosen this bolt. You'll need a thin wrench that's about 15 mm. You can test loosening this bolt on the other attachments since they loosen in the same manner. You'll have to bend the white shield down slightly to get the wrench in there. It's a tight squeeze even with a thin wrench. Hold on to the lower end of the dough hook and turn the wrench counterclockwise when looking down at it. Once you loosen the bolt, you'll be able to turn the lower portion of the dough hook to lower it. Then you can lower the bolt further. Once you have them low enough, you can remove the dough hook like normal - lift and turn. Sure beats boxing it up, shipping it for repair and paying for shipping both ways!
May 03, 2010 | Cuisinart SM-55 Stand Mixer
Mixer blade keeps loosing the coating
See pg. 13 of the owners manual for bowl height adjustment procedure:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209707917.pdf
clockwise to lower the head and counterclockwise to raise the head for more clearance for the beaters.
Apr 11, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
My DeLonghi DSM800 when running sometimes stop for a second and then starts up again. It also seems to speed up at times and almost sounds like it is skipping a gear or something. Any ideas.
I had the same problem and fixed it.
  1. I took it apart, unplug unit, remove the small black cover inside the stand portion, 1 screw. Underneath you will find four screws with a white plastic wire junction.
  2. Loosen two screws and remove the black and brown wires which connect to the control panel with the dial attached.
  3. Remove rear attachment cover, front top cover, and front delonghi cover.
  4. Remove top three screws where the blender attachment goes. Now remove the aluminum cover that covers the entire top.
  5. Slip belt off. Remove three screws with plastic washers that attach motor to chassis.
  6. Remove 2 torx screws that are located next to metal bar that keeps top half from swinging too far from bottom half.
  7. Now you can pull the motor out and the control panel with the dial. Remove the three slip on electrical connections on the control panel and reinstall. Carefully remove the two slip on electrical connections on the motor and reinstall.
  8. Re-assemble and test unit.
I thought I had a problem with the control panel or the motor, as it turns out the connections were the problem. Carefully removing them and reinstalling them solved the problem.
Jan 03, 2010 | DeLonghi 800 Watts Cucina DSM800 Stand...
Runs fast for a few seconds , then runs very slow
Jan 06, 2009 | DeLonghi DSM7 Stand Mixer
Mixer has just stopped
On the newer A200s, there is a reed switch behind the solid portion of the bowl gaurd. On the cage portion there is a magnet embedded in a plastic holder. Without it, the mixer won't run.
Hobart part # 438525
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
Apr 04, 2008 | Hobart A200 Stand Mixer
Kalorik Sunny Morning Lime Stick Mixer-MS18676L Logo
Top Kalorik Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Kalorik Food Mixer Expert? Answer questions, earn points and help others
