Question about Olevia LT32HVE 32 in. LCD Television
Caption will not turn off?
Olevia Firmware updating is recommended by tech.  Does anyone know about this problem?
Re: Caption will not turn off? - Olevia LT32HVE 32 in. LCD Television Flat Panel Televisions
Cc button on remote
Posted on Mar 01, 2008
0 characters
3 Points
I have an Olevia 537H TV from 2007. I would like to download the latest firmware for the unit in hopes it will correct my audio issue on NBC only whereby the music drowns out the people speaking. All other...
Before updating the firmware, you should know about the version of the firmware now running with your TV. Without knowing it, and updating the firmware; might cause the set to get irresponsive to any external commands. So beware before updating. After make sure about the firmware now running, check the site linked here to get latest firmware update to your TV. It will be best to contact any service technician in this case, I suggests.
Electro help
Olevia Driver Firmware Manual
Jun 06, 2014 | Flat Panel Televisions
Olevia TV Model 237-S12 P/N FM1-037000EGS29 S/N
Good day!!!
Usually that problem is appear after the firmware update failure or not completed,..
I need to know if your TV having sounds?
Did already update the firmware?if that so where did you find the firmware?..
Jan 08, 2012 | Olevia Flat Panel Televisions
I have a olevia 232-t11 and it is in need of a firmware update. The tv turns on but screen stays black. If anyone knows where I can get the firmware please let me know. I also have a toshiba regza 32"...
Olevia went out of business a long time ago.
First, the screen is black can be due to the 24vdc power supply is dead or in shutdown due to short circuits in the backlight inverter board. You need to inpsect the caps and voltages.
Screen: not likely beacuse of the backlight inverter board and the T-CON board will not be the same.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Capacitors kit: he can make a kit for you.
Aug 13, 2010 | Flat Panel Televisions
Is there any place to download the firmware for the olevia 237T
here download this to a blank flash drive
Jun 24, 2010 | Olevia 237T 37 in. LCD TV
Olevia 232-S12 bad flash
Where did you get the firmware from? Can you provide a copy? I bought this TV when it came out and never upgraded the fw, now I can't find a copy anywhere.
Oct 09, 2009 | Syntax 232V Television
How to remove closed captioning
you can either turn it off in the TVs main menu or check for a CC button on your remote.
Feb 02, 2009 | Olevia LT32HVM 32 in. LCD Television
Firmware update Failed
I had the same problem with my olevia 242-T11. I flashed it with the wrong firmware and the TV would not even turn on. The blue LED light would still light up and my PC would still recognize a connection when i hooked it up to the USB cable connected to the TV.
I was fortunate to download the appropriate software. The software is called MTK_DownLoad1.exe. I know this is the correct software to use for Olevia 242-T11 and Olevia 237T. I do not know if this will work with other models.
Here is the link to the MTK_DownLoad1.exe
You will also need to install the USB to Serial driver before you are able to use the MTK Download Utility. The USB Driver is located at
BE SURE ONLY TO UPDATE YOUR TV WITH THE CORRECT SOFTWARE OR YOU WILL BRICK IT. I was lucky enough to recover my TV and finally able to upgrade it to the correct firmware but my TV was non functional for about a week and this has been a huge headache and if i could go back in time i would definitely not do it so please ask yourself if its even worth it risking upgrading the firmware of a TV who parent company is reorganizing after declaring bankruptcy.
If you still want to do this, here are the firmwares for all the various Olevia models.
I hope this helps all the people who need to recover / unbrick their Olevia TV's. If the links are down or you need any help please ask for help in avsforums. My id is sammykismail on avsforums and i will try my best to help you.
Jun 23, 2008 | Olevia LT42HVi 42 in. LCD Television
Broken tv
I had problems with channels on my Olevia LCD TV. My problem was solved by updating to the latest firmware.
Make sure the USB flash drive is formatted with the right file system, or the set will not see the updated firmware.
Mar 30, 2008 | Olevia LT26HVX 26 in. LCD Television
Olevia LT32HVE 32 in. LCD Television Logo
48 people viewed this question
Top Olevia Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you an Olevia Flat Panel Television Expert? Answer questions, earn points and help others
