Question about Sakar The Voice I Want You CD G Karaoke with Microphone
I have my cdg but my lyrics still will not come up
I know it works because it has before. It all of a sudden doesn't and I know it' s probably the karaoke machine, because I did everything that I could with the cdg but I cannot seem to fix the machine.
How do I get the lyrics to play on the screen using the karaoke anywhere app? I hear the music but there's no lyrics
The Karaoke Anywhere app will play standard MP3+G zip files. These contain two files. One must be an mp3 file and the other must be the accompanying cdg file. The zip file cannot contain any other files or folders.
It seems from what you describe, the file you are attempting to play through Karaoke Anywhere is an MP3 file but that it either does not have a proper CDG file, or the MP3+G zip file is not in the proper format.
Sep 01, 2014 | Sakar The Voice I Want You CD G Karaoke...
Read error
Your reader is probably going bad. You can try cleaning it with one of those home CD player cleaner kits and that might work for you.
Aug 23, 2014 | Akai Karaoke Akai KS808 CDG Karaoke System...
Karaoke machine
Have you turned off the subtitles on the TV ?
Oct 18, 2013 | Audio Players & Recorders
HOW DO I UNLOCK MY LG MT375 CELL PHONE
GSMUnlocking.eu provides safest and easiest non-invasive way to unlock LG MT375 Lyric phone remotely. Both methods, with original USB cable or using generated code based on your phone's IMEI serial number will unlock your phone in no time. On you will find everything that is needed to unlock LG MT375 Lyric. Just place order and your phone will receive instructions regarding unlocking your phone remotelyServices we provide for LG MT375 Lyric are 100% safe. We're unlocking LG MT375 Lyric same way as manufacturer or carrier would do it so it has no negative effect on your device performance.For some new devices like LG MT375 Lyric you probably could try to unlock it using third party patched software or so but such methods may lead to disabling your phone and/or loosing your warranty. You may also find sites with free unlock code generators but in most cases those codes are for old devices and doesn't work correctly for newer devices. Such invalid codes may disable unlock by code methods. In such case unlocking your phone will require manual servicing (which is more expensive) or may even lock your phone permanently.Unlock time for LG MT375 Lyric varies from 0d to 3d, but usually takes 0d
Feb 16, 2012 | LG Cell Phones
I want to burn a karaeoke disc
The problem isn't the burner. You need karaoke software to burn and view cdg files. Below is a link to free karaoke software. Install the software (or a software package of your choosing) and re-burn your files.
Karaoke Builder
Dec 27, 2011 | LG GSA-H22N DVD±RW Dual Layer Burner
KARAOKE MACHINE PLAYS SOUND BUT NOT WORDS
I assume you know that you MUST use special Karaoke disks to have lyrics displayed... Ordinary music CD's do not have that data on them.
Jan 25, 2011 | American Audio Cdg-350 Professional Dual...
Daughter received a GPX JM250S Karaoke Party Machine for Christmas and can not get the lyrics to display. I have a CD-G and it is on that setting, but no lyrics.
From the FAQ for this unit:
Make sure that you are in either CDG or AUX mode and then adjust the BRIGHT, CONTRAST, AND V-HOLD knobs, on the back of the unit, if needed
Dec 31, 2010 | Digital Products International Karaoke...
Sakar The Voice I Want You CD G Karaoke with Microphone Logo
61 people viewed this question
Top Sakar Audio Players & Recorders Experts
Robert
Carlos L. Burgos
Carlos L. Burgos
Joseph Hoffmann
Are you a Sakar Audio Player and Recorder Expert? Answer questions, earn points and help others
