Question about ViewSonic PJD6241 3D DLP Projector
LAMP AND HEAT LIGHT ON - ViewSonic PJD6241 3D DLP Projector
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
You need to reset the lamp timer
the manual will tell you how to do it
I am glad to send the user manual to you ,if you need
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Posted on Feb 22, 2014
How do I fix 62HM15 picture. Have sound-No Picture. Have red light steady and Green light blinks 8 times and cuts off and back on.
Usually 8 flashes means the lamp is not lighting.
When most lamps go bad , they physically crack because of excess heat.
The problem is probably the lamp or the ballast, which makes the voltage to light the lamp.
Replace lamp and remember to close the lamp access door after replacing, because the lamp will not light if the door is open an
Jan 23, 2015 | Toshiba 62HM15 62" Television
WHAT DOES A COOLANT SENSOR LIGHT COST?
98 olds?
a bad lamp is a dead lamp , not stuck on.
so your input is false.
no the lamp does nothing at all but REPORT over heated.
please say the exact name of lamp, on the cluster.
and ask why it is stuck on.
the operators guide, says what, get it serviced.
diy persons, know it either telling the truth or fibbing
we use a meter to check engine heat if it is ok the lamp fibbing
the lamp fibs when the overheat sensor is bad
or the wire to it falls off and hits the body metal.
Jun 12, 2014 | 1998 Oldsmobile Intrigue
Flashing red light for lamp
There could be several causes for this. Does the cooling fan come on, it may be defective. There could be something blocking the heat sensor. Is it possible the connector didn't get fully attached when you installed the new lamp?
Apr 15, 2014 | Hitachi Gst CP-X2020 Hitachi Hitachi Xga...
My tornado lava lamp doesn't work. A little plastic piece just bounces around on the bottom.
It's difficult to say based on your limited description. A lava lamp is a first of all, a lamp. Does the incandescent lamp light up? If not, replace it (it's the heat source which creates the swirling action in the attached "lava" globe). As for the plastic piece, perhaps it's part of the lamp-holder socket that broke off due to heat. Perhaps part of the switch.
In any case, the light light bulb probably burnt out. Believe it a standard 40 watt bulb, but be absolutely certain to check before replacing as you do not want to put a bulb with a higher wattage in there due to the confined space inside the lamp.
Apr 13, 2014 | Novelty Lava Desk Lamp
How to do energy saver dimming ?
Most modern dimmers provide normal energy savings. They reduce the total amount of watts consumed on the circuit. Many years ago, dimmers only reduced the watts consumed as light - making up the difference as heat in the dimmer switch. A 100W light turned down to 1/2 wattage at a dimmer switch resulted in 50 watts of light at the bulb, but 50 watts of heat was created in the switch. That was zero energy savings. The newer electronic dimmers will still let 50 watts be used as light, but only a few watts as heat in the switch.
To maximized energy savings, use of new cold cathode technology lights such as CFL (compact fluorescent lamp), LED (Light Emitting Diode), etc. types are suggested. You can use these lamps on a dimmer to furrther reduce the amount of energy used - but only if the lamp indicates that it is dimmable.
If the lamp or fixture does not specifically state it can be used on a dimmer, don't. This includes powering a light through a dimmer that is set to maximum brightness. Use a standard non-dimming switch instead.
I hope this helps & good luck!
Apr 14, 2012 | Electrical Supplies
Picture doesnt come on lamp and heat light
Need more info on the TV like the model #
Mar 04, 2010 | Televison & Video
Red temp and lamp light flashing
you may need to replace the lamp in the unit, to do so, remove the lamp and if it sounds like a rattle inside when you shake it, its blown due to heat ,hence the red temp and lamp warning. after replacing the lamp make sure you reset the lamp use hours. good luck.
Sep 26, 2009 | JVC HD-56FB97 HDTV
Dell 2400 MP projector lamp problem
could be a heat, fan - sensor issue or a power supply issue. Regards Kevin Andreassend http://www.iceav.co.nz iceavtech@gmail.com
Feb 03, 2009 | Dell 2300MP Multimedia Projector
1994 Jeep cherokee am/fm radio backlight lamp is out and AC/Heat dash lamp is out
There is a tiny little peanut shaped light bulb inside the radio that provides the light for the dial, it is replaceable, you will need to remove the radio, then pull the top cover off the radio chassis, the bulb is under the cover.
Nov 07, 2008 | 1994 Jeep Grand Cherokee
Mitsubishi rear projection tv color problem
I'm going to guess that this unit is a DLP projection set and that the lamp is not new. Try a new lamp. The heat of the lamp will char over time. If not the lamp, some of the internal filters in the light engine might be getting effected by heat and require replacement.
Keep us posted.
Dan
Sep 12, 2008 | Mitsubishi Televison & Video
ViewSonic PJD6241 3D DLP Projector Logo
49 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
