Question about Bear Archery Fred Bear Whitetail Hunter Bows
What does a stabilizer do on a bow - Bear Archery Fred Bear Whitetail Hunter Bows
Assembly for pse stalker bow
you need a bow stringer for a recurve bow. $15.00 cabelas
Oct 26, 2012 | Puget Sound Energy PSE Stalker Recurve Bow
How many different types of bows are there?
There are seven main types of bows. Recurve bow, compound bow, self-bow, Composite bow, backed bow, longbow and a spine bow.
Aug 26, 2012 | Betsey Johnson Archery
What do the stabilizers on a bow do?
Professional archers use stabilizers to assist with aiming. Stabilisers increase the overall weight of the bow, but improve the accuracy of aiming at long distances.
What's a Reflex bow?
A Reflex bow is a unique bow that has curved arms that turn away from the archer. The curves put the materials of the bow under greater pressure, allowing a fairly short bow to have a high draw weight and a long draw length. I personally own a Reflex bow of my own an had lots of other bows and for me it's the most powerful bow I've ever used, so you defiantly try this bow out.
Jul 30, 2012 | Archery
What are the different types of bows?
Mainly there are 7 different types of bows, the Recurve bow, the Reflex bow, the self-bow, the Straight bow, the Longbow, the Composite bow, and the Compound bow.
Where can I buy a solid bow?
I'vepurchased my bow through http://www.bowsports.com/ it's an online bow equipment sitethat has many different bows an bow accessories, fast delivery and a prettygood customer service, you can find bows from 100 dollars to 4000 dollars all dependson your own need and the money you want to invest on your bow.
What's the best bow for beginners?
You can findlots quality bows in different prices, but the best bow I advise you to get,the bow I actually purchased myself, is the Parker Sidekick. This bow isdesigned for beginner archers as it comes in 18- to 28-inches of draw lengthadjustable at 0.5 inch increments. Draw weights are available from 20- to40-pounds and 40- to 60-pounds with a comfortable 80 percent let-off.
Toshiba 51HX93, rear projection T.V. Green convergence problem
You will need to change both of the Convergence IC's----if you go to the trouble to just change one the other will fail in a short time---what happens most of the time is the white heat sink grease that was applied to the back of the two chips has dried out and one gets too hot and fails.
Most of these sets use 2 STK-392-110; WITH THE BACK OFF use a flashlight and you should be able to see the number on them; they are located on identical metal heat sinks with fins.
If this has been helpful I would appreciate a vote from you here. If you require more assistance respond to this post and I will help.
Aug 17, 2009 | Televison & Video
Bear Archery Fred Bear Whitetail Hunter Bows Logo
107 people viewed this question
Top Bear Archery Archery Experts
Tom Chichester
Are you a Bear Archery Archery Expert? Answer questions, earn points and help others
