Question about Sharp AQUOS LC-60LE820UN 60 inch LED HDTV
How do i factory reset sharp aquos lc-60le820un 60inch led hdtv without the remote
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
SOURCE: Programming the Acquos Remote
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
Posted on Oct 21, 2008
SOURCE: sharp remote control not working
Ok, looks like this TV works on MS Windows. Anyone who has had a computer 5 years back knows that when Windows has a problem, there is only one sure-shot solution.
SHUT IT DOWN, START IT UP !
Try this with your TV. Completely unplug it and leave for one minute. Start again. Voila ! Remote works flawlessly.
Posted on Sep 21, 2009
SOURCE: how to reset sharp aquos lc-32l400m?thanx before
Sharp Aquos LC-32L450M - i have recently baught this LCD, but I think the 'mpx' ie the multiplex sound is not working. there is this 'mpx' button on the remote, but wen i press it nothing really happens. in the manual its only written in one line "mpx- multiplex sound" . please any one can help me ..I m really not happy wit the sound right now. paid so much & no good sound its bit irritating please any one help.. wats the problem
Posted on Apr 11, 2011
SOURCE: Sharp Aquos LC-52D64U Won't Turn On
I have fixed many sharp lcd tv's with a reset. If one appears to have no defects like bad capacitors, fried inverters, broken panel, ect. and the power light is flashing steady or not on at all a reset may help. There is a lot of bad information regarding the procedure though. The correct procedure is to unplug the tv, hold volume down and channel up at the same time and plug it in. Release those buttons then push the power button. Did it start? Great! I have no idea why so many seem to need this. If there truly is a problem this will only work temporarily or even momentarily but many will be fixed for good.
Posted on Mar 27, 2012
1 short 1 long blink on sharp aquos LC-60LE820UN
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 24, 2016 | Sharp AQUOS LC-60LE820UN 60 inch LED HDTV
Hi I have a Sharp aquos tv that won't turn but does weird things. is there an easy diy way to fix this.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 17, 2015 | Sharp AQUOS LC-60LE820UN 60 inch LED HDTV
How to reset a sharp aquos lc4d62u without a remote
You can use the 'menu' button on the panel (next to power on my model) to bring up the 'Initial Setup' screen. The factory reset option is available from that menu. You'll need to navigate through the menus using the channel up down buttons and the enter button on the front of the TV.
Oct 14, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Sharp aquos won't resond to remote
Replaced Battery of remote.keep your mobile camera ON and press any from remote.If you get flash light in camera that means your remote is ok. Checked & Replaced LED TV sensor pcb.
Jul 26, 2014 | Sharp LC-60LE820UN AQUOS 60 In. 1080p LED...
How to reset a sharp aquos?
Hold VOLUME UP and CHANNEL UP buttons in while plugging set into power.
TV comes up in service mode.
Press CHAN + or CHAN - to select an adjustment that you want to change
Press VOL+ or VOL- to adjust
Jul 22, 2014 | Sharp AQUOS 65" 1080P Roku Ready LED 120Hz...
Factory reset
Here's a link to the manual, the reset instructions are on page 35:
files.sharpusa.com/.../LCDTVs/Manuals/tel_dow_LC80LE632U.pdf
Apr 18, 2014 | Sharp AQUOS LC-80LE632U 80" Class Full HD...
The light in the middle bottom of screen is blinking with no picture
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 29, 2014 | Sharp AQUOS LC-60LE820UN 60 inch LED HDTV
Slow wireless connection
Make sure you have a n series wireless router. Also wireless routers especially g, n series, or 2.4-4.8 are line of site frequencies. That means you will get better reception if your wireless device is in the same room as your router.
Jan 27, 2014 | Sharp AQUOS LC-60LE820UN 60 inch LED HDTV
Sharp AQUOS LC-60LE820UN 60 inch LED HDTV Logo
54 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
