Question about Alesis Monitor One Mk2 Speaker
Left speaker LED flashing, woofer and tweeter clicking...
Everything was working fine last night, I wake up this morning and (only) the left speaker is on the fritz.  The LED is blinking about 6 times a second, and the speaker itself is making some sort of clicking noise that corresponds with the flashing of the LED.
I'm assuming this is some kind of power issue based on my limited knowledge...
  • 2 more comments
  • raeshao Nov 20, 2007
    The same thing happened to one of my Alesis M1 MKIIs today (the right one).  Did you happen to find a solution?
  • Anonymous Dec 11, 2007
    i have the same problem, it started like 2 monnts from now. At first the left didn't wanted to start , but after a 10 minute power off it started. Now the light is blinking and if i put a loud signal the sound is disappearing.
  • Anonymous May 07, 2009
    Given that these monitors seem to fail the same way, one would think that Alesis would have the wisdom to make a replacement board available that is PROPERLY designed.
    This is the third time mine fails. The first two times I had the board changed. Now I am going to try fixing it myself. I tried to contact Alesis, but they have never responded. Pretty sucky customer experience.
  • Phoeno May 11, 2010
    Hi All,
    I'm not able to find the exact capacitor match, was wondereing if a 25v 470uf (80deg) capacitor would work as a replacement?
    Cheers
    Phoeno
The flashing blue LED and loss of sound on the Alesis M1 powered monitor is caused by failure of capacitor C8 (220uF, 35V) on the power supply board. It dries up due to its proximity to resistor R4 (47K, 2 W) which gets very hot. This is a design fault.
Remove the power supply board (4 corner screws and 2 mains connector screws) and disconnect the two plugs. Carefully desolder C8 and replace it. Its value is not critical (220 to 470 uF will do) but it should be a 105 deg. type, preferably at 50V.
Remove R4 and replace it with a similar resistor with its leads bent so that it is nowhere near C8, otherwise the fault will return. One end may be connected to one of the existing R4 solder pads (furthest from rear of board), and the other to the top end of resistor R3. Check that you have connected it correctly by inspecting the PCB tracks.
Replace the board and all screws and plugs before testing.
Posted on Jan 01, 2008
Hi there, this is a response to Unheard's comment:
"Carefully desolder C8 and replace it. Its value is not critical (220 to 470 uF will do) but it should be a 105 deg. type, preferably at 50V. "
Does anyone know where I can find a part (online) which matches this spec, as I have the exact same problem?
Posted on Oct 20, 2009
C8 was the problem with mine! Thanks for the fix! I didn't put all screws back in the cover until I made sure it worked. FYI the blue/white wires go to the tweeter, I case you don't write it down.
Posted on Jul 17, 2009
    Problem Solver:
  • 4 Answers
Mines got the same problem..i now leave it on all the time,but if it happens to go off the light starts so i switch it off for 20mins with a fan blowing on the back of it and its fine to switch on again
Posted on Nov 27, 2008
I have this exact same problem with my Alesis M1 Active MkII monitor (left)... www.digikey.com appears to have capacitors of the appropriate specs.
I am considering setting up the replacement C8 capacitor with a thin piece of silicon insulation (similar to the silicon used in food baking mats) to place inbetween the replacement C8 capacitor and R4. Does anyone suppose this will work to insulate it properly? I should know for sure in a week or so when the parts arrive.
Posted on Sep 28, 2008
What can cause a sub woofer and room speaker woofer to stop
Check wiring for loose connection...may have to open speaker enclosure.
Jan 04, 2016 | Velodyne CHT-8 Subwoofer
Mission m73 with a woofer which seems to have gone dead
I use to have some warfdales that did that, and generally it was the cross over unit that would blow a fuse, if fitted.
Dec 26, 2013 | Audio Players & Recorders
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
My klipsch sw112 sub stop working and know when i turn it on it just makes a clicking sound the led light flashes on and off
The sub amplifier circuit is probably damaged and the protection circuit takes over. Have a qualified electronics technician take a look at it.
Oct 13, 2012 | Klipsch SW-112 Speaker
Altec lansing vs4121 speaker boom sound
you may have blown out the speaker or there is a miscommunication between the laptop and the woofer
Jun 15, 2012 | Altec Lansing VS4121 Speaker
Mackie SRM 450, the main speaker has stopped working but the tweeter is OK, there is nothing coming from the speaker at all, no hiss, or clicks.
It could be 2 things:
*Blown Speaker or,
*Fried power amp output stage of woofer, since this speaker operates as a bi-amplified system it has separate amps for woofer/tweeter...
Aug 17, 2011 | Mackie SRM-450 System
The woofer on one of my speakers stopped working. The tweeter seems fine. My DMM shows that the resistance across the 2 internal leads that connect to the woofer continuously cycles from 0 through...
The voice coil is open, you can look real close at the spider wires that are soldered from the two terminals to the cone to see if they are bad, otherwise you will need new woofer, you can try getting the woofer from partsexpress.com
Feb 14, 2010 | Boston Acoustics Micro90X Speaker
Sub has died overnight
Change the fuse - located at the 220V input. Use a knife ti release it. Then the system will work again.
Oct 08, 2008 | Creative Labs Gigaworks S750 Computer...
Alesis Monitor One Mk2 Speaker Logo
1,261 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
gggg
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
