Question about Sampo Televison & Video
Sampo pme42v6 dvi and vga input locked...pls help
Sampo plasma has input lock on these inputs and does not see them in the menu.....please help
SOURCE: Connecting an LCD TV to a computer to use as TV and Comp. Monitor.
Im no expert on the subject, but I use my L37 for a monitor, and use just the vga adapter. It works good as a monitor, and both dvds and my hdtv wonder tuner card look great through the vga connection. They do make adapters for dvi to hdmi. Although, hdmi also carries sound, but you wont get that out of your dvi output from your card. So you might not have sound when using that connection, as your tv may not look to the headphone type jack used for sound imput from your computer when you select the hdmi source on it. If you have speakers already connected to your computer you may not care. Also if you have a 720 p Vizio, 1366x768 is the highest resolution you are going to get out of it anyway, if I'm not mistaken. I'm Not sure why you would need 2 connectios to the same monitor either. I posted 1 link below because they had several dvi to hdmi adapters. Hope that helps.
http://www.bizrate.com/computercables_adapters/products__keyword--hdmi+dvi+d+dual+link.html
Posted on Aug 01, 2008
  • 12 Answers
SOURCE: Connecting laptop to LG Plasma via vga cable
you should have a button that you have to press to get it to switch over, on mine i have to press and hold the Fn key then press the F4 key might not be the same on yours but you should have a f something key that has what looks like a little screen on it that is to switch the output if that does not work try hooking up your laptop just like before, and then restart it. good luck
Posted on Sep 30, 2008
doin12volt
  • 233 Answers
SOURCE: connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Posted on Jan 12, 2009
  • 23 Answers
SOURCE: HDMI to DVI-D conversion problem. Not in compliance?
It souunds like te TV is having problems with the streaming data being applied Most plasmas with DVI connections were actually designed for PC type input signals  Unfortunately the TV's input may not be able to stand up to the stream of signal the DVD or cable box wants to display. You can try and lower the output of both devices to 720P Good luck to you
Posted on Feb 17, 2009
  • 124 Answers
SOURCE: I HAVE A 42 ILO PLASMA TV WHEN I TRY TO USE THE
Set the DVR to send signal from the HDMI output.
Posted on Feb 21, 2009
No signal when i used vga monitor connector to pc, no problem in dvi
Michael,
I have both ASUS and LG monitors with multiple input choices. On both, when the monitor is turned on, it remembers the last input source. Both monitors (and presumably yours, as well) have an INPUT selection in their SETUP MENU.
So, I'm suggesting you search your monitor for an INPUT selection option, then choose "VGA" rather than DVI / HDMI / AV / COMPONENT / CABLE / ANTENNA, etc.
Hope this helps.
Sep 02, 2014 | Acer Computers & Internet
Tip
Toshiba 50HP95 Input Lock Reset
Toshiba 50HP95 Plasma TV Input Lock Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Input Lock?
Have you forgotten your Input Lock PIN, passcode or password?
If you forget your Input Lock passcode, you can view the locked input without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The Input Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 50HP95 Plasma TV Manual
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
***Need Help Connecting HP Pavilion dv6500 (running Win Vista SP1) To Panasonic Plasma!!
No. It is not going to work.
VGA is an Analog signal. HDMI is a digital signal, that is why you need the box, it converts analog to digital.
You can get VGA to DVI and DVI to HDMI convertors because DVI is capable of using both - depending on the type of DVI you have.
What is the difference between DVI and DVI NVIDIA
HDMI Wikipedia the free encyclopedia
Video Graphics Array
Mar 29, 2017 | Computers & Internet
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
I just purchased a acer h203h and when I hooked it to my computer it says no signa and light turns red.
Please check the video input selected, press Menu botton, the monitor will show you among other information the input selected, if indicates VGA, you must have connected the corresponding cable between your PC and monitor, if it indicates DVI and your computer doesn't have DVI port press the Input botton to select VGA.
Feb 22, 2011 | Computers & Internet
No vga input/dvi input monitor going to sleep. irksome! can somebody give the appropriate solution. tns.
When i turn my computer on my monitor keeps saying no vga input and no dvi input then the monitor says going to sleep ..........PLEASE HELP ME!!!
Feb 10, 2011 | HP w1907 LCD Monitor
Samsung syncmaster 2033sw monitor, till now i was using a vga cable for the display, but recently i bought a dvi cable and connected it. but its not detecting the display of dvi cable. if i remove the vga...
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Nov 15, 2010 | Samsung Syncmaster 2033SW Monitor
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
I have a Sampo PME42x9 monitor that I am trying to get to work with my laptop. I set the input to RGB and hook it to the laptop and then use the Fn key with F8 and nothing happens. On the monitor it says...
The problem of course is not the computer since you communicate well when using the Samsung TV. The problem is your Sampo. The Video Ports are:
Composite Input (Shared w/ S-Video) RCA-pin x 2 S-Video Input (Shared w/ Composite) Mini DIN 4-pin x 2 Component Video Input RCA-pin x 2 Sets (Y/CB/CR, Y/PB/PR auto detect) DVI Input (with HDCP) DVI-D 24 pin x 1 RGB Input D-Sub 15-pin x 1
If the RGB WILL NOT COMMUNICATE, I suggest you try RCA/DVI/ or shared composite. You may need adapters, but with so many options, just try other methods.
Feb 06, 2018 | Sampo Computers & Internet
Use of HDI-V input on PPM42M5SBx
the answer is no as VGA is a analog connection whereas the DVI connection is digital just like HDMI.
A DVI input on your display wont understand the analog signal and vise versa, hope this helps
Jun 17, 2008 | Samsung PPM42S3 42 in. Plasma Television
Televison & Video Logo
23 people viewed this question
Top Sampo Televison & Video Experts
Lyle Siemens
Lyle Siemens
Starnley Johnwells
Starnley Johnwells
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
