Question about LG LFX25976ST 24.7 Cu.Ft. French Door Refrigerator w/ water & ice Dispencer FACTORY REFURBISHED FOR USA
Squeaky seal on lg french door
Our french door LG seems to squeak whenever we open or close the right hand door. I'm sure it is coming from the flexible seal. No signs of food or liquid that might be causing it to stick and squeak. Any recommendations?
  • 31 Answers
Just get some wd40 and spray the inches, as they have gone dry
Posted on Feb 16, 2014
LG french door refrigerator does not keep food cold. Left door pops doesn't stay tightly closed.
What do you mean by "pops"? If your problem is the door, then it is possibly leaking out your cold air. It could be the seal or the hinge.
Aug 11, 2014 | LG LRFD22850 Bottom Freezer Refrigerator...
What to do about LG french door refrigerator that does not keep food cold
I would suggest you check the seal and the hinge. This frig has a piece that folds in and out flush for the two doors to seal, you might check that as well.
Aug 11, 2014 | LG LRFD25850 French Door Refrigerator
Squeaky Suspension
HI MAX.ummm i think if u level it properly it will be ok.as far as i know cant oil suspension.hope this helps Ali
Aug 21, 2012 | LG LFX25960ST Stainless Steel French Door...
The gasket on the right hand French door is slightly torn, so I bought a replacement gasket. It's arrived, but I have no clue how to replace the gasket.
The gasket is easy to replace. Remove bins and shelves set them aside. Next at the top right hand corner remove the door trim cover pull it straight out and set it aside. Note the tabs on the inside of the trim are fragile. Peel back the gasket at the top forward edge and bottom frward edge and you will locate a hinge. Use a small screw driver to pop these hinges out. Pull out the gasket on that side first and the whole seal comes on out of there. The hinge slides out of the old seal. Just snap yer new back in. Do on door at a time. The trim pieces for each door are different. Snap your door trim back and check for propah opening and closing of door. Then party on!
LG french door service manual
Aug 13, 2011 | Refrigerators
We have a Lg LFC25760SW fridge and the lights stay on in side the fridge
LG had a circuit board malfunction with many french door models with fridge lights staying on with the door closed. the bulb lens usually overheats; deforms; and falls off. the plastic frame surround is warped too. the bulb sockets are darkened too. if this is the case, call LG and they will usually repair this overheating issue for free. you can just unscrew the bulbs for the meantime.
Jun 15, 2010 | LG LFC25760TT Titanium Bottom Freezer...
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Light stays on with doors closed
press the swith by hand,work,check the door if it touch the swith.otherwise,ckech the swith
Mar 30, 2009 | LG LRFD25850 French Door Refrigerator
LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Jan 10, 2008 | LG French Door Cabinet Depth Refrigerator...
LG LFX25976ST 24.7 Cu.Ft. French Door Refrigerator w/ water & ice Dispencer FACTORY REFURBISHED FOR USA Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
