Serial number CNH 609 1025 HP TV have sound, but no picture
Why does my TV have no picture but still have sound? Its a LG LED Tv Model number 42LS3400-UA prod code 42LS3400-UA.APHLJD Serial number 2101NBSB2837 When turned on there is sound but no picture.
the picture board has gone faulty
thee are two system boards in the set --one for sound and one for picture
if you have the number from the board you want to replace try e-bay --circuit boards for your tv and see what comes up
Feb 22, 2016 | LG 42LS3400 42" Class FuHD 1080p LED LCD...
TV no sound, picture bleached and skewed
model. serial numbers would be helpful.
Apr 19, 2014 | Televison & Video
Picture just went out on my tv but I still have sound
I have the same problem with my HP PL4260N 42" Plasma HDTV serial # CNH6141988, model # CPTOH-0602. I have perfect sound and can change channels still with sound but NO PICTURE. I am a consumer with a question that need the advise of an expert.
Apr 17, 2013 | HP PL4260N 42 in. Plasma HDTV
50pf9631d/37 have sound no picture
You need a new main board. You can order one on ebay but make sure its the correct model/serial TV number on the back label of your TV.
Feb 16, 2013 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Devant 32" LCD TV: No picture display, no sound, no standby mode.
You should call Devant's hotline now to verify the problem. Be prepare to present the model number and serial number located at the back of the TV. Devant's hotline is 3029700.
Aug 07, 2010 | Televison & Video
No picture, no sound
sounds like the main board maybe going out or is gone and the lamp may have went as well
Jul 20, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Tv screen not on but got sound
Mainboard damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
May 14, 2009 | Televison & Video
Akai, PT46DL10 Has sound, no picture
make sure all componet cables are in the right color coded spots on the back or side of the tv and you are on the right componet if using a cable box make sure using componet / monster cables not all cable companies support hdmi if that is how you are trying to hook up make sure to check with them
May 14, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Tv wont work
does the power indicator blink? If so how many blinks? also do you hear any sounds when you press power?
Aug 09, 2008 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
