Question about Olympus E Cameras
What does the card error mean
When loading a compact flash card - "card error" comes up on the screen
    Top Expert:
  • Olympus Master
  • 6,702 Answers
Can be lots of things. Would have been handy, if you had told what card you are using. Your camera can work with CompactFlash, Microdrive and xD-Picture cards.
If you did not insert the card(s) you are using, correct, or you removed the card in a wrong way, you could have damaged the cardholder, causing an error you probably can't repair yourself. The CF and Microdrive you can remove by pressing the eject button. The xD-Picture card you can remove by pressing in the card, and release it. The card comes out.
Then you could have damaged the file system, by opening the card cover, while the card access lamp was blinking. What ever card was in, the filesystem can be damaged.
Then you can have two cards in, Both, o CF of Microdrive and a xD picture card. Some settings are required for the camera, to know hat card it should use.
If you have an Microdrive, the drive can be damaged, by a magnetic file, or the drive just stopped rotating. A micro drive is actual a miniature spinning hard drive.
First check if the memory card is inserted correct. Eventually, remove it and check all contacts, on the card and in the camera. Then try formatting the card. If you think there could be important pictures on the card, put it in a external card reader and use a recovery program, to see you can recover the pictures on your computer. Programs can be found on the net.
If you can't format the card, check if you have a Microdrive. If so, try to replace that with a CF or xD card.
I hope something is to any use for you.
Next time, please give us some more details. I know you exactly see and know what is not working, but we only can use your description. And only what you give us.
Posted on Feb 16, 2014
  • 4 Answers
SOURCE: compact flash error
try this link https://self-service-kb.canon-europe.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=68,E=0000000000429774916,K=2059,Sxi=0,Case=obj(45929)
If you have the right error they will repair it for free. Had mine done just before Christmas 07.
Posted on Jun 18, 2008
  • 70 Answers
SOURCE: Compact flash card problem
Go to the menu and format the card (as long as it's blank) formatting will erase all data from the card
Posted on Apr 15, 2009
SOURCE: Largest Compact Flash card a Kodac DC290 will acomodate?
I'm changing the cf of my dc290, I'had tried the 2Gb and it was working.
I would try the estreme III 2/4Gb, but i'm not sure...anyone else have an idea about them?
Posted on Sep 10, 2009
SOURCE: Canon A10 - "CF card error" with new 4GB card
powershot a10 is FAT16 based computer device,and can use CF cards only upto 1 GB.Memory cards above this are FAT32 based and will work only devices compatiable with FAT32 system.although FAT32 based cameras can work on FAT16 based cards.hope you find your answer!!!get a new camera to get that 4gb card work.i have an a10 and i am planning to buy a 2004 pro1.new cameras from canon and others are not that good.
Posted on May 29, 2010
  • 111 Answers
SOURCE: i-pro 8gb Compact Flash -
Hello -- just read your problem - interesting - do you have a multi card reader for the PC ? if so you could check out the card with the PC first. OR -- do you have a printer that can accept 'cards' this would also work from the PC also.
(This is how I download RAW format from my FinePix onto the PC)
I assuming you have entered a Card into the M603 before and other cards worked ? and it's just this 8GB card that won't.
Last resort if you can't get hold of a multi card reader is to take the card in a Photo Shop as if to print some pictures and see what their machine says when you insert your card.
It may ask you - Should I formatt the card -- say YES. Or if it says card error than just suspect the card , it may be faulty. -- Ray
Posted on Mar 04, 2011
Getting write error on Kingston 32gb Ultimate 600X Compact Flash Card
at the command prompt (pc/notebook) type chkdsk x: /f where x is your flash card
Dec 03, 2013 | Kingston Electronics - Others
Err CF I have a Canon Rebel XT, how do i fix this error and what does it mean?
CF stands for compact flash which means you have an error with your memory card. Try removing and replacing your compact flash memory card. If that doesn't work you may need to format your memory card or replace it.
Jul 28, 2011 | Canon Rebel XT / EOS 350D Digital Camera
THE CAMERA BRINGING A NOTICE ON A SCREEN ERROR CF.WHAT IS POSSIBLE THE PROBLEM.
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
What does CF full mean?
It means your memory card or Compact Flash Card is full. You need to delete some files.
Dec 13, 2010 | Canon Cameras
After inserting the sandisk into my computer, I get an error message. It says I/O device error. What does this mean?
It usually means that your Input/Output device (e.g. Card Reader either internal or External) is not compatible with your Flash card which is a 'newer' high speed and high capacity medium (OR your Flash card is a new one and has not been formatted). You can check that your card reader is working by inserting a 'standard' (not ULTRA) working lower capacity card (1GB or smaller). Hope it helps: let me know hoe you go.
Apr 03, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
I have a Canon EOS 350D, Compact Flash card freezes my computer
Instead of connecting via the camera, just use a USB card reader and put the CF card in that.
Mar 17, 2017 | Canon Rebel XT / EOS 350D Digital Camera
Compact Flash Problems
Dynamite,
have you tried to reformat the CF card?  If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
SteveK
Oct 27, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
HP PSC 1610 All-In-One - Memory card Error
Pulling out the card without using the 'Safely remove Hardware feature' risks corrupting data on the card. Reformat the card in the camera. Also with compact flash it is a simple matter to wreck the some of the tiny pins in the card slot. Check out both these and come back
Sep 10, 2007 | HP PSC 1610 All-In-One InkJet Printer
Updates for the PCMCIA and Compact Flash Card controllers
Some MobilePro units have exhibited the following symptoms when using Compact Flash Cards or ATA PCMCIA Memory Cards: 1. Storage Card folder is not displayed when you insert a PCMCIA ATA card and/or a Compact Flash card. 2. Warning message "Unidentified PC Card Adapter". 3. Warning message "Storage Card Warning" displayed. To fix these issues: If you have a MobilePro 750C without a ROM upgrade, download the file MP75Pcm.exe from support.necsam.com. For a MobilePro 750C with upgraded ROM, use the file MP75RPcm.exe. After the files are extracted, follow the instructions in the Readme.txt file.
Sep 14, 2005 | NEC MobilePro 750
Cameras Logo
51 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
