Question about Logitech X-240 Computer Speakers
Targus wireless speaker
The targus wireless speakers won't play my music and i've tried everything
SOURCE: logitech speakers will only play on 2 speakers not 5
Liamog, i bought the exact same speakers and sound card, and i had the exact same problem as you. I tried for days to fix it and it turns out that its only a setting you have to enable in your sound card settigns. If you go into your EAX console for your creative sound card you will find a thing that sams CMSS 3D, and all you have to do is select the button that says Enable CMSS 3d surround. I hope this will fix your problem. Alex.
Posted on Jan 18, 2007
Indian Guru
  • 32 Answers
SOURCE: Speakers do not work
yes thats the fact when you plug a headphone into any speakers the head phone will be the only one to function the speaker stops thta the circuit technically which will break the connection of power to speaker if you plug head phone
Posted on Apr 20, 2007
  • 25 Answers
SOURCE: my right speaker from my z-2300 stop working.
sounds like a loose connection somewhere inside that particular speaker. You could open it up to check for a loose or separated solder joint. The safe option would be to return to place of purchase and exchange for a new set.
Posted on Apr 30, 2008
mpcheeseman1
  • 1400 Answers
SOURCE: I just installed Logitech X-240 speakers and the
Polarity correct?Or possible bad ground in a cable.
Posted on Jan 17, 2010
KingDWS
  • 1606 Answers
SOURCE: Can hear a radio station thru my speakers
You could try to wrap the signal wire around through a ferrite core.
(That would look better than the tinfoil ;-]) You might need a couple of of cores to have any effect. The core will either look like a small donut or be a clamp on. Sort of like a splt pea. Just take the signal wire and wrap it around and through the core. Mare sure the wire doesn't cross over itself.
If the station is only 5 miles away then you are really getting a strong signal. If they are like other tejano stations they are probably pumping out a lot of power.
Make sure the wires are seperated out and not twisted around. What you want to do is isolate the wire and then add the cores that will help change the effective length of your wire. And that should shift it out of the frequency of that station. Then you can at last listen to something soothing like country and western bagpipe music.
Posted on Apr 11, 2010
Testimonial: "knows his stuff. and how to explain it too!"
What is the pin number for targus bluetooth speaker mid#2550913?
Password for Targus wireless speaker Mid#2550913 is 0000
Jul 12, 2014 | Audio Players & Recorders
Dell searches anbd never discovers targus speaker
Make sure to put the Targus Blutooth speaker in discover mode... You need Blutooth activated on your Dell as well. Otherwise, go to the Dell website and start a chat or go to the Tagus web site and chat with them.
Jul 12, 2014 | Targus Computers & Internet
Problem getting my bose soundlink to play blue tooth audio from my laptop.
Hi Sirtuan.
Go to the system panel, there choose "sound" . a list with all available sound devices appear. search for your bose soundlink and make it your "standard device".
had the same prob. with my BT headset and this works for me.
if your bose get disconnected the sound should automatically switch to pc speakers.
Regards
Gue.
Apr 06, 2013 | Bose SoundLink Wireless Music System...
No speech only music when using headphones
The tablet may be having trouble detecting that the headset is plugged in. You could try an app named SoundAbout (search for it in Google Play) to manually route the media audio to the headphones.
Nov 22, 2012 | Tablets & eReaders
My LG LHB975 Theather system subwoofer keeps going on n off when playing music flashing blue slowly
marvinpogno,
Sounds like you having an interference issue. Firstestablish a good connection, then diagnose why the signal is getting lost. You write that the problem occurs whenplaying music, which makes it sounds like everything is fine when playinganything but music.
First establish the connections; press and hold the stop button then press themute button on the remote. Check to make sure all units are operatingwith something other than music. Now to diagnose the issue; what you are using to play themusic most likely is causing an interference that is breaking the wirelesslink. Try something else to produce themusic from, ipod, mp3 player, etc. Don't forget about other things that could cause interference. Microwave ovens, wireless phones, wirelesscomputer router, etc. Hope this helps. Please rate the answer if I was able to help, thanks. -Chris
Jan 09, 2011 | LG LHB975 Theater System
Hiya i have recently moved my computer from the front room to a bedroom and plug everything in, i thought everything was fine until i tried to play some music so i checked all the connections/leads and...
Hi try looking over it again with the help of this https://www.download.p4c.philips.com/files/s/spa7300_79/spa7300_79_dfu_eng.pdf just make sure all connections are pushed in properly as those plugs have a tendency to not plug in all the way
May 04, 2017 | Philips SPA7300 2 Speakers
Targus mouse not recognized
What is the OS of your computer? This Targus mouse would work with Win 98, Win 2000 and Win XP. Vista was not mentioned. And if you are running Windows Vista for you laptop, then that could be the reason why it was not recognized by the computer.
Is this the wireless optical mouse? If yes, you need to follow the steps below to isolate the problem:
1. Connect the USB receiver into different USB ports of the computer.
2. Replace the batteries with the fresh ones.
3. Try connecting the mouse into different computer to see if you've got a defective mouse.
If you've tried everything and got the same problem, you may need to refer to the manufacturer, because I'm not sure if this mouse is a Plug-n-Play device or if it needs a driver.
Have a great day!
May 26, 2009 | Targus PAWM001U Mouse
Logitech X-240 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
