Question about Beats By Dr Dre Beats Executive Over Ear Headphones Black
Executive beats folding ear part has broken - Beats By Dr Dre Beats Executive Over Ear Headphones Black
How can I repair my Beats Mixr headphone in which one of the ear is not working ?
Presumably this is a wiring problem, for one of two reasons. If you look at the RCA plug that you use to hook into your stereo, you will see two black bands on it - one band for each signal - left or right. If there isn't a good connection, often you won't get sound in both earpieces. First try inserting the plug into your equipment part way, or rotating it carefully, to see if you can get both ears working. If that doesn't work, then the problem is either the wire for whatever ear is not working, not being connected properly at the RCA plug itself, or at the ear in question. You can unscrew the plastic cover on the RCA plug to see the wiring connection. But if the connection is bad at the actual earpiece, I would suggest returning the headphones, rather than taking them apart. Good luck.
May 23, 2014 | Beats By Dr Dre MIXR Black Over-Ear...
The sound quality in my beats studios is poor
Either get a replacement pair, or get some Sony MDR-1R for 170 Pounds or around 300 dollars
from john lewis, Sony e.g. fantastic headphones, I'm actually using them now and they sound so much better than the beats, and look better
Oct 29, 2013 | Beats By Dr Dre Studio Noise-Canceling...
Beats pro only playing in one ear and that's the side where the cord goes
As expensive as those are, this should be under warranty. In any case, the wire from the one speaker might be bad where it connects to the other side or it could be the main wire from the jack. If you have a meter you can test the cables and the speakers.
Mar 31, 2013 | Audio Players & Recorders
Beats studio no bass working in the left cup.....
There may be a broken wire or defective connection in the left side.
Mar 28, 2017 | Beats By Dr Dre Studio Noise-Canceling...
The plastic headpiece on my beats by dr.dre headphones are broken where the two screws are about 2 inches from where the ear phones bend. Can this be fixed?
a broken holder to the head set could be mended with plastic glue as means to first resort. second, a damage beyond repair is advisable to acquire a headset instead. perform an observation to decide on replacing or mending the broken headset.
Dec 28, 2010 | Monster Cable Radio Communications
Need basic waffle recipe . Need to make blueberry waffles for dinner.
Makes about 6 blueberry waffles.
  • 2 eggs, separated
  • 1 1/2 cups milk
  • 1/2 cup melted butter
  • 2 cups sifted all-purpose flour
  • 2 teaspoons baking powder
  • 1/2 teaspoon salt
  • 1 tablespoon sugar
  • 1 cup fresh or frozen blueberries, rinsed
In a small mixing bowl, beat egg whites until stiff; set aside. Beat egg yolks; add milk and melted butter. Sift dry ingredients together; add egg yolk mixture and mix until smooth and fold in blueberries. Gently fold in beaten egg whites. Bake in a hot waffle iron.
Bon appetit!
Jan 04, 2010 | Kitchen Appliances - Others
Beats By Dr Dre Beats Executive Over Ear Headphones Black Logo
Top Beats By Dr Dre Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike
Tom Chichester
Are you a Beats By Dr Dre Audio Player and Recorder Expert? Answer questions, earn points and help others
