Question about Frigidaire Over-the-Range Microwave
Cooling fan turns on very frequently
Hi the cooling fan turns over almost all the time and I can not use it because the fan won't turn off. Is there any problem with the oven ? does it need service?
  • Frigidaire Master
  • 9,047 Answers
<-- I could have given you some specific detailed repair information if you had included the full model number as shown on the tag on the oven (not from the manual).
And if FixYa would inform us experts when as persons responds to a request for more information, we could reply back quickly.
But since (for some reason) they won't, you'll just have to post a new help request.
But please be sure to include the full model number from the tag on the oven, and exact symptoms - what it's doing or not doing, and when.
Posted on Feb 17, 2014
Stops after 4 mins
Can you hear the "whirl" of the fan? It is possible the fan is not turning & cooling the oven therefore it will shut down when it reaches a certain temperature. This could be caused by a supply fault to the fan or the fan motor, either way it would need to be tested by a qulified engineer.
Nov 10, 2013 | GE JVM1653 Microwave Oven
Light and fan trouble
Fan works when component heat is higher so its normal.
Mar 01, 2008 | Samsung SMH7174BC Microwave Oven
The power keeps shutting off
see the details and fix it. God bless you
All microwaves have some sort of a cooling fan to help keep the magnetron and controls at a tolerable level. Most OTR models will usually use the vent motor for the cooling fan also. Countertop units have a small fan behind the control panel somewhere. Either way, if the cooling fan is not working and heat builds up, it is going to open a thermostat. On some makes, this thermostat might re-set itself as soon as the temperature cools down. Other makes, you will have to replace the thermostat or fuse.
If this is your microwave oven repair problem, you will need to check the operation of the fan. Below in the component testing chart, you will see how to test the fan. Also, if possible, make sure the fan is not obstructed somehow and not turning. Also check your fan relay at your control board for voltage, if no voltage, replace control board. This fan should come on at the same time any cooking starts.
Nov 15, 2012 | Panasonic NN-SD697S Microwave Oven...
Microwave shuts off after 10 seconds
see this causes and fix it. God bless you
Sep 24, 2012 | Maytag Microwave Ovens
We have a Hotpoint microwave model no. RVM15135DM2WW. It works well for about 2 minutes at a time then shuts down. Sometimes a PF will appear on the screen. I'm assuming it's overheating. Th
see the steps and use the common sense:
God bless you
Sep 09, 2012 | Microwave Ovens
Emerson mw9090ss just stopped while heating something
proceed with common sense, clearly, and logically.and fix it .God bless you
Microwave overheats and keeps turning off All microwaves have some sort of a cooling fan to help keep the magnetron and controls at a tolerable level. Most OTR models will usually use the vent motor for the cooling fan also. Countertop units have a small fan behind the control panel somewhere. Either way, if the cooling fan is not working and heat builds up, it is going to open a thermostat. On some makes, this thermostat might re-set itself as soon as the temperature cools down. Other makes, you will have to replace the thermostat or fuse.
Aug 02, 2012 | Emerson MW9090SS Microwave Oven
Fan turned on by self, won't turn off
The unit has a temperature sensing device that turns on the fan if it gets too hot...if it is very hot in your house it could turn this on...
If it is not overly hot then the thermistor or the main control board have gone bad and are reading an incorrect temperature...
heatman101
Aug 06, 2011 | Maytag Appliances Over-the-Range Microwave...
Panasonic 28 L NN C784 MF Cov+BAke. Turns off automatically after 20 secs every time. It once displayed HOT message too. Even after 24 hours of last operation the MW turns off automatically after...
hi,
look in the back through the grille with a flashlight to see if the cooling fan is running, you should feel a slight draft there too. if not running take the cover off and oil the magnetron cooling fan with 3 in1 sewing machine oil. oil it on both sides of the motor so its saturated. if it does it again you will have to order that motor. probably at panasonic.com or searspartsdirect.com. be careful inside the microwave with the cover off, avoid the red high voltage wires. use gloves if necessary. panasonics are a pretty good oven, worth fixing..
jm
Apr 25, 2011 | Panasonic NNH965BF Microwave Oven
Does the exhaunst fan turn on automatically when we cook or warm food items in our Samsung Microwave -- SMH 9187W?
Some interesting reading on page 8 of the owner's manual:
"Boilovers cause smoking and greasy spillovers that may ignite and spread if the vent fan is operating.To minimize automatic fan operation, use adequate sized cookware and use high heat on surface units only when necessary."
And on page 20:
"If the temperature becomes too hot around the microwave oven, the fan in the vent hood will automatically turn on at the LEVEL 2 setting to cool the oven. The fan will automatically turn off when the oven has cooled down sufficiently. This is an automated process and cannot be turned off. The fan may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. The Vent Fan will only operate in 1~4 levels modes while the microwave is working."
"Using the Vent delay off button
1. Press the Delay Off button once to turn the fan off after 1 minute.
2. Press the Delay Off button twice to turn the fan off after 3 minutes.
3. Press the Delay Off button three times to turn the fan off after 5 minutes.
4. Press the Delay Off button fiour times to turn the fan off after 10 minutes.
5. Press the Delay Off button five times to turn the fan off after 30 minutes."
If for some reason you don't have your owner's manual, you can still download it free here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jan 01, 2011 | Samsung Microwave Ovens
The freezer constantly drips water even with the ice maker turn off, the fan constantly runs but when the door is open the fan shuts off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Microwave Ovens
Frigidaire Over-the-Range Microwave Logo
61 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
