Question about Vehicle Parts & Accessories
2009 toyota tacoma 4 wheel drive will not engage
    Sergeant:
  • 406 Answers
If it is an automatic or push button four wheel drive..it most likely is the four wheel drive control box...not sure where it is located on your vehicle..you need to find out where it is located..It is a plug in so many can be DIY once it is located..some are under the battery box...they run about $100-200 and there are many different ones so make sure you find the model number..dealer will be over $400 so see if you can find it..And good luck..
Posted on Oct 03, 2014
My 2009 Toyota Tacoma 4 wheel drive 6 cylinder cruise control does not work
check fuses and relays --have vehicle scanned if theirs a fault pending most cuise controls wont operate most auto stores offer scan for free if good stat looking at switch and harness
Aug 01, 2016 | Toyota Cars & Trucks
4 wheel drive does not engage when turning knob
Check fuse for transfer case. Check electrical connector to transfer case. Listen for transfer case motor running when switch is activated.
Mar 02, 2015 | 2008 Toyota Tacoma
4 wheel drive in 1995 toyota tacoma
check that the transfer case is in 4wd and if you have free wheeling hub locks check that they are engaged
Dec 02, 2013 | 1995 Toyota Tacoma
1997 toyota tacoma will not go into 4 wheel drive
Has the transfer case ever been serviced? The fluid should be changed every 30,000 miles, if not the works can stick and cause engagement problems. Make sure the vacuum to the front hubs is available, if the front hubs are not locking the front drive shaft will turn but no Front wheel lock up and no 4 wheel drive is available.
Oct 05, 2012 | 1997 Toyota Tacoma
1995 Toyota Toyota Tacoma 4WD 6 cylinder 3.4
no, you will tear up the differential.
Dec 19, 2009 | 1995 Toyota Tacoma
I have a 2000 4wd tacoma with manual locking hubs and the 4wd does not seem to be engaging after locking the hubs and shifting the lever into 4 hi or 4 low
Sounds like one of your hubs is sticking and not engaging. You can check them by engaging the hubs and the transfer case and jacking up each front wheel independently if it doesn't spin your good, if it does you found your problem. As far as fixing a hub goes, it may be just dry and need some grease, or there are some very good aftermarket hubs available from Warn.
Hope this helps
Dec 08, 2009 | 2001 Toyota Tacoma
2003 tacoma 4 wheel drive, seems that the hubs are stuck in 4 wheel
engage in 4low drive forward. disengage and drive back and forth a few times if this doesnt work bring to dealer
Jul 23, 2009 | 2003 Toyota Tacoma
Vehicle Parts & Accessories Logo
51 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
