Question about Kenmore Dryers
Kenmore 70 dryer blower doesn't work. Can look in and see that the blower wheel is not turning. Is the problem the motor or could the wheel just be stuck.
    Sergeant:
  • 239 Answers
Odds are, it's the motor. Unless that particular model has a belt drive on the fan, then, it would simply be a job of replacing the belt if it's slipped off, worn, or broken.
Posted on Feb 16, 2014
4 Suggested Answers
  • 1122 Answers
SOURCE: kenmore dryer series 70 won't turn on
most of the time it is the door switch that goes bad,also you can check the main fuse inside the dryer on the blower box,and always make sure your dryer vent and wall vent are clear to vent,let me know what you find-mike
Posted on Oct 29, 2008
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
machinetech7
  • 1344 Answers
SOURCE: kenmore dryer 70 Series drum not turning
http://www.youtube.com/watch?feature=player_embedded&v=bJ5TNlzHKhA
Posted on Jun 06, 2012
Kenmore dryer 70 series
Check the vent for clogs and kinks. Could be something in the blower wheel causing the noise and blocking the vent.
Remove the vent from the back of the dryer, unplug the dryer, and reach inside the dryer vent to check for items lodged in the blower housing.
Feb 04, 2014 | Dryers
My Kenmore dryer 11060056990 that turns off after drying for 2 minutes
Either the motor bound up by the the blower wheel or the run winding is bad on the motor itself. Once you access the blower wheel area you'll know which situation that you are dealing with,
Sep 07, 2012 | Kenmore 63942 Dryer
DRUM WONT TURN- The blower turns, the belt
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 23, 2011 | Kenmore Dryers
Kenmore 70 series electric dryer not coming on
next time send the model number,if it's not starting unplug the dryer,on top of the blower wheel housing there will be a thermal fuse,if the filter is on top it's behind the back panel of the dryer,if the filter is inside it's in the front of the dryer,it will be near the duct that the lint filter slides into,you need to remove at least one of the wires before you read it out with a meter,it will be a 3392519 or a 3390719,these are the two most used thermal fuses.let me know what you find,if it is the fuse most likely you need to clean out the dryer.blow out the vent line i use a leaf blower if it's long,clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is
Apr 23, 2010 | Kenmore Dryers
I have a Kenmore dryer model no. 1109282610. When
the motor is humming,could be something stuck in blower wheel,might of had lint filter out and ran dryer and something went down into blower wheel,the belt could be locked up or the motor is bad,take the belt off of motor and see if motor spins
Nov 02, 2009 | Kenmore Dryers
We have an electric Kenmore 70 series dryer that is making very loud noises - still drying well otherwise. Husband just took off front and top, and took out drum - still makes same noise when just motor is...
check yopur blower wheel and blower wheel housing...turn with hand to check motor bearing,,if motor bearing tell husband a little bit of wd 40,,or white grease at each end
Dec 28, 2008 | Kenmore 63942 Dryer
Kenmore dryer help?
Sounds like motor is stalled. Remove the lint filter, look inside down toward the bottom left corner at the blower wheel. Something may be jammed in the blower wheel. If difficult to see, TURN OFF POWER TO MACHINE, remove bottom access panel. 2 to 3 screws on bottom of panel. Remove lint housing (3 to 4 screws) and inspect blower wheel for debris.
May 27, 2008 | Kenmore Elite HE4 Electric Dryer
An Old Gas Kenmore 7870701
Michael, here are a few things to check. Can you turn the drum by hand? If not you may have something in the blower wheel binding the motor. You can acess the blower by removing the back panel and removing the two screws under the vent screen on top. Once the back panel is removed the blower wheel will be behind the vent. Three or four screws and it's off. If the blower wheel is ok, it may be the motor itself going bad. Have someone hold the door switch down and while pressing start, give the drum a turn. If it starts running, it's probably a bad motor. Other things to look for is bad rollers. If they are bound up it may prevent the dryer from starting. Check these things out first...Catriver..post back.
Jan 03, 2007 | Kenmore 72602 Gas Dryer
Dryers Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
