Question about Panasonic AG-DV2000 Mini DV VCR
When plugged in and iMovie is open, the screen is black but the sound is fine. Changed the cable and still the same problem. Could it be the dv connecter inside the actual machine? And if so can that piece be changed?
  • Panasonic Master
  • 1,511 Answers
Broken screen....good audio, sorry!
Posted on Jan 22, 2015
I am unable to import video from my Panasonic DVC62. when i connect it with my mac computer it doesnot show any icon in desktop. can u help me to solve this problem please.
Use a firewire cable to connect the camera to the Mac. Nor a USB cable.You will not see an icon on the Mac desktop.If iMovie does not open automatically then open iMovie.
Jan 07, 2012 | Panasonic AG-DVC62 Mini DV Digital...
I bought a DV/Firewire cable, in order to plug the Canon MV800i camcorder, but once it is plug, how can I get the datas from my many tapes, onto my Apple Computer in order to save the tapes onto...
Connect the camera to the Mac with the firewire cable.
Open iMovie and capture the required footage.
Send the iMovie project to iDVD and burn a disc.
Apr 02, 2011 | Canon MV800i Mini DV Digital Camcorder
IMovie 09 / Mac OS X will not recognise Sony DCR-HC35 via firewire or USB? Do I need to download the correct driver?
mac doesn't support usb streaming so that leaves us with firewire. it should be a plug-and-play connection. no need to install any kind of driver for the camcorder (but try to check if there are any available driver updates for the firewire card).if possible try to check if your computer firewire port is working by using other devices.your imovie software should detect the camcorder once connected.if not, disconnect cam, open imovie, and connect again.if still doesnt,RESET camcorder.if still the same try restarting computer with cam connected and powered on.check if you have a dv in indicator on your screen.check if firewire cable connection is secured.try diff ilink cable if available.if still no go, try a diff computer. if everything fails might also be a service issue.hope this helps.tnx:)
Apr 16, 2010 | Sony DCR-HC35E Mini DV Digital Camcorder
I am looking for a way to download to my harddrive the mini dV to the drive itself, any suggestions? Mark
you need Ulead 11 (20 bucks at Ebay) program and a firewire cable. install the program. connect the camera to the computer with the firewire cable turn the camera on and put on play mode. follow the on screen prompt.
Apr 06, 2010 | Canon ZR-950 Mini DV Camcorder
Panasonic pv gs 180 can't import into imovie
Hi, I managed to down load mine by connecting with a firewire and setting the camera to playback mode (not PC), opening imovie, turning the camcorder on and selecting file -' import from camera". a screen came up then I started playback on the camcorder and was able to select import from the screen on the imac.
Sep 28, 2009 | Panasonic PV-GS180 Mini DV Digital...
Macbook not recognizing camcorder
I had this problem when first plugging in my Canon zr80 to my Mac. What I did first was (if you have it) open up the program Imovie in you're applications menu. Then plug the firewire cable into both the camera and computer. Turn the camcorder on and set it to play(VCR). Once this happens you should see a "DV in" on the camcorders screen, followed by a blue window on you're computer. The rest should be easy.
Jul 01, 2009 | Canon ZR800 Mini DV Digital Camcorder
Import into imovies
convert your video to mp4, mov, or dv with imovie converter, and then import them to imovie for editing.
Jun 29, 2008 | Canon MV700 Mini DV Digital Camcorder
JVC GR-D275U Driver for mac
You would need to use iMovie. Most MacBooks come with this already installed but if you can't find it you might have to buy it from apple's website. All you have to do is open iMovie with the camera connected and on and import the movie into iMovie, then you can edit the way you want it to be. iMovie has some great tutorials as well. Importing and editing can take a while, however.
Nov 08, 2007 | JVC GR-D275 Mini DV Digital Camcorder
Camcorder to Mac Sony dcr-hc32
Maybe this FAQ will help ya? Problem: Camcorder will not connect to iMovie - No camera attached Possible Solutions: * Are you using a 4 to 6 pin firewire cable? That is the ONLY thing you can use. No USB cables or anything else * Are you using a compatible camera? Still cameras that take movies are NOT a DV camera * How new is the cable? If it is pretty old or you have kinked, it you may need another one * Is the camera in DV mode? It should be. (Usually in the menu options somewhere) * Have read ALL of Apples help topics on this If your good with all the above: 1. Close iMovie 2. Delete all iMovie plist files for iMovie located in Home/Library/Preferences 3. Plug the camera in to the wall (electricity) 4. Make sure you have a good firewire cable and plug it in to the Mac from the camera 5. Turn off your camera 6. Reset your pram 7. When the Mac is booting, power on the camera 8. Start iMovie Sony camcorder special fixs: 1. Turn your camcorder to Play mode. 2. Press menu button (or relevant touch-screen button) 3. Click the 'ETC' item and then to CONTROL. 4. Select i-link (and not IR). or 1. Turn your camcorder to Play mode. 2. Press the Menu button (or relevant touch-screen button) 3. Scroll down the Menu to the 'ETC' option, if there is one 4. Click the 'ETC' item and choose 'VIDEO EDIT' if it's there 5. Click 'VIDEO EDIT' and 'MARK 1 IN' may appear 6. Click on 'MARK 1 IN' and then exit from the Menu options, by pressing the Menu button again Your Sony cam should now work OK with iMovie. * Reason? The camera and Mac can't decide which device is giving the FireWire instructions, and which is supposed to be receiving and acting on them. Using this sequence (above) lets the camera receive instructions from iMovie.
Sep 14, 2005 | Sony Handycam DCR-HC32 Mini DV Digital...
Panasonic AG-DV2000 Mini DV VCR Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
