Question about CITIZEN AMERICA Citizen CT-S310II Dot Matrix Printer - Monochrome - Receipt Print
Printer beep codes
Printer makes a loud beeping noise- seven to nine short beeps. Error light flashes short-short-long, power light flashes continuously.
I have mb-msi2000-815e pro ver1, it is constantly beeping. change the memories,agp,, but it still continues.what could be wrong/
1.Your first step is to look at the information about the meaning of the beeping codes. Beep codes are important and useful tools when troubleshooting booting issues. When you turn on your computer system, it is called POST (Power On Self Test).
2.No beep is usually a power problem that can be related to the power supply, motherboard or both. Always check your battery power before thinking there is a bigger problem.
3.One beep is a normal POST. That means everything is fine.
Two, Three, or Four short beeps are normally about the memory of the machine. If there is a problem with one of your memory chips you should get beeps of different combinations in this area. If you get two or three short beeps, one or both of your memory chips could be in trouble.
4.Five beeps point toward motherboard or CPU problems. Make sure your memory and video card are seated properly. Try removing them and putting them back in, only if you are comfortable with computers.
Six, seven and eight beeps.
Eight beeps indicate problems with your video card. Six or Seven are CPU, or a bad chip on the motherboard.
Nine beeps mean the BIOS is bad. Replace the motherboard.
Ten beeps means the problem is in the CMOS. All chips need to be replaced.
5.Eleven beeps are related in the cache of the mother board and this means that the motherboard needs replaced.
One long and three short beeps mean that it is related to a loose memory chip. Try reseating it.
One long and eight short beeps means that the video cards needs reseated.
6.I hope that this list of beep codes will help settle the panic you feel when your computer is sick. If all fails, Then you inform me
Feb 21, 2011 | ASUS Intel 815E Chipset CUSL2-M...
Tip
Error Codes you need to know.
Standard Original IBM POST Error CodesCode Description
1 short beep System is OK 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Display adapter problem (EGA) 3 long beeps 3270 keyboard cardIBM POST Diagnostic Code DescriptionsCode Description 100 - 199 System Board 200 - 299 Memory 300 - 399 Keyboard 400 - 499 Monochrome Display 500 - 599 Colour/Graphics Display 600 - 699 Floppy-disk drive and/or Adapter 700 - 799 Math Coprocessor 900 - 999 Parallel Printer Port 1000 - 1099 Alternate Printer Adapter 1100 - 1299 Asynchronous Communication Device, Adapter, or Port 1300 - 1399 Game Port 1400 - 1499 Colour/Graphics Printer 1500 - 1599 Synchronous Communication Device, Adapter, or Port 1700 - 1799 Hard Drive and/or Adapter 1800 - 1899 Expansion Unit (XT) 2000 - 2199 Bisynchronous Communication Adapter 2400 - 2599 EGA system-board Video (MCA) 3000 - 3199 LAN Adapter 4800 - 4999 Internal Modem 7000 - 7099 Phoenix BIOS Chips 7300 - 7399 3.5" Disk Drive 8900 - 8999 MIDI Adapter 11200 - 11299 SCSI Adapter 21000 - 21099 SCSI Fixed Disk and Controller 21500 - 21599 SCSI CD-ROM System
on Mar 09, 2010 | Computers & Internet
Tip
Beep Codes (Different BIOS) " What they mean "
Code Description
Code Description
200 - 299 Memory
300 - 399 Keyboard
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
on Dec 30, 2009 | Computers & Internet
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    My Canon s4500 not working, with 6 beeps error
    This is because the BJ Cartridge is not installed. Please refer to your manual page 214.
    Two beeps: Out of paper, or paper feed error
    Three beeps: Paper jam
    Four beeps: BJ Cartridge out of ink
    Five beeps: Cartridge not installed correctly
    Six beeps: BJ Cartridge not installed
    Seven beeps: BJ Cartridge defective
    Eight beeps: Waste ink tank almost full
    Nine beeps: Automatic print head alignment failed
    The POWER lamp flashes orange and green alternately with beeps: Service error
    YBC (/\)
    Oct 08, 2009 | Canon Office Equipment & Supplies
    BJC-8200 beeps 10 times and wont go online.
  • Hi
  • All The Best: Pineworks
  • Oct 06, 2009 | Canon BJC 8200 Photo InkJet Printer
    It is beeping "Error" with 5 beeps
    5 beep error means that the waste ink tank is full. You can reset the counter to make it print by doing the following: You have to be exact. If you make a mistake in any of it, just go back to the beginning and start it all over.
    1.Unplug the power cord from the printer
    2.Hold down BOTH the POWER and RESUME button at the same time and then plug the power cord back in. Keep holding down the buttons until the printer finishes its powering up noises.
    3.After the printer is quiet, release the POWER and RESUME buttons. Then hold down the RESUME and CARTRIDGE buttons at the same time with one hand, and press the POWER button with the other. KEEP HOLDING DOWN the RESUME and CARTRIDGE buttons until you hear 2 beeps. They will come quickly together and one beep will be longer than the other. Listen carefully, as they are not very loud.
    4. Once you hear the 2 beeps, release both buttons.
    5. After both buttons have been released, then press the CARTRIDGE button 15 times. You will hear a beep each time it's pressed.
    6. After you finish pressing the cartridge button 15 times, then press the RESUME button one time. The printer will beep and shut off.
    7. Turn the printer back on by pressing the POWER button. The printer will work fine now. The waste ink will have been reset to 50% full.
    Sep 29, 2009 | Canon BJC-85 InkJet Printer
    Turn it on it beeps cdc
    You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
    BIOS Beep Sound core list
    AWARD BIOS
    1 short(Beep) System booting is normally.
    2 short(Beep) CMOS setting error
    1 long - 1 short(Beep) DRAM ERROR
    1 long - 2 short(Beep) Display card or monitor connected error
    1 long - 3 short(Beep) Keyboard Error
    1 long - 9 short(Beep) ROM Error
    Long(Beep) continuous DRAM hasn't inset correctly.
    Short(Beep) continuous POWER supply has problem.
    AMI BIOS
    1 short(Beep) DRAM Flash Error
    2 short(Beep) DRAM ECC Check Error
    3 short(Beep) DRAM Detect Fail
    5 short(Beep) CPU Error
    6 short(Beep) Keyboard Error
    8 short(Beep) Display card memory Error
    1 long - 3 short(Beep) DRAM Damage
    1 long - 8 short(Beep) Display card or monitor connected error
    Jul 16, 2009 | E-Machines T6520 PC Desktop
    Pc keeps beeping 3 times and nothing on the moniter
    remove the RAM(MEMORY CHIPS) from *********** board and reinsert.if the problem is same replace the chips,get new chips.mostly cleaning the golden lines on the chip with pencil/school rubber solves the problem.
    Step3
    One beep is a normal POST. That means everything is fine. Two, Three, or Four short beeps are normally about the memory of the machine. If there is a problem with one of your memory chips you should get beeps of different combinations in this area. If you get two or three short beeps, one or both of your memory chips could be in trouble.
    Step4
    Five beeps point toward motherboard or CPU problems. Make sure your memory and video card are seated properly. Try removing them and putting them back in, only if you are comfortable with computers. Six, seven and eight beeps. Eight beeps indicate problems with your video card. Six or Seven are CPU, or a bad chip on the motherboard. Nine beeps mean the BIOS is bad. Replace the motherboard. Ten beeps means the problem is in the CMOS. All chips need to be replaced.
    thanks.
    Jul 11, 2009 | Asrock 775i65G Motherboard
    Beeps
    Code Description
    For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
    Aug 16, 2008 | Dell XPS M1530 Notebook
    CITIZEN AMERICA Citizen CT-S310II Dot Matrix Printer - Monochrome - Receipt Print Logo
    Top CITIZEN AMERICA Office Equipment & Supplies Experts
    k24674
    jasbo
    jasbo
    Are you a CITIZEN AMERICA Office Equipment and Supply Expert? Answer questions, earn points and help others
