Question about Yamaha RX-V420 Receiver
RX-V420 Receiver clicks on but doesnt display anything or play music
It clicks when I press the power button and after .5 seconds it makes a quieter click noise
snakehead
  • 1074 Answers
SOURCE: Yamaha RX-V420 Will Not Power up
Hi Daniel if your set does not have a fan that trips on when the volume gets louder surely the audio output will damage. every working component generates heat and when the heat sore up to an uncontrolable level it cause damage.have a tech look on your set to repair it.good luck.
Posted on Apr 26, 2007
djnick989
  • 1067 Answers
SOURCE: Power shuts off
is it pl;uged direct in wall must nbe on a nice hi end break surge proably got zapped transisters in it best to try to replace it u can try to un plug it from that outlet few min then back in anther one
Posted on Jan 21, 2008
  • 4234 Answers
SOURCE: Yamaha RX-V420 No power
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
Dan
Posted on May 12, 2008
SOURCE: yamaha av receiver rx-359
go to best buy and buy a new recever
Posted on Apr 10, 2009
SOURCE: RX-V1600 2 clicks but won't switch on
I have the same problem, any resolution on this one yet?
Posted on Nov 22, 2009
I need to conenct yamaha rx v420 to Samsung tv
Unless your Samsung has optical digital entries, I'm afraid you can't use them together in high quality.
Today, everything is connected through HDMI. Your Yamaha receiver has only analog connections. As well in as out. Although on the left side, when you look from behind, there are some digital connections.
I found the manual still online, so if you don't have one, click the link below.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V420.pdf
Mar 31, 2014 | Samsung Security Cctv Sod-14c Soc-120...
My Yamaha RX V461 receiver will not turn on. When pressing the ON/STBY button, I hear the familiar "click" when pressing the button and a second one about 1-2 seconds later that comes from the...
Your receiver probably went into protect mode because you were overloading the output stage with concert blast. In some units, protection consists of fuses that blow; in others protection is provided by thermal shutdown devices.
Mar 04, 2017 | Yamaha RX-V461 AV Receiver
My remote can not do any action of my home theater system in spite of red light running every time I click a button. Mother is a problem in the system or remote? I would love to get help.
the remote is designed to control multiple components you need to push the "receiver" or possibly "amp" button on your remote to tell it control the receiver. Other wise it is trying to control another component.
Sep 29, 2010 | Yamaha RX-V420 Receiver
Gigaware remote for ps3 cant connect
I can not locate a Remote For PS3 By Gigaware now if its a controller Follow these steps
Connect to PS3
1. Turn on your console and plug the receiver into the first port on the console. The RX indicator on the receiver flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. The controller’s POWER indicator lights and the 4 port indicators flash.
3. The controller connects with the receiver automatically after about 3 seconds. If successful, the RX indicator on the receiver lights.
4. Press the PS button to assign a controller number. The corresponding port indicator lights.
Manual Search
If you are unable to automatically connect, try manual adjustment.
1. Repeat steps 1 and 2 under “Connect to PS3.”
2. Press CONNECT on the receiver. The RX indicator flashes.
6
3. Press and hold SELECT and L3 (left analog stick) on the controller simultaneously for at least 3 seconds. When the RX indicator stays lit, release SELECT and L3.
n Notes:
• Repeat “Connect to PS3“ or “Manual Search“ if the connection fails again.
• If you purchase a new receiver for the controller, but have previously been using it with the supplied receiver, you will have to follow connection steps again.
Reassigning a controller number
1. Press and hold the PS button for one second. The functional screen displays. Select “Controller Settings”, then “Reassign the controller.” Press X to confirm.
2. Use the D-pad to select the number that matches the controller’s port.
3. Press X again to confirm. The corresponding port indicator lights up.
7
Connect to PC
1. Plug the recevier into a PC’s USB port. The receiver’s RX indicator flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. If connection is successful, the RX indicator on the receiver lights and the 4 port indicators on the controller turn off.
Test the controller
1. Open the control panel on your PC, and double-click “Game Controllers.” Then click “Properties“ and the testing screen appears.
2. Press the buttons of the controller. After testing, press OK to exit. You are now ready to play games.
Troubleshooting
If the controller stops working at any time, or will not connect to PS3 or PC, follow “Manual Search“ steps on pages 5-6.
Dec 14, 2009 | Video Game Consoles & Games
No power
Crystal for system micro should be in front panel display and near the lcd display .while your there check solder connections in display board
Aug 05, 2009 | Yamaha RX-V420 Receiver
Zone 2 issues
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there
Aug 03, 2008 | Yamaha RX-V659 Receiver
Dan
May 12, 2008 | Yamaha RX-V420 Receiver
Remote control problem
try pressing the TUNER button on the top of remote before pressing these buttons
Nov 27, 2007 | Yamaha RX-V420 Receiver
TURNS ON BUT NO SOUND
if the amplifier integrated circuit is busted that will not sound even the power will display the front panel.
Sep 13, 2007 | Yamaha RX-V420 Receiver
Apr 26, 2007 | Yamaha RX-V420 Receiver
Yamaha RX-V420 Receiver Logo
26 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
