Question about LG Microwave Ovens
Lg label is loose. Can I remove it. - LG Microwave Ovens
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Well does it seem to be necessary in order for the microwave to work? If it doesn't, I think it is fine.
Posted on Feb 18, 2014
How to replace the light bulb in LG microwave oven.
Free LG Electronics Microwave Oven User Manuals ...
kitchen.manualsonline.com > ... > Kitchen Appliance LG Electronics
Products 1 - 50 of 141 - LG Electronics Microwave Oven 1SS6LMV1 8. LG - Life's Good Microwave Oven User Manual. Pages: 0 Saves: 0. See Prices
Sep 24, 2015 | LG Microwave Ovens
Instructions on how to remove the cover from a wall mount LG LMV2073 mic oven?
On my GE, if you open the door, there are screws to remove that will allow the cover to be removed. When it quit working, I had to show the guy how to remove it. He thought he had to take it all the way down. Turned out to be the fuse (which I could not see when I had it opened) so he charged me half the cost to come out because I had to show him how to open it
Oct 30, 2014 | LG Over-the-Range Microwave
LG. Why are wires attached to KSD1 150/0 (MGT Thermostat) burned?
If the wires were loose and cause them to burn under a load. Loose terminals cause high voltage and burn switches, relays and thermostats. I hope this helps you.
Nov 23, 2013 | Microwave Ovens
I need I know how to set the clock on an lg microwave model ms1446sqp
The MS-1446SQP is the version of this microwave sold in Mexico. To set the clock, press the button labeled Parrar/Borrar (Stop/Clear on English microwaves) in case any cooking programs are running. Then press the button with the clock face (Reloj). Then press the touch pad labeled Inicio/Inicio Rapido (Start/Fast Start). Type in the 4 digits of the current time (24 hour format). Then press Inicio again. (Note: I have left off the accents.)
The manual for the LG MS-1446SQP is available here: http://www.lg.com/mx/soporte-producto/lg-MS-1446SQP . The directions for setting the clock are on page 12 (pictures of the control pad are included). This is the Spanish version of the manual and is a pdf. Thus you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Nov 18, 2012 | Microwave Ovens
How much energy does lg microwave of 26 and 28 and 30 litre use in one hour
They will use exactly what they state on the identity label on the rear of the product. If they are all rated at 1200Watts, then that is what they will use per hour.
Feb 10, 2011 | LG LRM2060ST Microwave Oven
Microwave is arking is there a solution?
Hi!!
Unplug unit from wall outlet and remove the two screws on each of the bottom sides to remove the metal cover, check wiring insulation and for a loose or disconnected wire. Check on the inside of the cover for burnt marks, that will give you an idea of where the problem may be. Use needle nose pliers to handle and plug wire terminal back up.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 02, 2010 | LG LRM1260SW Microwave Oven
Turntable won't turn
Look at the front panel, at the bottom, in the middle.
Identify the button labeled "Turntable On/Off".
Push it.
Slap yourself on the forehead.
Next time you fumble to turn of the light in the dark, push the right button.
Dec 05, 2009 | LG LMV1630ST Microwave Oven
Goldstar NV1502 No Heat
You should still have about a 5-year warranty on the magnetron, if that's the trouble.
If everything else works, it's almost certainly a high voltage component, most likely the magnetron or diode, but also possibly the transformer.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
I would contact LG / Goldstar first. For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 05, 2008 | Goldstar MV-1501 Microwave Oven
Sharp carolsel model r1505 on/off buttons broken
Unplug micro wave.
3 screws to remove top vent.
1-screw to remove touch panel from chassis.
tilts foward disconnect wires from board . I labeled for
reassembly .
1-screw holds the touch panel electrics to face plate.
There are 4-6 snap in plastic tabs holding it in place.
you have full access to the cheap plastic hinged buttons.
I hot glued mine once but they broke after 6 months.
I found this site:http://207.234.249.73/mwd/#brands
Good pics and you can see the buttons.
They sell a replacement button for $15 . There is also a
complete service manual for the Sharp 1505 for free download.
Did I mention to unplug the microwave before starting...
Rob H
Dec 17, 2007 | Jenn-Air JMV8208A Microwave Oven
Microwave Ovens Logo
14 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
