Kodak error code 3825
Kodak esp 5250 shows error code 3825. Will not print. Message says print head jam and paper jam. Checked front and rear for paper but none found
  • 285 Answers
SOURCE: error code 3820
try the baack of the printer. open it up from the back
Posted on Jan 28, 2009
  • 8 Answers
SOURCE: kodak esp 7 has a
If you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
Posted on Mar 05, 2010
  • 15 Answers
SOURCE: My Kodak ESP 3 all-in-one printer will not print
you may try to clean the printhead and recalibrate the printer. if this will not correct the problem, you need to replace the printhead. I suggest contacting Kodak technical support to have a replacement printhead.
Posted on Apr 17, 2010
SOURCE: My Kodak ESP & keeps giving me the error code
hi my kodak printer is giving the printinr error code 3825 all the time. What is that?
Posted on Sep 09, 2010
  • 5 Answers
SOURCE: My Kodak ESP 5250 has
Fart in a bottle and then sniff the bottle
Posted on Mar 07, 2011
Code3825
Error: Printer Error (3825) Published 04/17/2012 04:30 PM ' Updated 05/30/2012 11:48 AM ' Answer ID 46577
How do I resolve the error message "Printer Error" (code 3825) on my all-in-one printer? To resolve the error:
  1. Remove all paper from the paper tray(s).
  2. Disconnect the power cord from the printer.
  3. Wait 5 seconds, then reconnect the power cord.
  4. Reload paper in the paper tray(s).
  5. Try printing again.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Mar 12, 2014 | Office Equipment & Supplies
My kodak printer esp 3.2 is giving me an error code 3533 paper jam but there is no paper jammed and when i put new paper in it, it still wont print and keeps giving me the same error code 3533
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Sep 12, 2013 | Kodak ESP C310 AllInOne InkJet Printer
Printhead carriage jam
It all depends on who made the product. There are often times simple solutions but they need to be found by searching on the web and talking to service people about the unit. Some print head motors were known to fail or develop bearing noise over time in the HP line. Many of these things are really not prone to be fixed as the repair cost is sometimes the same as a new unit.
I would contact the warranty center- even if out of warranty and see if you could talk to a technician to start.
Aug 29, 2012 | Kodak ESP 5250 All-in-One Printer
Esp 5250 error code 3528
Hello Shaheen,
Try this:
  1. Press the On/Off button on the printer control panel to turn off your printer.
  2. Wait 30 seconds.
  3. Press the On/Off button to turn on your printer.
If the error continues, double-check that all paper and foreign objects are removed from inside your printer.
NOTE: Even if you do not physically see a paper jam, you will need to follow the paper jam link to solve the error.
Paper Jam Error
Oct 19, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My kodak esp5210 printer is showing paper jam remove rear access cover. clear all papper. attach cover. press ok to continue. (code 3533). ive followed the instructions but nothing changes. there never...
I've got exactly the same situation/circumstances and error code, the thing different is that my code changes between 3533 and 3528? sorry I;m no help right now but I'll be back if I solve it. Martin. (Banksy100@hotmail.com)
Feb 11, 2011 | Office Equipment & Supplies
Kodak esp 5210 code error 3533 paper jam no paper in it
Leave the rear cover off, then spam the OK button if the error message remains on. I did that maybe 10 times in rapid succession, then hear a very distinctive CLICK in the back of the printer. I replaced the cover, the hit OK, the printer cycled through startup, and now it's operating normally.
Jan 17, 2011 | Kodak ESP 5 Printer
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere?
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Sep 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Esp 5 all in one printe paper jam shows error. can't see where the paper is jammed. where do you start?
Go to www.kodak.com/go/itg and try the step by step solutions. If still you do not see the paper,call kodak @ 1800 421 6699 and they will replace the printer for you free of cost,even if Your printer is more than 1 year old,as all Kodak Esp printers are under warranty. Kodak is the best. Enjoy ,keep me posted.
Sep 25, 2009 | Kodak ESP 5 Printer
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
64 people viewed this question
k24674
jasbo
jasbo
