Question about Vacuums
Vax rapide ultra motor squealing
The main motor is making a squealing noise
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Vax rapid ultra brushes not turning
Dear Sir:
1) Test the power cord for defective wires, broker,or loose repair
2) Test the switch for open see the diagram
3) See if there are some open fuse.
4) See if the belt is broken, replace.
5)Test the input voltage motor.
God bless you
Posted on May 27, 2012
My bissell proheat 2x model 9200-A is making a high Pitch squealing noise every time I turn it on. Can’t figure out what’s wrong with it please help
Pump or motor bearing. Possibly hair around the brush roll. You will have to have it serviced to fix these problems
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_affa8ba20bcbf6c9
May 25, 2018 | Bissell Vacuums
How can I stop the squealing noise in the motor on my Sanitaire wide track commercial vacuum? It's making a squealing the minute I turn it on
Is it the motor or the brush roll? Remove the brush roll and belt and see if it still squeals. If not clean or replace the brush roll and get a new belt. Inspect the fan to insure there is not something stuck in it. If it's the motor you can try to clean it, make sure there is not something stuck in the motor causing the noise.
Jan 23, 2017 | Vacuums
I have a DC41. The power head wont turn and is making a squealing noise.
Sounds like your power head is seized or almost seized. Possibly real dirty. take apart and lubricate ends and replace the belt I feel is slipping Hence the squealing.. Clean all parts thoroughly.
Dec 02, 2016 | Dyson DC41
My vax rapid carpet cleaner no suction filter is fine
If the vacuum is still functioning, the hose is most likely clogged. Disassemble the vax and unclog. Make sure you drain before disassembling. If possible do this outside.
May 16, 2016 | Filter Vacuums
Brush makes noise when engaged, I put a new belt
You don't say what kind of noise, but if it is a bumping noise or squealing noise, make sure both ends of the brush roller are clean. It may be binding.
Oct 05, 2014 | Vacuums
Changed Belts, Changed Roller Bar, Still have High pitched, ear splitting squeal, is there a fix for this?
Remove belt and roller. Start motor- noise still there? If so noise is in the motor or caused by the motor.
Mar 09, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Vax v-091 burning smell and clunking noise
Is there something stuck inside, underneath, being turned along with the motor? burning smell usually means something got caught and the belt snapped. Not expensive and don't know if it's an easy DYI. Shouldn't cost too much to have it repaired or you can google the brand and model and the word belt, see what you find.
Mar 01, 2014 | VAX Appliances 2000 Canister Vacuum
Radiance RAD.4 Vacuum squeals when powering on or running the brush
It might be a bad bearing in the brush roll or the hall sensor is squealing. I recommend taking it to your local dealer to have it checked. Failure to fix it properly could cost more in the long run.
Jan 12, 2014 | Riccar Vacuums
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
