Question about Konica Minolta Office Equipment & Supplies
Service call 2a mem malf
Does this mean I have run out of RAM memory.....or must I call a service rep?
  • Konica Minolta Master
  • 6,680 Answers
Well model number would help and never seen just two number/letters is there a code on the control panel c-xxxx
Posted on Jan 18, 2016
Have a COMPAQ PRESARIO SR2020nx want to upgrade the memory it have 512mb how high I can go up on the memory
  • Two 240-pin DDR2 DIMM sockets
  • Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs
  • Non-ECC memory only, unbuffered
  • Maximum HP/Compaq approved memory is 2 GB
Feb 28, 2013 | Computers & Internet
What does printer code "mem test failure 1/6
Hello carmen_alley,
This means the memory test process failed due to a bad module. DIMM ( Dual In-line Memory Module ) is the memory of your printer. It is really similar to computer RAM (memory).
If the printer is under warranty I would contact the manufacturer for a repair/replacement. If it is not, I would still contact them and get further information on what DIMM you would need to purchase to replace the bad one.
Hope this helps!
Jun 29, 2011 | HP LaserJet P3005dn Printer
How to repair memory ? means that how to test the memory chipsets ? how to sholdering & removing them ?
if you shut it down open the case you wil see 1 or 2 memory cards standing up in sockets off of the motherboard.
there is a white clip on either side of the memory card you pull them back away from the memory card and that corner pops up do same for the other side after you get 1 out you can try booting up to see if it boots up if it does chances are that memory stick is good.
then pull that 1 out and try the first 1 you took out to see if it boots up on that stick if it does not boot then memory is bad.
if it is bad you will need to buy another stick of ram if memory serves me you can get a set of 2 matching cards for around $35 dollars.
If you have vista on it you can run mem test goto start then in the search box type in memory and click on Memory Diagnostic Tool and it will ask to run mem test now or the next time you start computer up.
Jun 26, 2010 | Famous Brand Dell Optiplex GX280 Intel...
Why won't my calculator type it's just the screen and the marker. won't even turn off by itself just on and does nothing.
If cursor is a checkerboard rectangle that means the memory is full. Memory must be cleared or at least some space freed.
Press [2nd] [MEM][7:Reset][1:All Ram][Reset].
Press [CLEAR] to erase Ram cleared message.
If some third-party program or game is stuck in memory, it should be kicked out of memory.
Dec 15, 2009 | Texas Instruments TI-84 Plus Calculator
Gives error memory message when tries to change
See if the cursor is checkered. If so, the calculator is out of memory.
You may have very little memory available and then wanted to create a table with a very small DeltaTbl (the table step). If the step is small, and the domain is large, very many points will have to be generated and that may make the calculator unable to comply for lack of RAM.
I suggest you free some Ram by clearing the lists, clearing the entries. To do so you press [2nd][MEM][3:Clear Entries] to clear entries, then press [2nd][MEM][4:ClrAllLists] to clear the lists.
Alternatively, you can just reset the Ram by pressing [2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER]. Then clear the Ram Cleared message and start again your table.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Dec 01, 2009 | Texas Instruments TI-84 Plus Calculator
My msi gt 735 laptop keeps freezing
freezing usually related to mem you may have bad mem or have few do you open too many files before it freez if yes then you need to increae the mem
Sep 05, 2009 | MSI GT735-024US Notebook
I have a abit v17 mobo want to get max ram (2gb) bought kingston value ram from kingston rep said it would work. also have corsair matched memory also was told by rep that it would work. I plug them in and...
Your motherboard supports DDR SDRam I assume the ram sticks you bought fit in the socket correctly and are the right way round?
Try the computer with each ram stick seperately. Just because ram is new doesnt mean its not defective.
What configurations do you have?
Are you using two corsair sticks or two kingston or a mix of both and what models are they?
Jun 19, 2009 | Computers & Internet
Dead PC, Pheonix Award Bios post code 2A, ASUS A7V400-MX SE Mothe
There is 3 reason for 2a error
Ram power supply mosfet open or short
bios programme currupt
Feb 02, 2009 | MSI Galaxy KT400 (MS-6596-20B) Motherboard
Ram upgrade
youll find your memory underneath your laptop beneath a compartment door which is secured by usually one screw.remove screw and lift hatch to view mem.either one or two slots will be available.mem looks like oblong board with chips on it.at either side of memory board are clips.push clips outwards and lift out mem board.when clips are removed mem board will lift to about 45 degree angle.to put new mem in; place board in housing ,dont worry they only go in one way ,then push down till clips secure
Mar 01, 2008 | Compaq Evo N610C Notebook
Mobo reads less ram than windows
possible that you have incompatible mem installed, the archictecture of the mem could be 32mb x 64bit could mean that the "BIOS" may only be able to see 32Mb x 8 which to me suggests that this is not the correct mem for this Motherboard, is this mem recovered from another system or an old board. Try Kingston.com and use their memory configurator to find the correct mem for your motherboard (enter the MB manuf and model)
Aug 16, 2007 | Promise Ultra100 ATA/100 Pci (ultra100 tx2...
24 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
