Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
Et1fhtxm how to remove back freezer wall - Whirlpool ET1FHTXM Top Freezer Refrigerator
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: my whirlpool fridge/freezer model ET1FHTXM forms
Turn off or unplug the refrigerator.
Open the freezer.
Remove the food.
Remove the back panel inside the freezer.
Thaw the ice and clean out the defrost drain hole.
Re-assemble the freezer parts and turn it back on.
Posted on Jul 20, 2011
Kitchenaid KBFL25ETSS00 bottom freezer refrigerator not cooling properly in the refrigerator nor the freezer. I hear the refrigerator running, but don't know if it is just the fan. It was working fine,...
You mean the temps are getting warmer? Look inside the rear of your freezer and back wall and tell me if you see snow or a layir of frost building. If so pull everything and unplug and do a manual defrost a hair drier will speed things up.Sounds like we need to use the tech sheet here but Kitchenaid will not allow me to publish here. So Skater125 you need to click here and I will send it to you only, Thanks, Sea Breeze
Sep 17, 2011 | Whirlpool ET1FHTXM Top Freezer...
My refrigerator has water running down from under freezer and there is no water in the drain pan.
Your drain line is clogged from the freezer to the pan. The drain line and drain pan are located behind the back freezer wall panel.
Aug 09, 2011 | Whirlpool ET1FHTXM Top Freezer...
My whirlpool fridge/freezer model ET1FHTXM forms ice in the back of the freezer, and water drips down to the fridge. I can't figure out what is wrong. We do not have the water hose hooked up. Could...
Open the freezer.
Remove the food.
Jul 20, 2011 | Whirlpool ET1FHTXM Top Freezer...
Water is dripping from just behind refrigerator light closer to the back of fridge.
You will need to remove the rear panel from inside the freezer compartment and thaw the drain line. It is below the aluminum evaporator coil. Once thawed, install a drain heater to prevent this from happening again. The heater is inexpensive and easy to install. It comes with complete instructions.
Kelly
Mar 27, 2011 | Whirlpool ET1FHTXM Top Freezer...
Refrigerator and freezer are not cool enough. Cleaned coils,has enough space between walls.etc.
Most likely problem is the internal fan. The fan draws air across the cooling coils and blows it into the freezer and refrigerator compartments. If it malfunctions, there's nothing to move the cold air and both sides of the unit get warm.
Nov 20, 2009 | Whirlpool ET1FHTXM Top Freezer...
Whirpool refrigerator ,water dips into the fridge compartment from the freezer
It is not supposed to be removed. try flushing some warm water through it.
Aug 01, 2008 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool top freezer problem
Check for frost build-up behind back wall in freezer. If there is a heavy frost build-up, it's not defrosting. This will restrict airflow to refigerator section and can stop fan. If fan is stuck again and it's not because of frost, replace evaporator fan motor.
Nov 12, 2007 | Whirlpool ET1FHTXM Top Freezer...
Ice Build up on back panel of top freezer.
you have a Adaptive Defrost Control problem or a bad heater...the heater is in the freezer it is a Black wire just like in an oven.. after unpluging the refigerator...Unplug the header and check the heater with a multmeter check for Continuity if it's open you have a bad header... let me know..
Aug 22, 2007 | Whirlpool ET1FHTXM Top Freezer...
Ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Aug 10, 2007 | Whirlpool ET1FHTXM Top Freezer...
ET1CHMXKQ02 TOP FREEZER REF.
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Mar 17, 2007 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
16 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
