Have a whirlpool washer wtw6340wwo bearings are bad and need replacing but when I pulled the inside drum it sounds like there is water trapped inside is this normal?
    Scholar:
  • 111 Answers
Yes the water you hear is in the tub ring the white ring at the top of the basket it is for balancing
Posted on Feb 17, 2014
gittos73
  • 244 Answers
SOURCE: Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Posted on Sep 12, 2007
  • 212 Answers
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Posted on Jun 22, 2009
SOURCE: My Whirlpool Cabrio washer has some coins trapped
They are not in your agitator. they are in the pump on the bottom left if you are standing behind the machine. Be VERY careful. That litle pump seems to be the beginnig of many leaking problems.
Posted on May 03, 2010
  • 170 Answers
SOURCE: The drum inside my ge wbvh6240fww washer is loose.
There is one bearing in rear tub/bearing is part of rear tub...To repair that unit you will need a rear tub/inner basket with spindal and possible a front tub if it damaged..If i was you I would price the parts b/c you may not want to repair it as it can be costly .....Good luck
Posted on Feb 01, 2011
  • 72 Answers
SOURCE: NOISE DURING SPIN CYCLE
You have to take the tub out, take off the rotor from the bottom of the washer, remove 4 bolts and take off the stator, take off the bearing retaining nut, then drive the 2 bearings out with a drift. I bought the bearings online for 20 bucks from a supplier (VBX). They are standard metric bearings number 6005 and 6006. I put some silicone grease on the shaft seal and drove the new bearings into place. Then reassembled, and the washer is whisper quiet.
Posted on Feb 04, 2011
Loud noises during spin cycle. Drum is eating up. All springs and shocks appear to be ok
The water seal has worn out and water has gotten into the bearings. You need to call a service tech to have it repaired. It is not a cheap repair. Whirlpool has a repair that replaces the back half of outer tub and a new inner tub or basket one in the same. Another salution is replace the seal and bearings, still a lot of labor. go to utube and a guy does to an LG, but the the repair is about the same for a Duet
Aug 08, 2014 | Whirlpool Duet GHW9150P Front Load Washer
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
I have whirlpool LHW0050PQ4 washer, after connect prower, start light is flash and hear click but no water in and is not working
Hello.
It can be tempting to ignore washing machine noises, especially if the machine is still working. But washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
4 Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer walks all over the place. vibrates like it is coming apart
the drum bearings are bad from water infiltration from a bad lip seal in the outer drum,replace them soon before it ruins the unit
Nov 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
My washer is making an awful noise and it wont spin like it suppose to what is wrong
your inner drum bearing lip-seal has gone bad and the inner drum bearings are now water soaked and rusted and need replacement,parts are cheap,but depending how long it takes to remove and clean the bearing races and time/labor you will need to check on in your area
Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sounds like a Harley when it spins, still spins though.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is not a Harley inside your washer, it is the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET HT IS TODAY NOT STARTING AND COMPUTER IS ON
i hope this helps it is the most common problem /solution for these washers. run the drain spin cycle manually if that does not work you will have to clean out the lint trap and the water left inside will drain on your floor. To clean the lint trap. there is a panel at the bottom front of the washer. along the bottom of the washer there are three torx type screws to remove the panel these will be above the drawer unit if you purcased the stand. remove the panel by lifting from the bottom. then in the center you will see a plastic cap. twist the cap to remove. this is your lint filter. it pulls out and has a cup shaped piece attached to it pay attention to how it comes out im not sure if you can put it in wrong. clean the area out. there may be some water to spill out depending on how much is clogged in your system. replace the cap once you have cleaned it out this should help with your problems.
Mar 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool heavy duty washer won't spin out the water and is leaking
yes you need to replace transmission and i think the bearinds and seal are all together on that machine
if not replace seal and bowl bearing
Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Sound in spninning cycle on whirlpool ultimate care 2
if its maling a loud rumbbling sound when it goes into spin then your bearings are on there way out m8 you can check this by opening the door place your palm on the font of the washer with your fingers on the inner drum now pull your fingers up and towards you if the inner drum moves ten this is your bearings if not then your suspension needs replacing m8
Jan 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
