Question about Health & Beauty
Broke 1 of the foot springs on Brookstone ottoman max 100
I need a Part for a Brookstone foot massager
Fixya does not sell foot massager parts.
Jul 27, 2017 | Brookstone Health & Beauty
I need a replacement cord for the Brookstone Max 2 cordless massager
i am looking for a cordless charger for MAX 2 Dual-Node Percussion. if any one has please let me know i will buy from them. or let me know where I can buy them.
Sep 06, 2014 | Brookstone MAX 2 Dual Node Percussion...
How can I get the foot rest to close without having to push it back forcefully with my feet?
the model your showing comes with a separate foot stool . you sure you have the same model
Sep 30, 2013 | Fjords 775 Bergen Recliner with Ottoman...
Recliner foot rest bolt broke and spring came off
looking for two small springs that go in the foot lift section of a lazy boy recliner. these springs allow you to raise the foot lift to different positions. these are very small springs and attach to each side of two small drum types.
Mar 22, 2013 | Lazy Boy La-Z-Boy Power Lift Recliner...
Need a water stopper for foot spa
good luck.. I got one for xmas last yr. the water stopper broke, they sent me another one and this one also broke...
Mar 10, 2013 | Brookstone Foot Baths heated foot bath
I need to replace a broken screw-in drain plug for a Brookstone foot bath/massager model # FJ1000. This was a Christmas gift and the plug broke in two
I used super glue and this repaired my drain plug. I can now used my foot spa. It's to good brookstone is not carrying a replace part when this is the most important part of the foot spa operation.. hope this helps
Jan 22, 2011 | Brookstone Health & Beauty
Volvo S40 :clutch pedal spring
The spring broke on my S40 clutch pedal too.
The old spring looks like a modified volvo part since none of the S40 clutch pedal springs at Volvo spares looks exactly the same as the one that broke. The one that broke looks similar to the replacement part that I bought, but one can clearly see that the old one was cut shorter at the other end and bent over to make it fit onto the clutch pedal mechanism. This is absolutely pathetic. I am taking it to Volvo to fix their rubbish themselves - and then they are still going to charge me R750 ($100) to replace a stupid spring! By the way, Volvo always wants the vehicle VIN number when buying spares because some of their cars (of the same year and model) use different parts - CAN YOU BELIEVE THIS! By the way, I am replacing the spring to pull the pedal all the way back - otherwise if I start the car in the mornings then the pedal is nearly on the floor when the car starts moving. If I pull the pedal back with my foot , then all is back to normal. I am scared that I may have no clutch after some time - so I will rather replace it.
Apr 20, 2010 | 2006 Volvo S40
Brookstone Max Massager failed
My Max 2 dual node just went bad. Mine is a model BST-007. All the electronics worked, but no movement of the thumpers. I opened up the unit and found the problem was a connecting rod between the rotating part and the oscillating part. Its a piece of rubber with 2 threaded rods coming out of each end. The rubber simply broke. I found the EXACT part at Ace hardware for $5.00. It was an easy fix!
Jul 04, 2009 | Health & Beauty
Increasing liquid line size from 3/8 to 1/2 on a 100 foot plus line set. How will affect subcooling charging? (R410A)
your unit is designed for a max lenth and size.confrim the max.Over sizing lines will just cause you problems of over charged for compresser capacity.in my opinion,30 plus yrs
Apr 04, 2009 | Heating & Cooling
Health & Beauty Logo
43 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
