Question about Sherwood RX-4109
Receiver won't turn on, even though the standby light is lit
  • Max Parks
    Max Parks Oct 26, 2014
    I have this problem too. Any solution?
Why won't my Kenwood theatre system turn on even though it is plugged in there is no standby light showing
Sounds like a fuse is burnt on the power supply just inside the case. Could be worse but I would start at this point being careful of high voltage in this area.
Jun 11, 2014 | Kenwood Audio Players & Recorders
Fisher receiver rs 737
No answer, but...
I have a similar problem... I can power up my rs-911, then about 3-5 sec. later, it shutsdown (standby light still on)... What in the tarnation is going on? All 3 fuses are OK.?.
Nov 18, 2013 | Fisher Audio Players & Recorders
Hello - Our Pioneer vsx-305 display screen doesn't light up anymore and we are unable to get it to work even though the on/off button appears to operating correctly (red standby light comes on). T
It is likely failing due to age.Cold solders fail, corrosion can cut a connection, a capacitor can harden and fail... a myriad of things can happen in time. Repairing it will cost more than an inexpensive replacement. The same receiver can be had on ebay from $60 up (with shipping). It is a cost benefit issue at this point.
Jan 10, 2013 | Pioneer VSX-305 Receiver
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
Str-da30es. reciever will have no sound ot times or loud buzzing noise. all functions will remain lit though
Then have it repaired , start with the standby circuits
Check relay drive circuits.
Aug 01, 2011 | Sony STR-DA30ES Receiver
Iv"e purchased a older home with an old 1984 era furnace. The pilot light will activate the burners but the burners won"t stay lit.
Make sure the thermostat is turned all they way up.
Also make sure the gas valve is turbed to on instead of standby,
Jul 03, 2010 | Heating & Cooling
Onkyo TX-DS989 not staying on
This sounds like the action of some protection circuit that is monitoring some condition or voltage that isn't within its design limits. If it was mine, I'd look for an Onkyo forum to see if others have experienced the same problem.
Sep 10, 2008 | Onkyo TX-DS989 Receiver
Sherwood RX-4109 Logo
131 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
