Question about LG Electronic LG 32LV3400 32" Class Widescreen LED
Lg 32lv3400 My tv just started having an issues with the picture today. One the left half of the screen there are two vertical areas that are sort of grayed out but you can make out some of the picture. THe right side almost looks normal except the color is off a little bit. The dark areas are blue. The top and the bottom of the tv has grayed out areas as well. I've tried different settings, reset the tv and tried different inputs. Happens even on the default picture on startup.
  • Aaron Alyea
    Aaron Alyea Feb 15, 2014
    There's also horizontal noise on the left side where the two vertical grayed lines are. Any help would be appreciated. This tv has hardly been used.
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Recently I turned on my TV and I have vertical white area with some lines that are colored on the left side of the screen. The rest of the screen looks fine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 04, 2015 | Sharp Televison & Video
32LV3400
have you been tried to look for a replacement in any hardware near in your area.
Sep 22, 2012 | LG Electronic LG 32LV3400 32" Class...
Tv 27" has only half screen picture horizional I
Possible failure of the VERTICAL SECTION of the deflection circuit. It is possible that the areas related to the vertical circuit is checked , check for weak capacitors near the output vertical drive. Also a faulty vertical coil- deflection coil- can result in half picture.
A vertical signal test can confirm.
Oct 16, 2011 | GE Televison & Video
My 42LG5010-ZD takes 30min to have clear picture when it turned on (left half of the screen is darker and has vertical lines and pictures seem traced)
I have had the same problem for a couple of Months . Bought my lg in March 2009, just had it diagnosed as the Screen . Apparently they are not Lg screens but a cheaper version called AUO optrix . my tv is a non economical repair and i am waiting for Currys to get back to me . let me know if i can be of any help. Mike
Sep 16, 2010 | LG 42LG50 42 in. LCD HDTV
I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
Screen is half picture and half black with vertical colored lines
I had the same issue. I could get the tv to work intermittantly by pressing on the boards while playing. This points to bad solder joint, so I resoldered every molex plug connector, and it nows works like a charm.
Apr 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Left Half of the screen is not working
you have a problem with your "buffer" boards inside your tv. there are several different ( 4 or 5
) ones inside. it may also be your controller board, only a tv service technician will be able to answer this question after a look see
Jan 22, 2009 | LG DU-42PY10 42 in. Plasma HDTV
My picture looks like cartoon characters from new commercials
I had recently noticed the same thing happening with mine.Then the left half of the screen turned black and has various red, green, and blue vertical lines. The right half of the screen shows has the picture just fine. It's exactly right down the middle of the screen.
Nov 18, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
LG Electronic LG 32LV3400 32" Class Widescreen LED Logo
Top LG Electronic Televison & Video Experts
richie46
Are you a LG Electronic Televison and Video Expert? Answer questions, earn points and help others
