Question about Brother MFC-7820N Printer
Brother MFC7820-N won't connect to ABBYY Finereader Pro for Mac
When I try to scan from the printer (Scan to OCR) an error box comes up that says "OCR software not installed".
  • Brother Master
  • 783 Answers
This is the software brother recommended for your printer...Download the software from the link given below: Download Brother
Posted on Feb 18, 2014
SOURCE: OCR with Brother MFC 5440CN
Abbyy finereader 6 works well with the 5440cn. The latest version is 9.
Posted on Apr 24, 2008
crayzeetrayn
  • 837 Answers
SOURCE: Using Windows vista and MFC-440CN for scanning
The OCR software comes with the printer on installation CD's .. otherwise goto HERE
Select all
Select WIndows Vista
Select English (or whatever language you want)
Click Search
Download and install the vista programs/drivers
Posted on Dec 01, 2008
CarlGehrke
  • 169 Answers
SOURCE: Not able to scan to pdf file with Brother MFC-240C
What you seem to want to do is not possible. Let me explain:
A file that has its data in the Adobe company Portable Document Format (or a pdf file) contains various objects that are described to the computer using a superset of the PostScript language, some of them can be images.
A file that comes from the scanner is first a very organized set of pixels and gets put into a more compact form by using a well known process as defined by the Joint Motion Picture Experts group. This is a roundabout way of saying that it has a format that isn't PDF.
What you CAN do:
a) open the jpeg file with a Macintosh, using the Print command from the file menu make a pdf file that has the image in it.
b) buy and install a PDF printer driver on a Windows machine, and then follow the same process as A above.
c) Use your favorite PDF creation program to make a file with the image embedded.
Carl
Posted on Dec 10, 2008
SOURCE: brother 5460cn won't scan to email,file,ocr,image
Brother Scanner error message.
After much time with Brother Tech support. The solution finally turned out to be as simple as downloading this file to reset the drivers.
http://support.visioneer.com/utilities/twain_reset.exe
Posted on May 13, 2009
SOURCE: Scan to OCR error message
After I installed the mac snow leopard I started getting this error. I went to the brother support website and downloaded the latest software to resolve the issue.
Posted on Dec 21, 2010
OCR Software for Lexmark
You should be able to assign Abby FineReader 11 Pro as the OCR software in the Lexmark software (Lexmark Productivity Studio for Windows or All-in-One Center for the Mac OS). You will need this software though and to have the monitor running to "listen" for the scan button to be pressed. You will also need to ensure your firewall doesn't block communication if you connect the X6650 through the network.
In the Productivity Studio (launch Lexmark Home), click on the Settings tab and then the Scan Destinations option. Add Abby FineReader 11 Pro to the list of destinations. Click on that option and click on the Modify button to make sure that the Application button is set and is pointing to the correct program and correct file type. Then you can go back to the all-in-one and press the Scan button. Select Scan to Computer and then choose Refresh to update the list of destination programs.
I hope this helps. The steps may be slightly different in the Mac software.
Feb 04, 2014 | Lexmark X6650 4-In-One Wireless InkJet...
I want to scan OCR with my canon MP250
hi..
The best software for that is abbyy finereader.
home version or professional.
preserve the original image scanner without changing it, staying intact, and places the OCR below the original image and can edit the OCR and image individually, creating a searchable PDF keeping the original image without changes, among other functions.
OCR PDF ICR OMR Software Optical Character Recognition PDF and Linguistic...
Sep 03, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
Lexmark P4350 All in one - I barely used this lexmark. Noticed a problem with the scanner. When I go to scan something the Abbyy Finereader 6.0 Sprint would convert some of the things scanned on the...
It's the OCR that is having problems. Make sure you have a good resolution when you scan, with good contrast. Black and white type in a nice typeface is usually 100%, but colored funky type on a colored background is going to have problems.
Apr 09, 2017 | Lexmark P4350 All-In-One InkJet Printer
CAN i SCAN A DOCUMENT TO MY PC
Yes you can, you must use OCR to do that, OCR means Optical Character Recognition, first you must scan the hard copy and save it as TIFF format and run through OCR reader, take note that convertion is not perfect, you still have to edit words that are not read correctly.
You can download OCR reader on this link: http://finereader.abbyy.com/?gclid=CK6C96aflZ4CFRgbawodiDZ2oQ
Hope this helps.
Nov 22, 2009 | Canon PIXMA MP240 All-In-One InkJet...
How do I scan documents to word. I'm only able to do photos with Picasa using new HP C4600 all in one printer
You must use OCR to do that, OCR means Optical Character Recognition, first you must scan the hard copy and save it as TIFF format and run through OCR reader, take note that convertion is not perfect, you still have to edit words that are not read correctly. You can download OCR reader on this link: http://finereader.abbyy.com/?gclid=CK6C96aflZ4CFRgbawodiDZ2oQ
Nov 18, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Wanting to scan to microsoft word
Please note that the OCR software is a third party software which is available in the Lexmark Installation CD itself. However, please click on the link given below to download the trail version of the OCR software:
http://www.download3000.com/download-abbyy-finereader-8-professional-edition-count-reg-46361.html
Apr 09, 2009 | Lexmark X1270 All-In-One InkJet Printer
OCR
To scan a document for editing purposes, you will need OCR (Optical Character Recognition) software. OCR software is not included with your model.
OCR software interprets the scanned document for editing purposes. The Epson driver alone only scans documents as image files and is not capable of this interpretation.
Some reputable OCR software programs on the market are:
Omni Page Pro
ABBYY FineReader Pro
Presto! OCR 4.0
Please understand that Epson has NOT tested our products with these programs. They do not know if these programs are TWAIN compliant and will import directly from our scanners. I recommend that you contact these companies for full compatibility information if you are interested.
Jun 01, 2008 | Epson Stylus CX9400 Photo Printer
Creating editable forms
To scan a document for editing purposes, you will need OCR software. What OCR stands for is optical character recognition. This software interprets the document on the flatbed for editing purposes. Reputable OCR software on the market are:
Omni Page Pro
Presto! OCR 4.0
Pls dont forget to rate solution, thanks!!
Apr 15, 2008 | Adobe Acrobat Professional 7.0 for PC
Apr 11, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-7820N Printer Logo
113 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
