Model ALW480DAW Amana Washer, replaced torn belt. Now whenh it goes into spin cycle the pulley on the motor spins clockwise, but this puts slack on the belt because the pulley on the tub raises and locks against bottom of tub. When I spin it by hand counter clockwise it moves very easily. Is it possible the motor spinning in the wrong direction? Or is there something wrong with the pulley on the tub?
  • 1462 Answers
SOURCE: PAV2300AWW tub spin on wash cycle
fault may be tacho on motor fallen off or round magnet that turns inside the tacho coil has become unscrewed. remove motor and check tacho. it is located at opposite end to the belt pulley
Posted on Sep 07, 2008
srsrs_1999
  • 9 Answers
SOURCE: AMANA WASHER WON'T SPIN. HOW DO I REPLACE THE BELT?
is this a whirlpool built amana? if so, its most likely a direct drive model, and when it doesn`t spin its likely a coupling between the gearcase and motor assembly...youtube has videos on how its replaced, which isn`t too complicated to do...good luck
Posted on Apr 30, 2009
  • 497 Answers
SOURCE: Washer won't spin. Belt is slipping. Tub is stuck.
The belt sounds worn out since its slipping. Change it out. Its cheap fix.
The drum brake does just what is sounds like. brakes the drum. For instance when u open the lid during a cycle and everything stops thats the drum engaging and stops the movement of teh drum. If the brake is malfunctioning two things will happen, you open the lid (assuming the safety switch is still good) or the drum will not spin at all.
Posted on Aug 24, 2009
mindreader
  • 578 Answers
SOURCE: The Maytag washer doesn't spin and had a burning
You should have a tensioner pully (a small wheel on a piece of spring steel) that hold the belt tight.
If that spring steel is broken or weak, then you will have to take the broken one to your local appliance repair parts shop and obtain a new one.
That should keep the belt tight and keep the drum spinning.... -Jim
Posted on Oct 23, 2009
jumptrout51
  • 3361 Answers
SOURCE: Replaced the belt on my Amana Washer Model
The belt is too tight and causing the problem.
Get the right size belt.
Posted on Sep 09, 2010
Washer motor spins but not the belt in spin cycle only,
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Replaced broken washer belt, but drum still won't spin.
you may have a bad bearing in a pulley,could be motor coupling. Take belt off and spin motor shaft and pulley both ways if it's free, then its more than likely not the motor. Now spin the drum with belt off and see if it does the same as with the belt on if it does it has to be a bad bearing or coupling to the drum. hope this helps
Aug 24, 2009 | Amana ALW480DA Top Load Washer
Apr 30, 2009 | Amana ALW480DA Top Load Washer
Amana dlw330 washer belt urned & broke again
Had the same problem on a machine I worked on. Changed the belt... was burnt and broken. Second time I replaced the belt, I ran it through all of the cycles and listened to it on SPIN cycle.. Although it's spinning.. it's making an extremely LOUD noise... It's the Spin bearing that is gone out. When a load is put in, and in spin cycle, the bearing is oveloaded..(being dry).. and putting extreme pressure on the motor and belt. When the drum reaches a point where the bearing just won't spin, the belt stops, and spins on the motor pulley, wearing it through.. (And smoking a great deal).. until it breaks.. again. I believe the top "Spin bearing" is about 75.00 or so.. and a BEAR to replace. Hope this helps
Feb 26, 2009 | Amana DLW330RA Top Load Washer
Model alw480daw Amana Washer, belt siezed, idler pulley free spinning, pump still rotates and works, tub spins. White hex drive under tub pulley is partially raised. Prior to problem a howling noise...
you could have a transmission porblem are you might have something in the washer basket cause the noise check basket maker sure there notting like a nail are some thing in hole of the basket an due see any oil leaking out tranmission are call a appliance service
Dec 13, 2017 | Washing Machines
Amana ALW480DAW Top Load Washer
sometimes the pump becomes stripped where the motor shaft goes into it.
Jan 22, 2008 | Amana ALW480DA Top Load Washer
ALW480DAW Washer Doesn't spin
had same problem grab agitator and rotate it clock wise and you should hear a clinging noise and try again to wash, it should be fine
cost free for now
Jan 20, 2008 | Amana ALW480DA Top Load Washer
Amana ALW480DAW washer
Remove the front panel by loosening the two screws that hold it in place. Unhook the spring that puts tension on the tension pulley. Remove old/worn belt and replace with new belt. Very important that you use the correct size belt or the motor may be damaged and remember to hook the spring back for the tension pulley. The new belt has to go around the inside of the tension pulley.
Oct 22, 2007 | Amana ALW480DA Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
