Question about Oster Coffee Makers & Espresso Machines
My oster keurig won't draw water - Oster Coffee Makers & Espresso Machines
2 Suggested Answers
  • 40 Answers
SOURCE: my keurig coffee maker will not draw water into
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
Keurig B40 prime problem?
That whole system is run with air pressure. You need to check all the valves for deposits and proper operation.
Aug 10, 2014 | Keurig Elite B40 Coffee Maker
Keurig B60 coffee maker won't draw or heat and "not ready" stays on
Handel not in positive position to start brew process.
Jan 26, 2013 | Keurig B60 Coffee Maker
Water will not draw in
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101 =-=-=-
Sep 17, 2011 | Keurig Platinum B70 Coffee Maker
Sounds like it draws water, but won't make a cup in the morning. I usually have to power cycle a couple of times and then it works fine rest of day.
heatman101
Jul 08, 2011 | Keurig Platinum B70 Coffee Maker
My b-40 Keurig doesn't make coffee it draws the water and despences it back into the water well. It doesn't come thru the coffee pod.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jun 05, 2011 | Keurig Elite B40 Coffee Maker
My B70 loses prime when drawing water from the reservoir. After a few seconds of the pump running and no water being pumped, the unit will automatically shut off. The reservoir is fully seated. Does...
The problem might be common however, Keurig does not have any repair centers around the country, nor do they have schematic drawing available :(. In order to get your problem taken care of you have to call Keurig directly 1.866.901.BREW
Sep 15, 2010 | Keurig Platinum B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
19 people viewed this question
Top Oster Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
richie46
Are you an Oster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
