Question about Magellan RoadMate 1470 GPS Receiver
I need an update but have Canadain MC. How can I get update installed in Pheonix.
Loose suction from windshield mounting. Also need update using Canadian MC.
Charging Instructions
Plug the vehicle power cable ? into the USB port on the device ?. 2 Snap the mount ? onto the suction cup ?. 3 Press the suction cup to the windshield, and flip the lever ? back toward the windshield. 4 Fit the bottom of your device into the mount. 5 Tilt your device back until it snaps into place. 2 n?vi 2405/2505 Series Owner's Manual ? ? ? ? ? 6 Plug the other end of the vehicle power cable into a power outlet in your vehicle. 7 If necessary, connect the external antenna to the traffic receiver and secure it to the windshield using the suction cups. https://static.garmin.com/pumac/nuvi_2405_2505_series_OM.pdf
Feb 09, 2016 | Garmin nuvi 2595LMT 5" GPS w/Lifetime Maps...
Updating software update could not be completed and turned them off
Hi. Which software did you use for update ? Do not ever use other software other than Pheonix because they are risky.If you want to fix it by yourself follow the instruction below....
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 2690 Flash File and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 27, 2011 | Nokia 2690 Cell Phone
I need instructions on how to mount the nuvi 200w to my windshield
To secure the nuvi 200w to your windshield with the included suction cup mount (pictured below),
center the GPS on the clip, and tip the bottom edge on the bracket. Push the top of the GPS against the top clip until it clicks into place. Hold the bracket and GPS near the windshield where you like it best. Note where the suction cup is on the windshield in relation to the mirror, etc. Remove the GPS from the mount's clip by pushing the top tab back from the top of the GPS.
Clean the windshield (or portion that the suction cup will be stuck against) with a paper towel or newspaper and ammonia solution like Windex, etc. Clean the suction cup with the paper towel and Windex, too.
Lift the lever at the base of the mount - is shown in the picture above - if it isn't already. With the mount oriented as shown in the picture above, press the suction cup against the windshield where desired with one hand. Hold the mount firmly against the glass and use your other hand to press the lever on the base back toward the suction cup and glass. Press until it lays flat against the base / suction cup. Plug the power cord into the GPS and reinstall the GPS in the mount clips as done earlier.
To remove from the windshield, release the GPS from the mount clips, and lift the lever away from the base / suction cup. Locate the tab that is connected to the suction cup edge near the lever. Pull on the tab away from the glass to break the suction seal and remove from the windshield.
If this was helpful, please rate it 4 thumbs up. Thanks & good luck!
Sep 20, 2011 | Garmin GPS
WIll not adhere to the windshield... suction cup does not hold GPS
Tomtom GPS devices come with a variety of windshield suction mounts. All have in common that the windshield and the suction cup both must be clean; use a mild soap dispersed in some warm water to remove any dirt. Rinse properly. Sometimes it helps to keep the cup a little moist.
Make sure the cup is not warped due to previous exposure to heat, and check for any nicks in the rubber. Small damage may easily make the mount unusable and you'd need to get a replacement.
Models with a lever mechanic: open the lever (cup becomes flat), press the cup against the windshield and while keeping pressure, close the lever. It will lift the middle of the cup away from the windshield, causing a vacuum.
Models with a ring around the cup base: Turn the ring all the way counter-clockwise (cup becomes flat), press cup against windshield and while keeping pressure, turn the ring clockwise 90 degrees. This requires some force, but in my experience these mounts stick more reliable,
Dec 31, 2010 | Tomtom GPS
Mount no longer sticks to windshield
Well a new mount suction cup will need to be purchased. you can grab one at radioshack.com you alsmo might want to wet the plunger then try to stick it. Or clean of that dirty windshield and try again.
2 solutions
1. clean the windshield and apply a little water to the back of it.
2. Buy a new suction cup.
thats all I hope you to stop by and rate it thanks.
Apr 16, 2010 | Tomtom ONE GPS Receiver
Installing windshield mount
there are two pieces to the mount, the mount and the cradle..the cradle snaps on the gps and the mount slides in the groves on the back of the cradle.
to attach it to the window, lift the lever near the suction cup on the bottom of the mount..press firmly against the window, the push lever down toward the windshield to lock it.
you should remove it and reattach it every few weeks to prevent it from falling off the window and damaging the unit.
bill
Feb 28, 2010 | Magellan RoadMate 800 GPS Receiver
We installed the car cradle to the windshield but receiver won't adhere to the disk. Please tell us what we did wrong. Thanks, Pat skillman
i think you mean the mount wont adhere to the disk..normally the disk is not used to mount the gps to the windshield, is more for the dash area or another spot where the suction cup wont adhere. the are rare occasions where the disk is needed for the windshield though, but its rare. try ataching it to the windshield without the disk. lift lever at suction cup, press the mount firmly against the windshield, then press the locking lever down to secure the mount. the picture below is the wount in the unlocked position.
form Magellan
This adhesive disk provides an alternative to mounting your Magellan GPS to the windshield of your vehicle. The disk adheres firmly to your dashboard or virtually any surface. Then attach the suction cup of your windshield mount to the disk.
Aug 14, 2009 | Magellan Roadmate 1200 Car GPS Receiver
There is a black disc but I do not see any instructions for using it.Does it mount on the windshield?
my Magellen came with a black disk with adhesive on 1 side. Intended to be adhered to any smooth surface (e.g., windshield). The mount for my unit includes a suction cup. So, mount black disk to windshield and attach suction cup to smooth side of black disk. Be sure disk is positioned where suction cup and bracket and GPS will have sufficient room to mount everything.
Jun 05, 2009 | Garmin nuvi 255W GPS Receiver
Sticking my nuvi 260W to windshield - after a few days often in sun [winter/spring Mass.] thesuction cup mount falls of to dashboard- risking damage to nuvi. advice? without having to use permanent...
Here is what I do. I clean the spot on the windshield very good with Windex or another good window cleaner. I also clean the suction cup surface while I am doing the windshield. Next I place the GPS next to the Rearview Mirror. and connect the suction cup. Then I take the power cord and use it to tie a knot around the suction cup mount and then I loop it around the Rearview mirrow twice leaving no slack between the GPS and the Mirror. Be sure to not block you view in the mirror. If the GPS come loose from the windshield it will just fall far enough for the power cable to catch it and will just be swiing there instead of falling to the dashboard or floor. This is kind of a Mickey Mouse way to do things but it works.
Apr 08, 2009 | Garmin nuvi 250W GPS Receiver
Garmin Suction Cup (Rubber)
Put a drop of dishwashing detergent and a few drops of water on the rubber and distribute it evenly before You mount it to the windshield. This mixture enhances the suction power and keeps the rubber soft. Repeat after 3-4 months! If You don't like the look of it on the outside of the window, put a smiley sticker on it! :-)
Aug 09, 2008 | Garmin Suction Cup Mount with 12V Adapter...
Magellan RoadMate 1470 GPS Receiver Logo
15 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
