Question about Jenn-Air PRG4810 (NP) Gas Kitchen Range
Our prg4810 natural gas oven has never heated to the temp set at on the big oven side this has been 4 years now the oven won't heat at all the small side does. How do I rectify this?
  • 161 Answers
SOURCE: Elements are heating but gas not coming on
That is because it is electric and not gas.
Posted on Aug 07, 2007
  • 26 Answers
SOURCE: over heating
Do you have a thermometer in the oven ? could be a stuck relay in the control.
Posted on Jan 09, 2008
fixyourboard
  • 310 Answers
SOURCE: My oven will not heat above 190 degrees. It just
Sound like the bake element has gone bad.
Posted on Oct 06, 2009
  • 43 Answers
SOURCE: It is slow to heat up
The oven ignitor is slowly going out...it needs to be replaced!
Posted on Oct 25, 2009
  • 2672 Answers
SOURCE: My oven is very slow to heat up now. It takes an
you need to change out the bake ignitor.when the ignitor is breaking down this is what happens,it takes longer and longer for it to ignite the flame and i've seen some ignitors burn a hole in the tub,change out the ignitor and you'll be all set,part number 74007498.
Posted on Jan 08, 2011
I have a double oven kitchenaid natural gas range model KGRS505X. When I cook in the upper oven nothing I cook will brown. Buiscuits get cooked but are still ehite when done. What is the problem?
The top oven not maintaining heat why plenty of reasons depending on age could be a weak ignitor, bad temp sensor, is the oven light on if so oven stops heating after 30 seconds any oven maintaining set point temp will brown and if left long enough burn
Jan 26, 2015 | KitchenAid Kitchen Ranges
Why does my oven on fan only heats sometimes
you must have the temp set to low, so if you cook a big thing it will get warm, & a small item wont heat it up at all, because the fan air can circulate better, which keeps the temp down.
get the manual & turn it up. if thats not the problem, then the thermostat is on its way out.
Sep 03, 2014 | Neff Ovens
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
We are having problems with our GE xl44 gas oven holding tempture and not pre heating very fast. The oven heats sometimes and then won't re-light to keep it up to needed temp. We have looked on some sites...
if that glow plug didnt work the oven wouldnt heat at all. i had one of those for about 10 years and replaced 4 of them. the oven on the thing never held the temp right and the control panel died after about 6 years... tossed it out and got an lg now. lets see how that goes. sorry i dont know much else to help you...good luck
Jul 22, 2017 | GE Profile Spectra JGB910 Gas Kitchen...
I have a Thermador wall oven (POMW301/02) when bake is selected, heats up very slowly until the pre-heat light goes off. And then the oven light stays on but it doesn't hold the set temperature. While it...
Due to the nature of the self-cleaning cycle heating the oven to above normal temperatures what likely happened is that the temperature sensor went bad. The sensor is a small rod about 6 inches long and 1/4 inches wide that sits in the back of the oven. You can remove it from the back side of the oven which will need to be pulled from the wall. Replacing it should solve the problem.
Let me know how this works out for you.
Benjamin
Dec 28, 2009 | Ovens
Takes a long time to heat water. Brand new Ge 50 gallon water heater. Once heated it right temp,just a long time to heat it and then won't maintain hot water. Is gas line to small? 3/8 copper line. Thanks
If you are using a 3/8" copper line for your gas, get it replaced ASAP. It will fail. 1/2" Black Iron is required with natural gas. 50 gallons is a lot of water to heat. Look on the heater label for the recovery rate.
Feb 27, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Amana first addition oven (approx 10 years old) will not heat
I had a similar problem with my Amana oven, also about 12 years old. It was slow to heat and sometimes wouldn't reach the set oven temp. I replaced the oven igniter on a tip that it wasn't drawing enough current to open the gas valve solenoid. That did the trick. It starts immediately and heats to the right temp. Good luck. Joe
Dec 23, 2008 | Amana AGDS902 Gas Kitchen Range
The pilot light in my natural gas oven is lit. When I turn the oven on, a secondary pilot light is lit under the oven burner but the oven doesn't heat. Is it the thermometer or the thermocoupler or...
The secondary pilot you speak of should envelope the end of the thermocouple. That heats up the fluid inside, which expands and forces fluid to open the oven gas valve. If the end of the thermocouple is enveloped in the flame, but you have no oven ignition, you will have to replace the oven valve. It is the part the temp knob is attached to and also has the thermocouple attached to it.
Sep 17, 2008 | Stoves Kitchen Ranges
Gas oven won't heat
You most likely have a defective oven bake ignitor.  Call an experienced tecnician.
Oct 09, 2007 | Ovens
Jenn-Air PRG4810 (NP) Gas Kitchen Range Logo
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
