How can I drain a top load washer stopped in mid cycle
I have had the washing machine for 4 months - inherited it with the house. it often goes off balance and I think it may be a belt, but without draining it I can't check it out - it is currently full of towels and soapy water
    Scholar:
    New Friend:
  • 111 Answers
Use a wet vac easiest way if unit is in the basement on a non carpeted floor lower the drain pump to the floor it should drain if not there is something in the drain pump or a bad bearing in the drain pump a bad belt will cause agitation problems too
Posted on Feb 17, 2014
4 Suggested Answers
Jimster
  • 240 Answers
SOURCE: kenmore top load (model # 110 82370120) drain problem
Good AM. I see here that you have a fairly old belt drive Kenmore washer. The real problem with these is that the parts for them are so very expensive anymore to get. A timer (which you may be needing) will run you around $100.00 to $175.00 depending on where you live. Very expensive repairs on these, but if you want to go for it, here are some hints to help. Sounds like you have one of three problems. First off PLEASE UNPLUG YOUR MACHINE BEFORE WORKING ON IT. Your timer may have lost or has a stuck contact inside (unrepairable in most cases) which is making it do something is shouldnt be doing in that area of the timer. This would probably be the most expensive of your repair. The next thing is it could be the water level switch could be going bad. This one is highly doubtful since it fills and stops filling, but I have heard (but never have seen) that they can short out sometimes and cause wacky operation. Both these issues can be fixed by remove the console rear panel and front knobs to remove both. The next item could be a defective wig-wag in the bottom of the unit. One of the positioning solinoids maybe going bad and sending bad signals back to the timer.
None of these problems are really hard to fix. And truthfully (even though some of these guys will be mad) you can sometimes find these parts on ebay for a halfway good price. Part numbers for each are:
Timer: 381860
Water Level Switch: 359712
Wig-Wag: 89814
Good luck with this one, and if you know how to use one, try to run resistance with an ohm-meter on your wig-wag to be sure your getting power flow through the soilnoids (you will have 2, be sure to unplug the solinoids before testing to be sure its a true test) before replacing.
Posted on Dec 06, 2007
  • 6277 Answers
SOURCE: my beko washing machine has
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 12, 2011
CoachDave
  • 14 Answers
SOURCE: HOW TO DRAIN WATER IF MACHINE SOPS AND WONT RESTART
Howdy IBAT125,
It sounds like a wet/dry shopvac is what you need. You can buy or rent one at The Home Depot. I suppose you will need to either call a repairman or look at buying a new washing machine too.
Either way, Have a Merry ChristmasCoach Dave at The Home Depothttp://community.homedepot.com/
Posted on Dec 23, 2011
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Doesn't work. Why does it stop mid-cycle?
    washing machine stopped mid cycle, won't drain : DIY - Reddit
    https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
    RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
    Troubleshoot - washer stops mid cycle, won't drain or spin ...
    ? 1:58
    https://www.youtube.com/watch?v=6Gc0ZgLD6a4
    Jun 20, 2012 - Uploaded by searspartsdirect
    Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
    Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
    Why does my washer stop half way through cycle - Ken
    Dec 18, 2015 | Washing Machines
    Our drain pump was squealing so when the washer stopped mid-cycle
    you will need to make sure that the plug is in the pump properly as if it is not the machine will not turn on, also the pump has a thermal over temp inside it so you need to make sure that it has not popped (it is self resetting unless it is faulty), so check the pump for continuity it should be about 32ohms. Also check the pump housing to make sure there is nothing in there restricting water flow
    Jul 30, 2010 | Fisher and Paykel GWL11 Top Load Washer
    Stopped in mid cycle.
    The timer went bad. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure
    Nov 12, 2009 | Maytag Bravos MTW6600T Top Load Washer
    My whirlpool duet front load washing machine stops in mid cycle
    F21 = LONG DRAIN ERROR
    If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
    Press PAUSE/CANCEL two times to clear.
    Procedure:
    1. Check the drain hose and make sure it is not plugged or kinked.
    2. Unplug washer or disconnect power.
    3. Check the electrical connections at the pump and make sure the pump is running.
    4. Check the drain pump filter for foreign objects.
    5. Plug in washer or reconnect power.
    5. If the above does not correct the problem, go to step 7.
    6. Unplug washer or disconnect power.
    7. Replace the pump.
    Alternative Procedure:
    If the machine cannot be forced to its diagnostic mode then:
    1. Disconnect the washer from the power supply and water supply.
    2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
    3. Remove the Molex connector from the water level switch / pressure switch.
    Refer to the picture below.
    4. Reconnect the power supply but not the water supply.
    5. Power the machine. The machine will enter diagnostic mode.
    6. Power off the machine.
    7. Replace the water level switch / pressure switch.
    8. Reconnect the water supply.
    9. Power on the machine it will work without error
    Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Washer stops in mid cycle
    This is probably normal. There is a natural pause between agitating and draining, and again between draining and spinning. Hope this helps!
    Feb 04, 2009 | Whirlpool LTE5243D Top Load Stacked...
    Stops mid cycle
    CHECK DRAIN PUMP AND DRAIN HOSE FOR RESTRICTION
    Jun 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
    Washing Machines Logo
    29 people viewed this question
    Top Washing Machines Experts
