Question about Microwave Ovens
Nokia Mobile company
My name is Bonolo Phaswana, I bought a Nokia Lumia 510 phone, Never was it mentioned that the phone does not support the *111# service for the Vodacom network. I was informed after I asked for help at a vodacom shop by a IT specialist that the fault is with nokia, as they made fAults with the phone and that I should rather buy a windows 8 phone, Its been a year I cant even use my points or have other services to my advantage. really this disappointing. I have been a loyal customer for Nokia for over 7 years now, THIS TIME I AM NOT IMPRESSED.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Try jailbreaking it. Put a different (but free) OS on your phone if you can like cyanogen (android). hope this helps.
Posted on Feb 18, 2014
  • 579 Answers
SOURCE: Microwave convection oven repair needed
Check the internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. I tlooks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Posted on Jan 01, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven went dark.
It may be possible that the magnetron overheated and its thermal cutout or thermostat tripped.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Aug 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave bulb replacement
The oven will need to come down from the wall so the outer cover can be taken off. Then you'll see the light socket(s).
It's recommend due to the weight and awkwardness of the oven that two people do this job.
If you don't still have your installation instructions, you can download them here, but you should use you full model number, as opposed to the base KEM378.
This uses a fairly common halogen bulb, but I'm not sure of the wattage. It should be marked on the bulb or on a tag near the reflector.
You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 01, 2008
Obertelli
  • 3006 Answers
SOURCE: I have a Panasonic combination
This is a really common problem with all models which use the same door assembly.My first one failed after three months and was repaired by Panasonic under warranty. It failed again just after the warranty expired and the company were not interested in helping so I took the door apart to see what's wrong. (Remove outer oven casing, undo hinge plates from oven body and withdraw door. Unclip inner brown/black plastic seal, and then unscrew and remove metal shielding and door glass).
Basically, there's a design fault. A really weedy and poorly designed plastic post is the anchor point for a strong door spring catch, and the post is part of the inner door casing moulding. The plastic itself is not amenable to being glued and where the post breaks there is too little area for glue to have much effect even if it could work. The plastic is an ABS type of material and this is well known for being difficult to use glue with.
At first, I shelled out for a new outer door casing from a parts supplier, when it arrived I was really disappointed to see that the design was unmodified. As expected the door failed a few months later despite being careful to always gently close the door.
I went back to my old door and after a few experiments I temporarily glued the post with superglue just to hold it in place, and then I packed carefully around it with two part car body filler, ensuring that it would not foul other components when the door was reassembled. In the end, I still had to carve away some filler afterwards to enable reassembly.
A year later and it's still working, but the stress point has now been transferred to the outer door casing where the top of the post engages into a moulded anchorage. This is now cracking showing that this is also under-engineered and that the door spring is far too strong. The inner microwave seals are fine though, but it clearly indicates a really poor design.
Since then, my parents Panasonic has had the same fault (a different model but using the same door) as have a couple of friends and neighbours. Some have had warranty repairs, a few have been binned and replaced with a different brand and I've repaired some. It's a real shame as the basic ovens are very good, just this **** door lets everything down and despite loads of internet reports of a problem the company won't admit there's an issue.
I don't advocate this at all, but one neighbour was so angry with Panasonic's attitude after his second (one month out of warranty) failure that he went and bought the exact same model new. He then dismantled and thoroughly cleaned his broken door, reassembled it and switched it onto the new oven and returned the new one to the store the same afternoon for a full refund, claiming the door broke as soon as he used it. He's used the same trick twice since and has stuck with this model as there are no others on sale in the UK with the same specifications and dimensions. I do not condone his actions as they're fraudulent, but I do understand why he's done so.
Posted on Jun 30, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: 63792 reports F2 error as well
An F2 error on these is a shorted keypad (either the main keypad or the transparent one in front of the tocuh screen). In some cases, this is a pretty easy do-it-yourself repair. Please contact me for an estimate and DIY tips.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for FREE help & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 11, 2009
I have an older free spirit treadmill with the model muber partially scratched off. I do have a serial number and a c22.2 number which I dont know what it is. Somewhere along the machine it mentions r
Free Spirit, a company owned by Sears but housed in Canada You can contact them for assist
Contact Us
Corporate Office
3000 Nestle Road
Jonesboro, AR 72401
Phone: 800-258-4555
Fax: 870-935-7611
Jan 01, 2015 | Microwave Ovens
FRENAGE BREWERY COMPANY does this company exist
No... This is a fake company as per the following reason.
1.No information available about this company apart from their website.
2. All information about this company on internet is available after 22/dec/2013.
3. Website was created in bangalore and operated in bangalore.
4. No person in canada has ever visited their website.
5.Contact number given to the website is a personal mobile number (+91.7050746119) rather then cooperate number.
6.Product(seagram) which they show in their company has no idea about this company.
7.Finally the website is copy of real company Brick Brewing co limited link: http://www.brickbeer.com/
This is a fraud company created in intention to make money by saying that they will provide job in canada.
Jan 19, 2014 | Microwave Ovens
What company does William Miller work for?
That's me. I am a self-employed, independent electronic service technician with just shy of 30 years' experience.
My repair work is mail-in only.
Some may think I have a company named MicrowaveDisplay.com, but that's just the web site.
Dec 25, 2012 | Microwave Ovens
Looking for the manual for this model 2115 cooks stainless steel microwave convection oven.
Got this from the "Answer bag" website:-
Cooks is the store brand name of appliances sold by JC Penny. The appliances are made for JC Penny in China by Sensio, an appliance company who also manufactures kitchen appliances for Chef Gordon Ramsey and the El Paso Mexican brand, among others.
Source:
Sensio
U.K. Telegraph: Gordon Ramsey Launches Cookware in Argos
International Housewares Association: Sensio Profile
More Information:
Fante's Kitchen Wares Shop: Links to Manufacturers
Consumer Reports: Cookware & Cutlery
Then clicked onto the Sensio website, couldn't find details or downloads for your over but on their contact page there's a phone number and an email address.
Customer service phone number: 1.866.832.4843 / info@sensioinc.com
Have a crack at one of those.
Jan 25, 2012 | Microwave Ovens
I bought Cook's Essentials cook ware many years ago and I have 2 pieces that need to be replaced but i have no idea how or where to send them to be replaced under lifetime warranty, can you help.
There doesn't apear to be a web site for the company. I can only suppose that it is just a trading name.
Try speaking to Argos or QVC.co, for advice but "Lifetime Warranty" doesn't mean anything. The LifeTime of the product could be 21year for instance and probably won't cover anything that has broken.
Have a try, nothing to lose.
Jan 02, 2011 | Microwave Ovens
Looking for a Emerson Microwave Manual # MW8119SBM
go on line to the company & see if u can't purchase manual, or write the company. Company name & often address or location is located on plate that model # is on. Hope this helps.
Sep 12, 2010 | Microwave Ovens
There is smell of burning rubber in the microwave? where can i get it serviced? i live in kochi india
The microwave would have had some booklets with it when it was sold. check them up and see who you can call. If its a reputed company then the people might come home to repair or might have a store nearby. Otherwise you ll have to look up the company on the web and contact them. Google will return any results with the company s name and kochi. Try it out
Jul 24, 2009 | Sharp R-1871 Convection Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
