Question about NEC MultiSync FE2111SB 22" CRT Monitor
NEC FE2111sb multisync 21 inch monitor troubleshooting
My NEC FE2111sb multisync 21 inch monitor died last night. At first it just went orange (the light) and now it is flashing the light on my monitor. It was working fine yesterday and now it is doing this. What can I do to fix this?
Thanks!
Jeanna
  • gnmorrison Jul 01, 2008
    I have the flashing green LED right now. It was never orange though. This happened the other day, but while flashing it just powered on. I've shut it off a few times since then, but when I came home an hour ago and I tried to turn it on, flashing green LED again.
    I've looked at a few of the more technical support sites where people had the same problem. Sounds like a capacitor may be off by a few farads and will need to be replaced. As far as I know, caps aren't too expensive, but replacing one yourself would require finding the defective one, removing the solder and soldering the new one in place.
    I'm going to call NEC tomorrow and see what they say. I don't want to give up this monitor. It's bulky and awkward, but better than about 90% of the LCDs I've used.
    Problem Solver:
  • 18 Answers
The symptoms you describe sound like the monitor is going into 'greeen mode' - that is to say, it sees no video signal present. first, try another monitor ti isolate and make sure the problem is the monitor. check the vga plug pins [especially if you have recently moved and/or disconnected and re-connected the monitor. ifnent, 'wiggle' the vga cable, as i have seen the actual cable fail frequently. if it is the monitir, vheck the solder connections on the neck boar [the circuit board that the crt plugs nto. if all looks well, and it is a component, such as a cap [and yes, they're cheap, and there's a wide tolerance in value- that is you can replace it with one as much as twice the value in microfarads, and just ake sure you use one with a voltage rating at least equal to, and better yet, exceeding the rating of tf the original. good luck
Posted on Mar 07, 2009
Me too!
Posted on Feb 23, 2008
My NEC vt 595 was working fine last night and today i went to turn it on the status and power light started flashing red and orange and there is no picture
if Power is flashing orange - then it's cooling down
if Status is flashing red - then there are 4 flash combinations.
1 cycle (0.5sec On, 2.5sec Off) lamp cover or housing error
2 cycle (0.5sec On, 0.5sec Off) temperature error
4 cycle (0.5sec On, 0.5sec Off) fan(s) error
6 cycle (0.5sec On, 0.5sec Off) lamp error
Which is your condition?
Mar 18, 2011 | NEC VT595 LCD Projector
My NEC MultiSync LCD1970NX monitor went black while in use and green power light is flashing.
If the system is booting up and if you see the "NUM LOCK" key lighting up in your keyboard then the system is working fine. The problem is with your graphic card. Check and repalce it. If not, the problem is with your monitor. Check the warranty and ask for a replacement.
Mar 03, 2011 | NEC MultiSync LCD1970NX-BK (Black) Monitor
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Screen off center
try updating the latest driver for your video and bios. try connecting your laptop to external monitor
if both of this didnt solve your problem, i suspected you lcd screen is faulty and need to replace.
May 29, 2009 | NEC MultiSync XE21 (White) 21 in.CRT...
NEC monitor drvier please !!
if you monitor turn on then not problem with monitor. it's related with your computer.
and what does it do when turning it on?
need more info for exact answer.
Mar 25, 2009 | NEC MultiSync FE991SB 19" CRT Monitor
NEC 17'' Multisync CRT monitor does nothing when turned on
the green is working ok but orange is usually waiting for an input from the pc (no input signal)
Mar 08, 2009 | Computers & Internet
NEC MultiSync FE2111SB 22in monitor problem
a blinking green light usually indicates no video signal. check your cables, and if you have another computer, try it on that. otherwise, carefully check your vga signal cable, and the connections on the neck board [where the crt plugs into]
Aug 11, 2008 | NEC MultiSync FE2111SB 22" CRT Monitor
Driver for NEC Multisync XE21
Normally if you set the refresh rate to match what the specs are (mentioed above), it should go you working.
Jun 07, 2008 | NEC MultiSync XE17 (White) 17 in.CRT...
NEC MultiSync FE2111SB 22" CRT Monitor Logo
280 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
