Question about Garmin Approach G3 Handheld GPS Receiver
When started, GPS location not recognized - Garmin Approach G3 Handheld GPS Receiver
GPS isn't recongnising the satellite
No possibility. Satellite is not recognizing the GPS. It is possible.
May 14, 2016 | Cars & Trucks
Unlock garmin 1390t gps forgot 4 diget pin
    • 1 Enter your four-digit personal identification number that you used to lock your Garmin GPS. When your Garmin GPS is locked, you need to enter the four-digit PIN every time you turn the device on.
    • 2 Drive to the security location that you set when you locked your Garmin GPS. Turn your Garmin GPS on and pull the GPS antenna up so that your GPS is able to acquire the satellite. Once your GPS recognizes that you are at your security location, it will unlock itself.
    • 3 Contact Garmin if you forgot your PIN and security location. You will need to send your GPS to Garmin to have it unlocked. You will also need to send a valid product registration or proof of purchase for Garmin to unlock your GPS. Call Garmin at (800) 800-1020 and get the shipping address and specific instructions from an authorized Garmin representative.
Jun 09, 2011 | GPS
How to do I reset for a Triton 400 to recognize current location
Normally the GPS will be positioned over your current location, once you have a GPS FIX.
Use your profiles and find GPS FIX and make sure it is ON.
If the black caret ^ moves but the map does not you have a problem with the T400.
When in trouble enter the ESC button and see if your problem goes away.
Sep 13, 2010 | Magellan Triton 400 Handheld GPS Receiver
Locked up
Hello :
Try this solution please :
1:Enter your four-digit personal identification number that you used to lock your Garmin GPS. When your Garmin GPS is locked, you need to enter the four-digit PIN every time you turn the device on.
2:Drive to the security location that you set when you locked your Garmin GPS. Turn your Garmin GPS on and pull the GPS antenna up so that your GPS is able to acquire the satellite. Once your GPS recognizes that you are at your security location, it will unlock itself.
3:Contact Garmin if you forgot your PIN and security location. You will need to send your GPS to Garmin to have it unlocked. You will also need to send a valid product registration or proof of purchase for Garmin to unlock your GPS. Call Garmin at (800) 800-1020 and get the shipping address and specific instructions from an authorized Garmin representative.
PLEASE DON'T FORGET TO RATE !
Apr 15, 2010 | Garmin StreetPilot C330 GPS Receiver
How can i remove tunes from a garmin 765t mp3
Connect the GPS to a computer via supplied USB cable and:
  1. The GPS will be recognized as a new drive. If a pop-up appears choose "Open Folder To View Files." If not, click the "Start" button, then go to "My Computer." The double click on the new drive.
  2. When the hard drive opens, locate and open the MP3. There will probably be a couple of sample songs, you can delete them to free up additional space if desired
  3. Simply select and delete existing MP3s in the directory. Alternately, you can drag and drop MP3s into the directory to add them.
Oct 07, 2009 | Garmin n?vi 765T Car GPS Receiver
Not recognizing the code.
Your only options for unlocking a PIN locked Garmin are:
1 - Enter the correct PIN.
2 - Take the unit to the location at which the PIN was originally entered.
3 - Send the unit back to Garmin.
Jul 01, 2009 | Garmin StreetPilot c550 GPS Receiver
I want to put my GPS coordinates on the address line because it won't recognize my home address. Any way to do that?
Tap screen, tap Change Preferences,tap right arrow, tap Change Home Location, tap right arrow, and finaly, tap Latitude Longitude to set coordinates for your home location.
Apr 01, 2009 | Tomtom One XL GPS Receiver
How to change home map on used Garmin i3 street pilot
Hello. Had the same problem and just solved it.
Do this.
Tools -> Manage My Data -> My Locations. Position to Home and then click Manage -> Change Location ..
Cheers.
Sep 15, 2007 | Garmin Map Source City Navigator
Garmin Approach G3 Handheld GPS Receiver Logo
52 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
