Question about Keurig B150 Office Brewing System
Only brews a partial cup
Even after cleaning with vinegar, says the water flow is interrupted
3 Suggested Answers
  • 60 Answers
SOURCE: Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Posted on Mar 26, 2010
heatman101
  • 43501 Answers
SOURCE: When brewing a cup of coffee, part of the water
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Sep 07, 2011
Gd morn. My CBC5200PC will brew only a partial amount of the water. This morning it stopped at 6 cups, then I coaxed it by turning it off and on,, but would only drop a cup of water at a time
Brewing Problems
Another common problem that can occur with the Cuisinart coffee maker is it will stop brewing, even when there is water ready to be transformed into coffee. The machine still turns on and works like it should, but does not continue brewing an entire pot of coffee, and acts like it has finished brewing even when there is still water sitting in the bin. This type of problem is pretty common among various coffee makers, and usually occurs when there is a problem inside the machine.
One of the best ways to fix this problem is by flushing the coffee maker out with a vinegar solution, which can be made with equal parts of vinegar and water. It should be poured in the same place as the water that is ready to be brewed, and will help to clear out the machine and make it ready to start brewing again. This problem is usually caused by calcium building up within the machine, and the vinegar helps to clear out any blockage to help it start running smoothly again. (From. Google Search)
May 17, 2017 | Coffee Makers & Espresso Machines
I cannot get my coffeemaker to brew. Do i need to replace filter before it will brew, or clean with vinegar?
Run a couple cups of white vinegar through it (just like you were making coffee). Don't use a filter. You can use the same vinegar over again if necessary.
If calcium build-up is the problem, you will see lots of little flakes in the used vinegar. Continue running vinegar through it until you are sure the flakes have stopped, then run a couple full pots of water through it before you try making coffee.
Mar 10, 2015 | Coffeemaker Coffee Makers & Espresso...
How can I fix my coffee maker when the water resovior will not drain?
Try cleaning it by brewing a 50/50 mixture of white vinegar and water. You may have to run it through a couple of cycles with a fresh mixture each time. Then rinse by brewing water only a couple of times. Over time calcium and lime builds up inside the tubes of the machine and restricts the flow so this should be done once every few months or as needed. The vinegar will loosen the mineral deposits and flush them out.
Jun 01, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
Mar 25, 2010 | Keurig B60 Coffee Maker
Brewing time is too long 20 min for 6cups
You have an obstruction in the feed line to the heating element. I found coffee grounds before the check valve. I had to take the bottom off it which I am sure the manufacture wouldn't approve of but I was at my wits end and ready to toss it. I just brewed a full pot 10 minutes!!!
Aug 18, 2009 | Cuisinart DCC-1200 Coffee Maker
Keurig only brews about 2-3 oz. of coffee.
Doesn't sound like a descaler issue. I am having problems with mine and noticed that water is flowing back into the reservoir when it is pouring into the coffee cup. I think there is a valve that is not closing properly.
Aug 01, 2009 | Keurig B50 Coffee Maker
I have a cuisinart Grind and Brew with a glass carafe - not pictured above. The self clean button keeps lighting up and I don't know how to run the clean cycle.
Fill the water reservoir with 2 cups distilled white vinegar and 2 cups water - then press the self-clean button. If the water doesn't start going through after a minute or two, just turn the machine on like you were brewing coffee. After the vinegar/water soultion has gone through the machine, brew one cycle of plain water to flush out the vinegar. If the self-clean light stays on, just unplug the machine for longer than 20 minutes, and the light should not come back on when you replug the machine. Good luck!
-Tha Mp3 Doctor
Feb 26, 2009 | Cuisinart Grind and Brew, 10 cup, black
My cuisinart cod 4000 doesn't use the last 2 cups of water in the reservoir when brewing. Any ideas on what would cause this and how to fix it? It is less than 1 year old.
I would go ahead and clean the unit with vinegar and water - I would use 2 cups vinegar and 2 cups water, although the manual suggests 1/3 part to 2/3. Just brew the vinegar/water like it was normal coffee. Don't forget to take out the charcoal water filter, or else it will get soaked with vinegar. Also, make sure the 1-4 cup button is not pressed, if your variant of the model has a 1-4 cup setting. Good luck!
-Tha Mp3 Doctor
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Partial Brew
My experience has been that an aggressive cleaning, by "brewing" 6 cups of straight (undiluted) vinegar will eliminate this problem.
Jun 24, 2008 | Cuisinart DGB-600 Coffee Maker
Keurig B150 Office Brewing System Logo
214 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
