Question about Kenmore Dryers
Dryer work but have no heat/kenmore mod:110 70982990
    Habit-Forming:
    New Friend:
  • 82 Answers
A burned out heating element is the most common cause. Other electrical components are also possible. Check the element first.
Posted on May 22, 2014
  • 66 Answers
SOURCE: dryer wont heat
if you already replace the heating element . it may be loose or it get damage . you can open the dryer from the back . and ck if the 220v is coming in . or the thrmstate is no goog . most likely you heater when dad again. good luck . and let me know if you need to find any parts for it .
Posted on Apr 04, 2008
AlmostBob
  • 550 Answers
SOURCE: dryer stpped working
with power disconnected
if any wire disconnected before any test, reconnect & test dryer, reconnect wires after each test
disconnect wires from start button and test, conduct when pushed, no conduct when release
if fail replace start button test dryer
disconnect wires from door switch and test, conduct when pushed, no conduct when release
if fail replace door switch test dryer
follow leads from start button to relay(relay is first device connected to start button), and make sure all wires connected at both ends. If any wires disconnected, test dryer
locate thermostats and thermal fuses on fan housing and ducts
individually disconnect wires from each and test. conduct good, no conduct fail
replace any failed thermal fuse or thermostat test dryer
if all prior test OK
replace relay, test dryer
Posted on Oct 12, 2008
SOURCE: gas dryer wont heat
You may have a blockage somewhere in your exhaust line. I had to have my professionally cleaned, but it fixed the problem.
Posted on Dec 11, 2008
vickygomar
  • 460 Answers
SOURCE: Kenmore electric dryer Mod. 100.66662501, type
Assuming that the fuses you speak of are the external pair, and not the internal motor or timer resets:
Check the fuse holder for corrosion on the plates. Often the fuse is not properly seated because of this build-up and therefore has an intermittent connection. This will cause the fuse to either heat up, or overload; ultimately failing.
To remedy this, turn OFF the breaker, or main switch if necessary, and fix a wooden dowel with a piece of emery cloth (or sand paper) on the end. Remove any visible black corrosion from the contact plates.
Finish with a spray of WD40 to protect the plates and fuse end.
Replace the fuse, ensuring that it's tight, reinstate power and try again.
Was this  helpful?
Posted on May 13, 2009
jsrock516
  • 5911 Answers
SOURCE: Dryer works but will not heat up, can I replace
To answer your question, "yes", replacing a heating element is a simple repair that you should be able to perform yourself. However, the problem may/may not be the heating element. There are several things that can cause a dryer no heat problem.
If the dryer runs, but does not heat, the first thing you need to check is the wall receptacle for the proper input voltage. A reading across the two hot leads (left and right slots) should read 220-240 VAC. If this reading is incorrect, check your breaker panel. Some homes have the dryer circuit on two breakers, vice one single 220 breaker. If the voltage at the receptacle is good, unplug the dryer and remove the cover on the terminal block in the back of the dryer. Plug the dryer back in and take the same voltage check at terminal block across the RED and BLACK wires. You should see 220-240 VAC if good. If the voltage is bad at the terminal block, but good at the wall receptacle, you have a bad power cord. If the voltage is good at the terminal block, then the problem is internal to the dryer.
NOTE: The reason a dryer will still run if the input voltage is incorrect is because the dryer drive motor only uses 110-120 VAC, while the heating circuits require the full 220 service. So, if you are missing a portion of your input voltage, the dryer may exhibit the symptoms you have.
If your problem is with the dryer heating circuits, the following link explains what to look for and how to troubleshoot:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. The number one cause of dryer heat related problems are caused by poorly installed, kinked, or clogged dryer ventilation. Your heating circuits are located on the lower right side of the dryer cabinet under the drum. You will need to remove the lower kick panel under the door to access. The elment is inside the heater box while the Thermal Cut-Out (TCO) and Hi-Limit Thermstat is located on the outside of the heater box to the left of the element. The TCO is located in the rear, while the Hi-Limit Thermostat is located near the heating element terminals. NOTE: Make sure the dryer is unplugged while taking any resistance checks. Make sure you disconnect any terminal wires before measuring to ensure accurate readings. If you have any questions, please let me know. I hope you find this information helpful.
Posted on Jul 13, 2009
Sears Gas Drier Mod 76912 14 years old. No heat.Glow coil works.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Aug 03, 2011 | Kenmore Dryers
The dryer is taking a couple of ctlces to dry items. I opened the door and depressed the button, so that the dryer would run while I was checking for heat. The heat comes on but then after a couple of...
heatman101'
Mar 12, 2011 | Kenmore 72802 Gas Dryer
Mod number 8866290 does not have warm air. Help
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 16, 2011 | Kenmore Dryers
NO HEAT ON KENMORE ELEC. DRYER MOD. 110.64992300
There could be a number of problems with your dryer causing it not to heat. Here is a tip that I wrote about your problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
Heatman101
Mar 10, 2010 | Kenmore 64992 Electric Dryer
Sears kenmore dryer not heating mod.11060202990
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
kjkgj
Feb 08, 2010 | Whirlpool LGR7646E Dryer
Kenmore Dryer-Mod.#11066514694-won't spin or heat
This could be caused by an internal thermal overload switch. These usually have a limited life span in any appliance that uses heating elements. Try to locate the overload switch which usually looks like a small diode or resistor. You can determine if this is the cause by bridging the switch with a piece of wire, then trying the dryer once more.
Best wishes,
Graemevm
Jun 06, 2009 | Dryers
Dryers Logo
90 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
