Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Hard to start
Will start if you hold hand over carb
  • 36 Answers
Sounds like it is sucking air. Rebuild carb.
Posted on Mar 03, 2014
Won't idle will run wide open if choked must hold hand on back of carb to start it
Theres a blocked orifice in the carb- Cleaned or not. Check by running thin wire or fish line thru all orifices
Oct 04, 2015 | Motorcycles
Clean carbs will start with choke out but dies when given gas if hold hand over air cleaner will respond to given more gas
Hi double check carbs the pilot jet must be blocked. There is are a very fine hole through these jets
Apr 12, 2015 | GAS Motorcycles
Can I do a DIY fueline replacement?
Yes small clear lines cheap cost but close hand Clarence..you may have to remove the carb not a hard job..a couple of screws hold the carb on once loose you can disconnect the old ones and replace good luck.
Sep 23, 2014 | Garden
Starting hard
Hi Ted, most likely the choke is not coming on fully. To fix this adjust the choke cable or if the choke is on the throttle adjust the throttle cable. Regards Phil.
Jan 01, 2013 | Cub Cadet Street Sign- tractor lawn riding...
My atc is really hard to start. What do i do?
It just need to clean the carb.
Try to pull down the air filter, choke the carb by putting your hand on the air intake and start it.Notice that fuel goes into your hand, try doing that 3 times to dislodge some dirt in the jettings.Otherwise, you have to pull down the carb and clean/overhaul it.
Hope that helps!
Dec 21, 2011 | Motorcycles
My 1984 rx7 starts when choke is pulled out. WHen engine warms and choke pulls in it stalls out. when trying to start it back up the engine sounds like it's trying to start, and it does when I pull the...
try removing air filter and spaying CARB CLEANER in carb while holding open intake rub thouroughly with hand in side carb, start vehicle and run... spray more cleane and by hand throttle open and spray reinstall filte and runner good on open stretch of highway.
see how that works
Apr 27, 2010 | 1983 Mazda RX-7
How do you set floats on a 60 hp johnson
Hold the carb in your hand in the position it is in on the motor the float and the carb body should be in line with each other. What year and what type of motor,these directions hold true for 90 percent of outboards. Jim OMCRetired Mech
Jul 06, 2009 | Boating
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
52 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
