Question about Canon MP12D Printing Financial Calculator
How do I load the paper into the machine - MP12D
Paper will not pull itself through
3 Suggested Answers
SOURCE: Loading paper
Cut paper at an angle and insert and push into back slot with tip of angle (apex) to the right of machine when facing it. It should engage number wheel when you hit addition sign, You may need tweezers to pull it thru if it doesn't advance.
Posted on Jan 23, 2009
5/14/09-
Okay...It took me forever to figure it out but I finally got it. On the back of the calculator there is a slot (back meaning where the black cord is connected to the calculator). fold the paper to make a perfect straight line. feed the paper through there and press thee upward arrow. it should work.
hope I helped...=)
Posted on May 14, 2009
I can not get the paper to feed in my Unisonic XL-1149 calculator
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
try this otherwise see the manual and make sure you are not using generic paper roll only use specific paper because the Chinese knock off paper is to thin
Mar 01, 2018 | The Office Equipment & Supplies
HP OfficeJet Pro 8600 tray can't be inserted all the way. Stops with 3 inches of tray sticking out.
  1. Grasp the handle on the front of the input tray, and then pull the tray towards you to open it.
    Figure 1: Pull out the input tray
  2. Slide the paper width guides out as far as possible.
  3. Remove all paper from the paper tray.
  4. Inspect and remove any foam or tape packaging materials in the paper tray.
  5. Insert a stack of unused, plain white paper (with the print-side down) in the center of the tray.
    Figure 2: Load paper into the tray
    CAUTION: Do not load any paper above the solid red lines on the sides of the tray. Do not use torn, wrinkled, perforated, wet, or folded paper. Make sure to remove all paper clips and staples before loading the paper. Figure 3: Stack label height
  6. Slide the paper guides in so that they rest against the edges of the paper, and then insert the tray into the product and push it forward until it clicks into place.
    Figure 4: Slide the paper guides in and reinsert the tray into the product
  7. Pull out the tray extender on the output tray.
    Figure 5: Pull out the tray extender on the output tray
Step two: Load paper in optional Tray 2
Tray 2 is an optional accessory. Follow these steps to load paper in Tray 2.
NOTE: Tray 2 supports only plain letter or A4 paper.
  1. Grasp the underside of the tray, and then pull out the tray from the bottom of the printer.
    Figure 6: Pull out the tray from the bottom of the printer
  3. Load a stack of unused, plain white paper (print-side down) in the center of the tray. Make sure that the stack of paper aligns with the engraved lines in the tray.
    NOTE: Load Tray 2 with only U.S. Letter or A4 plain white paper.
  4. Slide the paper guides in so that they rest against the edges of the paper.
  5. Carefully reinsert the tray into the printer, and then push the tray forward to close it.
    Figure 7: Reinsert the tray into the printer
  6. Pull out the tray extender on the output tray.
    Figure 8: Pull out the tray extender
Load specialty paper Follow these steps to load specialty paper such as card stock, envelopes, photo paper, or labels.
Before you proceed, verify that your printer supports the specialty paper on which you are attempting to print by viewing the product specifications . If the size, type, or weight of the paper is not available, the printer does not support printing it. Also note the tray loading capacity for the type of paper on which you are attempting to print.
Sep 27, 2013 | HP Officejet Pro 8600
Paper Bail Load lever advances paper all the way out of machine. How do I change this? dianna
With the machine on pull the paper bail forward, let it run until it quits, then use the paper down button and run the paper back 20 lines or so, hold the code button and pull the paper insert forward. That re-sets the stopping place, keep doing this until you get the paper insert to stop where you want it.
Jul 14, 2010 | Lexmark Wheelwriter 3500 Typewriter
My machine is not pulling the paper to print. It keeps asking me to load paper when paper is is already in there.
try to load more paper..some machines do not "feel " the paper unless there is a considerable thick bundle..
otherwise..it is just a mechanical problem ..just do not reach to the paper to grab it ..try it ..and let me know if it works ..
Feb 02, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Paper jammed
Paper Jams
Cause 1 : Paper jams in the paper output slot/Auto Sheet Feeder.
Action : Remove the paper according to the following procedure.
a) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will be ejected automatically.
b) Reload the paper into the machine and press [OK].
* If you have turned OFF the machine in step a), you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Cause 2 : Landscape Credit Card-size Paper Jams inside the Machine.
Action : You cannot load Credit Card-size paper in the landscape orientation.
If <PAPER JAMMED> or <E3> is displayed on the LCD/LED, remove the paper following the procedure below:
a) Load Credit Card-sized paper in the Auto Sheet Feeder one sheet at a time.
Do not load it in the landscape orientation.
b) Press [ON/OFF] on the machine to turn OFF the power.
c) Press [ON/OFF] again on the machine to turn ON the power.
The paper is fed and the jammed paper is ejected accordingly.
If you cannot remove the jammed paper or the error still persists, contact a Canon service representative.
Hope this helps
Please rate my response.
Thanks
Have a good day.
Dec 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How do I remove paper jamed in the printer?
Paper Jam :
Cause 1 : Paper jammer in the Paper Output slot or the Rear Tray.
Action : Remove the paper following the procedure below.
a) Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, turn the machine off, open the Scanning Unit (Printer Cover) and remove it.
Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
*If you cannot pull the paper paper out, turn the machine off, and turn it back on. The paper will be ejected automatically.
b) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step a), all print jobs in queue are canceled.
Reprint if necessary.
If you canot remove the paper or the paper tears inside the machine or if the paper jam error continues after removing the paper, contact your Canon Service representative.
Cause b)Landscape credit-card-size paper jammed inside the machine.
Action : Do not load credit card-size paper in landscape orientation.
Slowly pull out the paper from the Tray and remove it.
If you canot remove the jammed paper or if the paper jam error continues after removing the paper, contact your Canon Service representative.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 25, 2009 | Canon PIXMA MX300 All-in-One Printer
How do you load paper into the printing calculator?
Oct 10, 2008 | Canon P23-DHV Calculator
I get a load paper message when paper is loaded
Probaply some paper or obstackles stuck at PE (paper empty sensor) and that could be hard to fix it cuz you may need to pull apart the printer. However, if it is 6 monthsold, warranty covers this problem.
Feb 08, 2008 | Brother MFC-7820N Laser Printer
Canon MP12D Printing Financial Calculator Logo
137 people viewed this question
old marine
old marine
