Question about Duracell Electronics - Others
Duracell du8001 why does my indicator light flash?
Duracell 1000 flashes once. Nothing more. Doesn't work in any of the three modes.
*NOTE: We can only provide support for our products. Some Duracell Flashlights and Portable Lighting Products are distributed by other Duracell licensees. If you have questions or concerns regarding these products, please contact them for support.
Please do NOT contact us for support of these flashlights from the DURACELL® Durabeam™ Ultra Series:
  • 250 lumen flashlight
  • 300 lumen flashlight
  • 500 lumen flashlight
  • 1000 lumen flashlight
Instead, for support of flashlights from the DURACELL® Durabeam™ Ultra Series, please contact:
TechnoMate - phone: 1-888-910-2280 (8:00am - 5:00 Pacific Time)
The reviews here are NOT GOOD!
The reviews
Amazon com Customer Reviews Duracell Durabeam Ultra High Intensity 1000...
Jan 05, 2016 | Duracell Camping, Backpacking & Hiking
Camera says batteries low, replace
Make sure you are using fresh batteries when you are replacing them. If you are using rechargeable batteries, let them charge until the indicator light on the base unit turns green. If the indicator light on the base unit flashes red, the batteries are no longer good.
Cheap batteries form dollar stores (Sunbeam, or store brand name) do not last long, and digital point and shoots eat up those types in a few uses. Best to use Duracell or Energizer batteries for Cameras. They dont have to be Lithium, or digi camera specific batteries. Those are expensive and unnecessary. Basic Duracell or Energizer will do.
Feb 03, 2015 | Sanyo Vpc-s1414 14 Mp Digital Camera Vpc S...
When I insert some batteries the red light begins blinking. I also have some Duracells that appear to be charging but when I place them in the appliance they are dead.
All chargers cannot charge all types of batteries. Are your Duracell batteries NiMH or Alkaline? These indications generally happen when you insert a battery type that is not rechargeable.
Dec 13, 2009 | Duracell AA/AAA NiMH Battery Charger with...
FUji FinePix s1000fd, camera will not power on with new batteries, when it powers on it goes off in a few seconds or minutes indicating battery low, i have used fully charged batteries, ordinary batteries...
I have same problem as edmoze mentions above - batteries went dead. I first tried to use regular Duracell AA and it would still not come on. Went to internet & it recommended getting the Duracell rechargeable NiMh which I did. Got the charger & last nite they charged overnight. Today the camera did come on & I was able to download what I had taken. But what concerns me is that the low battery light is still flashing after a night of charging. What's up? Should I expect this kind of battery problem to continue? Seriously considering getting a Nikon Coolpix.
Sep 02, 2009 | Fuji FinePix S1000FD Digital Camera
Camera Crashes
hi
best is to use rechargable NIMH batteries of atleast 2200MAh or above
the red flashing light is a low batt indicator
cheers
pls rate if it was any help
Jul 05, 2009 | Kodak EasyShare C533 Digital Camera
Red flashing light
Find a new supply of "Duracell Ultra with M3 Technology" batteries and give them a try. The flashing red light is usually an indication that the batteries you have in the unit are not producing sufficient power to run the camera. Rechargable batteries are should have a rating of 2500mAh or above in order to provide enough power to maintain the draw from the camera.
Hope this helps!
OpenSource13
Apr 05, 2009 | Sanyo Xacti VPC-S60 Digital Camera
LED Light on or off indicator
on my charger the red lights are only to tell there is power connecting especially when you have two battery's behind each other on the bottom of my charger there is a guide as to how long you should charge each battery as to size which are aaa 7hours max
aa 24hours
c 24hours
d 24hours
9v 24hours
hope this helps glenn............
Nov 20, 2008 | Duracell AAA NiMH Battery Charger with 4...
Electronics - Others Logo
27 people viewed this question
Top Duracell Electronics - Others Experts
Joseph Mueller
Joseph Mueller
Tom Chichester
Are you a Duracell Electronics - Other Expert? Answer questions, earn points and help others
